go_a_way1, MisterSheep
Old 04-21-2023, 07:28 PM   #24235
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did pads and rotors all around, then detailed the wheels while they were off.
The Following 9 Users Say Thank You to RToyo86 For This Useful Post:
Cheeky (04-26-2023), Dadhawk (04-21-2023), DarkPira7e (04-21-2023), Greg Erskine (04-23-2023), mike_ekim1024 (04-22-2023), new2subaru (04-21-2023), norcalpb (04-21-2023), Stephen W. (04-23-2023), Wally86 (04-24-2023)
Old 04-21-2023, 07:32 PM   #24236
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Wow, very nice! What product(s) did you use for the wheels?
Originally Posted by humfrz
I'm old and lazy
Old 04-21-2023, 08:01 PM   #24237
RToyo86
RToyo86's Avatar
I used Meguiars D101 APC diluted around 5:1 for initial cleaning; I had to use extra elbow grease on the tires with a mircofiber.
Sprayed on carpro reload for some protection, and did the tires with Adams graphene tire coating.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Clipdat (04-21-2023), Wally86 (04-24-2023)
Old 04-22-2023, 06:57 PM   #24238
new2subaru
Weight Weenie
Drives: 15 FR-S
Installed ARP wheel studs that I've had on the shelf for a few years. The stock studs just kept on going...
Oh, and an AP racing sprint kit. Looks good with the 16" SSR Type C wheels.
The Following 7 Users Say Thank You to new2subaru For This Useful Post:
Clipdat (04-22-2023), eMCee (09-16-2023), NoHaveMSG (04-28-2023), RToyo86 (04-23-2023), Wally86 (04-24-2023), whataboutbob (04-28-2023), yberther (04-25-2023)
Old 04-23-2023, 01:14 PM   #24239
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Decided to clean the coilovers over the weekend. Just starting, I wanted to adjust and the spring collar was frozen to the coilovers body... Unfun but it must be done!!
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
Cedric (04-25-2023), NoHaveMSG (04-28-2023), orz (04-24-2023), Teseo (04-25-2023), Wally86 (04-24-2023)
Old 04-24-2023, 02:34 AM   #24240
orz
orz's Avatar
Drives: Halo
Started unboxing some new parts for the 86. Just got the rear suspension done but I ran out of sunlight. So round 2 tomorrow.
Here's round 2. 4/24/23. Doing this install at my friends house. So I'm stuck here for another night.
Rear calipers and brake lines in.
and the front suspension sorta done.
Round 3: Tomorrow. Front calipers, bleed brakes, and adjust ride height. Brake pads still look meaty at 40k miles.
orz is offline   Reply With Quote
The Following 10 Users Say Thank You to orz For This Useful Post:
AK2112 (04-27-2023), Cedric (04-25-2023), DarkPira7e (04-24-2023), NoHaveMSG (04-28-2023), RToyo86 (04-24-2023), soundman98 (04-24-2023), Teseo (04-25-2023), villainous_frx (04-24-2023), Wally86 (04-24-2023), whataboutbob (04-28-2023)
Old 04-25-2023, 12:33 AM   #24241
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
WHAT DID YOU DO TO YOUR FRS TODAY?
Installed a used set of Fortune Auto 500s (6k/7k) + Verus lower control arms
Install was pretty straightforward; I should have cleaned the underbody, fender wells and coilovers beforehand.
Cedric is offline   Reply With Quote
The Following 5 Users Say Thank You to Cedric For This Useful Post:
NoHaveMSG (04-28-2023), orz (04-25-2023), Teseo (04-25-2023), villainous_frx (04-25-2023), Wally86 (04-25-2023)
Old 04-25-2023, 09:33 AM   #24242
RToyo86
RToyo86's Avatar
That's how a 3 hour job becomes a 5 hour job
Cedric (04-25-2023), Wally86 (04-25-2023)
Old 04-26-2023, 08:04 PM   #24243
ammtx
Drives: 2015 Scion FR-S
Looking for Mods to Remove
Bought a 2015 FR-S last december as a project car, and it's been a hell of a project. There's a couple of problems that persist that make me think there's an undiscovered mod somewhere in that car. Here's why I think this:
The car is just too perfect for drifting!!!
