Old 04-26-2023, 10:04 AM   #1
ag-brz
Drives: 2022 BRZ MT
Question Caliper bracket bolts class action
Hi, I had a major issue with my 2022 BRZ where the caliper bracket bolts broke and the whole caliper came off while driving!! I haven't modified the car at all.
Subaru Service denied my warranty and wanted to charge me nearly $3,000 to fix it. Mavis did it for $130 including parts.....
If anyone had any issue similar to this or with similar bolts please respond or DM me as I'm starting a class action lawsuit because this isn't safe or right. Subaru has a serious problem with how they make bolts, as all of them seem to be extremely junky (including the studs).
ag-brz is offline   Reply With Quote
Old 04-26-2023, 10:12 AM   #2
Tokay444
Subaru doesn't make bolts. I can promise you that.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Clipdat (04-26-2023), DarkPira7e (04-26-2023)
Old 04-26-2023, 11:39 AM   #3
Grady
Grady's Avatar
That escalated quickly, I would rethink your path.
Old 04-26-2023, 11:54 AM   #4
ermax
ermax's Avatar
Do you have evidence that this is a common problem with caliper bolts? I know people have issues with the studs breaking when tracking where they swap rims frequently but this is sort of common on all cars that are tracked frequently on OEM studs.
Hard to do a class action when no one else has had a caliper bracket bolt failure. Also, this could have been caused by someone (you?) over torquing the bolts.
Old 04-26-2023, 12:07 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You have an unhealthy obsession with bolts loosening themselves on your car, Certainly this has nothing to do with you probably inspecting your hardware to see if your hardware matched the discussed hardware from your other forum post, right?
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (04-26-2023), Clipdat (04-26-2023), DarkSunrise (04-27-2023), NoHaveMSG (04-26-2023)
Old 04-26-2023, 04:07 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did you or anyone touch them?
Never heard of such an issue happening ousdie of negligence.
Old 04-26-2023, 09:57 PM   #7
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
As I said in your other thread, people mess up 1.25 thread studs all the time, For all the other bolts on subaru cars in general? They're fine, and not made by subaru anyway.
Though I still hate the valve cover bolts with a fat shank on the EJ when the car has seen a decade of road salt. Corrosion just seizes them to the valve cover and there's very little you can do about it with a 10mm socket in a narrow crevice.
Old 04-28-2023, 01:09 AM   #8
ag-brz
Drives: 2022 BRZ MT
It very much has to do, its the same issue. This is essentially a repost. My caliper came off and that's very dangerous. I never took the car to anywhere other than subaru service
Old 04-28-2023, 01:09 AM   #9
ag-brz
Drives: 2022 BRZ MT
who makes their bolts?
Old 04-28-2023, 01:53 AM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Good luck with your class action suit. Maybe you should just sue yourself. Afterall, with $130 in damages it would be way worth it. Let's not forget emotional trauma.
Class action also makes sense, after all, there are ones of people who have had this problem.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Clipdat (04-28-2023), DarkSunrise (04-28-2023), Opie (04-28-2023), Tokay444 (04-28-2023)
Old 04-28-2023, 02:47 PM   #11
Grady
Grady's Avatar
Same issue does not equal the same problem. If what you are telling us of no mods and only been to Subaru, getting warranty on that would have been simple. There has to be more to the story? My guess is you have been an ass to the dealer/service center so they are not going to go out of their way to help you.
The Following User Says Thank You to Grady For This Useful Post:
NoHaveMSG (04-28-2023)
Old 04-28-2023, 03:53 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm also only questioning what went wrong when the caliper fell off if an independent shop fixed it for 130 bucks.
Old 04-28-2023, 05:36 PM   #13
ag-brz
Drives: 2022 BRZ MT
I only went to an independant shop begrudgingly after nearly 2 months of not having a car, because they were refusing to do anything.
Old 04-28-2023, 05:38 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
So what did the shop fix? You didn't get an itemized list? 130 is pretty close to hourly rate for most dealerships and close to hourly for independent shops. How fast were you going when it fell off? Which caliper bolts, slider pin or bracket to hub?
Brake caliper bracket bolt Pinoy_FRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-12-2019 03:38 PM
Need help finding a dual caliper bracket. Snarl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-20-2016 09:39 AM
Dual Caliper custom bracket THA STI GUY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 02-25-2015 06:41 PM
Class Action Lawsuit 8brz BRZ First-Gen (2012+) — General Topics 88 06-21-2012 06:45 PM
