Old 04-23-2023, 03:15 AM   #15
tomm.brz
Drives: brz 2017 hksv2
if really 95Ron is the only fuel your going to use and you chase high numbers, you d need to go around 10:1, 300whp are then probably very achievable with 95Ron
You ll lose efficiency and mpg when you re not in boost, and you d need to raise the boost on a hypotetical Greddy t518z with a boost controller to 0.7 bar at least
This will then bring new problems as charge air will be hotter but still the lower compression outperform the rise in air temperature when you are in boost so you will be able to raise timing and reach your power goal easier
New rims cut my 0-60 a lot more than expected Riftur Scion FR-S / Toyota 86 GT86 General Forum 133 04-21-2017 02:28 PM
Greddy Turbo Kit 2.5/2.75" to 3"FP/CB Gains midnight23 Forced Induction 8 03-06-2014 10:34 PM
Seeing more than expected? CLTBRZ BRZ First-Gen (2012+) — General Topics 26 07-09-2012 03:47 PM
What kind of gains without Turbo Surge101 Engine, Exhaust, Transmission 18 01-25-2012 09:23 PM
Not what I expected. Casual Scion FR-S / Toyota 86 GT86 General Forum 34 11-23-2010 07:25 PM
