Old 04-16-2023, 12:36 PM   #4831
tomm.brz
Drives: brz 2017 hksv2
log is a bit short i hoped to see a more vary log of you driving around, also not even hot enough and i don t know the rpm to idle tables in your delicious tuning tune, 65 Celsius only maybe it s really commanded that high?
Does it sits at 1150 rpm also when fully warm at 88 Celsius?
Only "weird" thing i can see from this short log is a bit positive fuel trim, but not by too much, could not be relevant , as i never have seen a delicious tune with a perfectly spot on maf scaling/SD Volumetric efficiency, they rely really much to Ecutek closed loop correction and subaru oem fuel trims to make everything look good
usually fuel trims go positive when there is a small leak in exhaust btw
Old 04-17-2023, 12:56 AM   #4832
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I do have a small leak at the muffler that I'm fixing. And yes when fully warmed up to temperature it still idles high. It only has started idling high recently before it idled at the correct rpm.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 04-17-2023, 01:04 AM   #4833
tomm.brz
a leak in the muffler is too far and hardly a problem.. anyway
you have racerom 11
old tune with probably lot of bugs
Ask delicious to send you a more updated tune because the currently one you have gives you the dtc and high idle
I ve heard other times of similar problems... ALL with delicious canned tunes. All of them. Ask delicious to fix this
Or change tuner
Old 04-25-2023, 09:36 PM   #4834
Chris3007
Drives: 2013 BRZ Limited 6MT
A question for the folks that have installed the works oil cooler / regulator on the car. How did you route this hose coming off the throttle body? Installing it as intended, when you put the silicon coupling on it pushes the hose so far it makes contact with the belt. How did you do it? Any creative routing suggestions?
Chris3007 is offline   Reply With Quote
Old 04-26-2023, 08:38 AM   #4835
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I actually bypassed mine but that may not be a great idea for you in NY. Can you find a hose with a built in elbow to replace it with?
B T is offline   Reply With Quote
Old 05-01-2023, 03:44 PM   #4836
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Originally Posted by FrickingReallySlow View Post
Just got off the phone with Tony from EB, their main SC tech. He told me some very interesting things about the Filter that everyone has to do apparently.
1. EVERYONE needs to REMOVE the sealant you applied to the airbox seal. They found that it contaminates the MAF sensor and get all sorts of weird behavior (J02 anyone?). The sealant no longer shipped with the kits roughly 1.5 years ago and they're advising everyone to clean it off if you've applied it
2. DO NOT use the OILed version sold on K/N website. ONLY use dried, they switched to using a special EB only dried K/N filter that's painted red (no oil) in 2017. He advised us to use K/N cleaner ONLY then wash with water and then dry in the sun for 2 DAYS! just to be sure because the cotton very easily traps water. Also he said to vigorously shake it to get the water out lol
EB part number is 51-0157
K/N special part number is SP-3737
Again do not use the OIL spray, or sealant. It fucks things up apparently.
@devtec
I am a dumbass and applied O-ring silicone lube to my dry K&N filter.
Maybe this is why I am still experiencing hesitation and -18% long term fuel trims?
What is the part number for the dry filter, I am going to order a new one and reclean my MAF sensor.
GPhilly is offline   Reply With Quote
Old 05-01-2023, 03:53 PM   #4837
GPhilly
GPhilly's Avatar
See this post.. guy reported mostly hesitation/stuttering.
I actually see this on 1st going downhill in slight traffic with my foot off the pedal. haven't gotten logs yet since it only occurs going slow downhill for some reason. Its like the throttle is doing rapid fire bursts.
@devtec
Did issues come back long term after replacing the PCV valve?
I am having the SAME exact issues you were having. Only thing I replaced so far were the intake manifold gaskets which seemed to help for about 100 miles or so.
It seems to have helped short term trim, but car still drives like shit and sees bad LT trim.
Old 05-02-2023, 06:52 PM   #4838
brandonblt2
Originally Posted by GPhilly View Post
@devtec
Did you check the bypass valve yet? Mine was leaking and was producing a loud hissing and sucking sound. When I did a smoke test through the intake it didn't leak. Only when I plugged my smoke machine line directly into the bypass valve did I see it was leaking like a sieve and I have the old bypass valve.