1. The previous owner put in coilovers. They're set as low as possible.
2. The Traction Control is ALWAYS OFF. Turns out that the ABS light, the Traction Control light, and the Check Engine light are CONSTATLY ON. I had my mechanic diagnose this as needing a new ABS Actuator. He changed it, and it wasn't fixed.
3. The Cooling Fan is constantly on. This prevents the car from overheating, despite constant revving. My mechanic recommended changing the ECM. We put in a used ECM and had it reprogrammed for this car. THe new ECM didn't fix the problem.
4. The engine has plenty of power until it hits 4,000 RPM. Looks like that would be it's LIMP MODE. No matter how hard I drive it, it never goes over 4,000 RPM, so I guess I can't redline it!
After getting the ECM and the Actuator replaced, the car still has the ABS light, the Traction Control Light and the Check Engine light are still on.
I then took the FR-S to Cavender Toyota in San Antonio, TX. They kept the car for about 3 weeks and their diagnostic is that it needs a new ECM and a new ABS Actuator.
So I'm thinking that the previous owner had some undisclosed work done to it. Any recommendations for next steps?
ammtx is offline   Reply With Quote
Old 04-27-2023, 08:59 PM   #24244
orz
orz's Avatar
Drives: Halo
Install Complete
Got her aligned today. Stock settings for now. Did the first test run and everything seems to be fine. No weird nvh squeeks, pops, or clucking.
Summary:
FactionFab F-Spec Coilovers (7k/7k). Ride height set to 35mm on the collars. (two finger gap). Full soft.
Pedders Front Endlinks. Preload set to zero
SPC Camber Bolts (bottom)
Front/Rear Powder Coated Calipers
Front/Rear Stoptech SS Brakelines.
Project Mu Brakefluid
Blox Racing LCA
Whiteline Toe Arms
The Following 4 Users Say Thank You to orz For This Useful Post:
bcj (04-29-2023), Cedric (04-28-2023), MJones_RB (04-28-2023), NoHaveMSG (04-28-2023)
Old 04-27-2023, 10:50 PM   #24245
RToyo86
RToyo86's Avatar
Not a great picture.. but
Installed TRD engine and trans mounts. Was fortunate a friend lent me his lift; took me around 2 hours to do everything. Driverside mount was the most PITA but I did it kevinvo method without removing the header.
Only immediate intial impressions but I am quite pleased with lessened slop and NVH actually dropped after pulling out the OEM trans mount with whiteline insert.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
Cedric (04-28-2023), Clipdat (04-28-2023), DarkPira7e (04-27-2023), MJones_RB (04-28-2023), NoHaveMSG (04-28-2023)
Old 04-28-2023, 12:11 AM   #24246
Clipdat
Proud of BOXER
Clipdat's Avatar
Summary:
Blox Racing LCA
Whiteline Toe Arms
If you were paying for an alignment after installing all those nice suspension bits, why not dial everything in properly straight away?
Respectfully, I'm not sure I understand the logic of putting it on the rack if you aren't going to be making everything exact and specifically what you want.
Those numbers aren't necessarily what I'd want to be driving around on, to be honest. Again, just my opinion.
I'm old and lazy
The Following 3 Users Say Thank You to Clipdat For This Useful Post:
NoHaveMSG (04-28-2023), Ohio Enthusiast (04-28-2023), Wally86 (04-28-2023)
Old 04-28-2023, 02:13 AM   #24247
orz
orz's Avatar
Drives: Halo
@cliipdat Understandable. Just gotta trust the process.
Old 04-28-2023, 12:52 PM   #24248
Clipdat
Proud of BOXER
Clipdat's Avatar
What's the process?
I'm old and lazy
