| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2018 Subaru BRZ Limited with PP
Understood and it makes perfect sense. I've just never had it happen to any tires before. And I've had plenty of situations with lower pressure in a tire in the past. But then again, this is also my first experience with UHP A/S tires, so I'm sure that plays a big factor. Smaller sidewalls than I'm used to as well.
#16 | |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
You can watch tires separate in a similar fashion in just about any race series when the car gets a flat. It's pretty educational to watch. The tire goes flat, and if the car is a long distance from the pits, you can watch the sidewall split and the tire carcass start flapping around on the wheel. In the really bad cases, the carcass will come apart too and start destroying the body work and suspension bits of the car as it rolls along. This case isn't quite that catastrophic, but the same idea applies. |
| The Following User Says Thank You to Desertnate For This Useful Post: | Dzmitry (05-15-2023) |
| Front tire damage in skidpad. | andyk5 | Tracking / Autocross / HPDE / Drifting | 15 | 09-19-2022 05:07 AM |
| tire damage question? | Thet | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 03-26-2015 04:07 PM |
| Nail in the sidewall | ApoNono | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 02-15-2013 08:54 PM |
| Damage to built up area of sidewall/stock tire. | Zadkiel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 09-25-2012 10:03 PM |
| Tire Sidewall Question | applekash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-26-2012 09:42 PM |
