Old 04-26-2023, 02:32 PM   #7239
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well I just ordered that alcantara dash piece, and also this alcantara gauge hood: https://www.ftspeed.com/part/66180ca...trim-2013-ft86
MOAR ALCANTARA.
Funny story, back when JPM Coachworks was still in business, I asked them in June of 2013 how much their entire alcantara dash was: $1,200! Pretty expensive but wow that would look great.
Let me know if the hood improves the windshield glare.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
Clipdat (04-26-2023)
Old 04-26-2023, 02:35 PM   #7240
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Absolutely, will do!
Originally Posted by humfrz
I'm old and lazy
Old 04-26-2023, 04:36 PM   #7241
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Capt Spaulding View Post
I’m curious to see what you think. Most know that the quickest way around a corner is at the limit of the tires’ grip. It’s not in a full lock slide. Not saying the guy doesn’t have good car control. He does. But …
He looks like he is pushing pretty hard. Also depends a lot on tire. Ever watch the races at Goodwood on old bias ply's? They drive with a good amount of slip angle. Not anywhere near full lock though. Well, not often anyway.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Capt Spaulding (04-26-2023), Ultramaroon (04-27-2023)
Old 04-27-2023, 12:56 PM   #7242
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My buddy at work bought a 56' two door Bel Air from my uncle. Has a small block out of a 70's truck but he got a decent deal. He called me over the other day because it wouldn't start. The aftermarket digital dash in it won't even light up until you wiggle or remove/reinstall the high tension wire from the coil to the distributor. Then we have power again. Pretty sure we have a bad contact somewhere between battery/ignition switch/aftermarket dash. He got some factory analog gauges to replace the digital unit. Still, weirdest shit I have seen in awhile
humfrz (04-27-2023)
Old 04-27-2023, 01:16 PM   #7243
Sounds like it's time to clean up the contacts/wires between the coil, distributor, battery and starter.
I'll ring up ol @Tcoat for you, he is good with those old, junked up, half breed vehicles -
NoHaveMSG (04-27-2023)
Old 04-27-2023, 01:33 PM   #7244
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Whoops!
Electrical gremlins back at work this week.
Went shopping a couple days ago and didn't get the trunk shut all the way again.
~ 265 mV left in the battery this morning.
Going to find a neighbor to get a jump start to get a bit of charge in.
The battery tender doesn't sense enough to even try starting to charge it.
edit: got back from an hour drive for a bump charge. Reads 12.76 now so the tender has something to bite into.
It's blinking green lights now on the tender.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (04-28-2023), NoHaveMSG (04-27-2023)
Old 04-27-2023, 05:07 PM   #7245
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Get new wires.
soundman98 (04-28-2023)
Old 04-27-2023, 06:15 PM   #7246
Sapphireho
Famous Potatoes
Sapphireho's Avatar
If I had a '56, and money to burn, I would put this under it with an LS and 6mt.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (04-28-2023), NoHaveMSG (04-27-2023), Stephen W. (04-28-2023)
Old 04-27-2023, 07:09 PM   #7247
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Get new wires.
He has an appointment to take it into a specialty shop on Tuesday. I'd rewire it for him proper, I just don't have time. He ordered an ignition switch, and picked up a set of factory gauges locally. We weren't able to rule out the ignition switch in the time I had to look at it. I'm pretty sure it is something to do with everything tying together at the ignition switch.
There is a Bel Air that pops up at TT/TA events on the west coast. I have seen it a couple times. Full Speedtech chassis with LS swap. It's pretty cool to see tearing around.
Old 04-27-2023, 07:13 PM   #7248
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I ment the wire from coil to dist. You usually have to buy a plug wire set
Old 04-27-2023, 07:48 PM   #7249
Well if you are going to do that then:
https://www.vfnfiberglass.com/5557chevy.htm
Old 04-27-2023, 08:55 PM   #7250
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
We tried that, and we tried a new coil.
Old 04-28-2023, 12:41 AM   #7251
Sapphireho
Famous Potatoes
Sapphireho's Avatar
We'll see.
Off to buy lottery tickets.
Old 04-28-2023, 12:42 AM   #7252
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Bummer.
Pics?
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