Last edited by brandonblt2; 05-05-2023 at 12:12 PM. Reason: bypass valve is older style
Old 05-04-2023, 11:28 AM   #4839
GPhilly
GPhilly's Avatar
Originally Posted by brandonblt2 View Post
Did you check the bypass valve yet? Mine was leaking and was producing a loud hissing and sucking sound. When I did a smoke test through the intake it didn't leak. Only when I plugged my smoke machine line directly into the bypass valve did I see it was leaking like a sieve and I have the new bypass valve.
How did you do this without damaging the solenoid? Edelbrock instructions say to not tamper with the Bypass Valve.
I have not checked it yet. I do hear loud hissing on start up but cannot tell where it is coming from. Did they send you a new one?
Old 05-05-2023, 10:22 AM   #4840
brandonblt2
I don't believe a smoke test will damage the solenoid but I'm no expert. My car had a hissing sound that progressively got louder over time. I could definitely tell it was coming from the drivers side of the engine bay.
How is your idle? Is it high? If so another way to test it is pinching the vacuum line that runs to it or removing it completely and plugging it with your thumb and seeing if your idle drops a few rpm and is more stable.
As for the part I just went and brought it straight from Edelbrock it was $70. Probably could have gotten it for free if I really tried but, I just wanted the part asap.
Be fore warned if you do end up having to replace the bypass valve you will have to remove the supercharger to reinstall the upgraded version. The one they sell is V2 of the bypass valve. It is a lot bigger compared to V1 which you didn't have to remove the supercharger to install.
Old 05-05-2023, 08:14 PM   #4841
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Read this post. https://www.ft86club.com/forums/show...postcount=2368
The bypass valve is just a spring loaded silicon diaphragm attached to a metal rod that moves when vacuum is applied. Just don't apply too much vacuum or pressure when testing, you'll see the normal operating values in that post. It's super easy to check.
If you have the first version, i.e. 3 mounting screws, it's probably leaky. V2 has 2 mount bolts and is much beefier, not to say that it couldn't develop a leak.
And yes, replacing V1 with V2 requires SC removal.
BirdTRD is online now   Reply With Quote
Old 05-10-2023, 12:58 PM   #4842
Panstiks
Drives: Subaru brz 2014
What diameter to make my exhaust system?? 76mm(3") 70mm(2.75") 64mm(2.5")
I have the edelbrock supercharger kit
Sent from my SM-S908B using Tapatalk
Panstiks is offline   Reply With Quote
Old 05-10-2023, 05:08 PM   #4843
Hikari1
Hikari1's Avatar
Drives: 2016 BRZ Hikari
Hey everyone, having a weird issue with a high idle at low speeds when pushing the clutch in. It did this intermittently in extreme heat last year but this year after the winter is doing it everytime once the car has warmed up. At low speeds, when I put the clutch in, the car wants to idle at ~2000rpm for a few seconds...
I've checked the bypass valve, it's the updated model, and it's holding pressure and vacuum without leaking.
I've added a log short log of driving it to recreate the problem after a half hour drive to get it up to temp and a video of its behaviour as well...
https://datazap.me/u/hikari1/high-id...?log=0&data=30
https://drive.google.com/file/d/1VW6...ew?usp=sharing
2016 BRZ Hikari Edition
@BRZHikari1
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=107326
Hikari1 is offline   Reply With Quote
Old 05-17-2023, 11:01 PM   #4844
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I have to say that I’ve got a very new Edelbrock SC and a Delicious tune. The warmer the weather has become the more erratic the idle is. It’s super annoying. Right after startup and after driving a fair distance, everything is wonderful… no issues. Get in the car and restarting after going to the grocery and it’s a complete disaster. Idle bouncing and car trying to die. It sucks and I’m about to switch to a tune from CSG. I just want to know… is there anyone out there with this supercharger and a Delicious flex fuel tune that ISN’T having these types of issues at all?
Jeff86 is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
