Old 05-25-2015, 03:28 PM   #1
FirestormFRS
P0451
Keep getting this infernal code and can't figure out why.
Mods
KW C30 kit
Skunk2 Header
OP/FP/CBE
Clamped the vacuum hoses under the intake but I'm still getting the code generally after I drive a bit and park the car come back and the DTC is there. Any suggestions would be greatly appreciated.
FirestormFRS is offline   Reply With Quote
Old 05-25-2015, 04:00 PM   #2
SPCorBUST
SPCorBUST's Avatar
There is a thread on this code with multiple fixes including gas cap, hose clamping under the manifold (guess you can rule that one out), and determining if it's tune based.
Have you tried flashing back to stock and driving around below boost in low rpms for a few days? You could temporarily remove your cogged belt if you want to check the higher rpms as well. If it doesn't come up, the issue might be the MAF.
I think you could also try switching MAFS with a buddy and seeing if it goes away for you and pops up for him. That would expose the sensor as an issue but not if it's related to leak at certain rpms.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
FirestormFRS (05-25-2015)
Old 05-27-2015, 11:30 AM   #3
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I am also throwing this code. I Just swapped in a used FA with 8k on it after I blew up mine. Nothing special, 3bar MAF, 'stock' perrin Vortech Tune, and Radium Catch Cans.
Ran the exact same setup for an entire year on previous engine, and double checked all connections and hoses. Nothing changed with my filler cap - haven't gotten gas for over a month (Car sat for about 3.5 weeks while I dealt with engine crap)
Any ideas would be helpful.
Thanks!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-27-2015, 02:05 PM   #4
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
I got the same code when installed my Kraftwerks SV kit, just got tune update and hope no code again
scionfr_s is offline   Reply With Quote
Old 11-11-2015, 07:25 PM   #5
MattHoffman
Drives: BRZ Limited
I am working with oft for a tune right now but, I still get it with my vortech v3.
MattHoffman is offline   Reply With Quote
Old 11-11-2015, 08:14 PM   #6
Gopherboy6956
Yea i cleared it and it comes on once a month or so, maybe. Header related is my guess
Sent from my HTC6525LVW using Tapatalk
Old 06-14-2016, 07:03 PM   #7
nmastereal
Why would this be header related. This strictly has to do with EVAP I thought.
nmastereal is offline   Reply With Quote
Old 06-14-2016, 09:50 PM   #8
steve99
Drives: FT86
Mods
KW C30 kit
Skunk2 Header
OP/FP/CBE
http://www.autocodes.com/p0451_subaru.html
Do you guys have flex fuel kits or aftermarket wideband 02 sensors using evap input to ecu if so get your tuner to disable P0451. As the evap sensor input has been re purposed
It just an emmissions code so just disable it , but it does indicate you have an leak in evap emmisions system or a stuffed evap sensor or the plugs loose or similar. If your not running a tune thats repurposed the evap input, but its not needed for engine running.
but will cause you grief at an emmissions readyness check
Old 06-14-2016, 10:46 PM   #9
Gopherboy6956
Good point - I guess when it happens now, i just clear it and move on with my day. Could certainly be tune related.
I have no aftermarket fuel system changes, I do have catch cans though.
but yea, i just clear it and it will stay off for 1 to 2 months.
Old 06-04-2017, 02:21 PM   #10
brillo
Drives: 2013 Firestorm FR-S
I have the moto-east flex fuel kit and I keep getting this code. I presume I need the tune adjusted to turn this feature off? Car seems to drive fine. Any issues with driving or logging with this code?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-03-2023, 12:56 AM   #11
Humphrey
Drives: 2014 Subaru BRZ (JSRC)
I recently fixed this problem on my supercharged BRZ. The problem for me was I installed a 11 BAR map sensor and the carb legal tune did not have its MAP scaled to the correct bar. A proper tune with the correct scaling fixed the code.
Humphrey is offline   Reply With Quote
