Old 03-06-2023, 01:39 PM   #15
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Originally Posted by Mike_ZN6 View Post
@Ruben_86_ Were you able to install the driver/passenger Recaros and disable all the dash lights for the air bags, etc. ?
I have used a resistance in each connector and I have no light on the dash
Ruben_86_ is offline   Reply With Quote
Old 03-06-2023, 01:42 PM   #16
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Originally Posted by churchx View Post
I wonder if such custom made side mount brackets:
1) don't net extra width due their shape like L, not 7, like in later schematic pics?
2) if they cannot be made adjustable for wider selection of seats .. by simply changing their bottom mount holes to longer slots?
Yes, they could be made adjustable for a little wider seats
Old 03-06-2023, 06:12 PM   #17
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Even for the passenger seat? Did you transfer the occupancy sensor over to the passenger Recaro?
I tried to find you on instagram but didn't see any matches for @Ruben_86_
Mike_ZN6 is offline   Reply With Quote
Old 03-07-2023, 09:19 AM   #18
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
https://instagram.com/ruben_86_?igshid=ZDdkNTZiNTM=
I have not used the occupant sensor or the seat belt connectors, I do not know if I go with the passenger airbag always active.
but it doesn't mark me any problem in the dash
Old 03-07-2023, 03:38 PM   #19
gpvecchi
gpvecchi's Avatar
The passenger airbag is always on. The seatbelt and occupant sensor is just for the seatbelt alarm.
Anyway, we're going offtopic.
Old 03-31-2023, 03:56 PM   #20
gpvecchi
gpvecchi's Avatar
@Ruben_86_ can you please tell me what is the distance between the rear bolt in its lowest position and the floor?
I'd like to know if I can go lower using your brackets.
Old 04-01-2023, 05:14 AM   #21
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Hello, when I go to the garage I measure it, it will take a few days.I show you this photo that I have, the seat is very low, lower than the original
I already have the supports in production and orders are allowed on request
The Following User Says Thank You to Ruben_86_ For This Useful Post:
gpvecchi (04-01-2023)
Old 04-17-2023, 02:18 PM   #22
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
13-13,5cm
Old 04-17-2023, 04:09 PM   #23
gpvecchi
gpvecchi's Avatar
13-13,5cm
Thank you very much! I'll take precise measures of mine tomorrow!
Old 04-17-2023, 05:35 PM   #24
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Put them here, I'm curious
gpvecchi (04-18-2023)
Old 04-19-2023, 03:55 PM   #25
gpvecchi
gpvecchi's Avatar
Took the measures: with Recaro JDM slider and Recaro JDM side brackets (not that stupid ABE ones), the height is between 13,5 and 14 cm. This is correct, as Recaro sliders are declared to be 5 mm higher from stock, probably because of the seat belt bracket.
I found a very low sliders from Japan, the Kawai Works, but they'll not permit to use the Recaro JDM side stands. But I got an idea from them, I'll try modding the Recaro sliders, perhaps I could get around 2,5 cm more lowering.
Old 04-19-2023, 04:59 PM   #26
Pat
Pat's Avatar
Drives: 2023 BRZ
Why are ABE sliders stupid? I don't know much about this, and have a set waiting to go on as soon as my seat arrives.
Old 04-20-2023, 12:52 AM   #27
gpvecchi
gpvecchi's Avatar
The ABE brackets are absurdly high. The seat will results higher than stock one. Using the JDM brackets I lowered it 2 cm.
I think the best and cheapest solution is to use the custom brackets sold by Ruben 86.
The Following User Says Thank You to gpvecchi For This Useful Post:
Ruben_86_ (04-22-2023)
Old 04-22-2023, 02:05 PM   #28
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
The height of my supports is limited by the shape of the original bar, but for me it is already low, more than the originals
gpvecchi (04-23-2023)
FS: Recaro Pole Position MrAsh2222 Canada Classifieds 2 06-27-2021 02:13 PM
Recaro Pole position timandytimandy Interior Parts (Incl. Lighting) 1 08-30-2017 11:40 AM
Recaro Pole Position Gliderx Tracking / Autocross / HPDE / Drifting 1 04-06-2016 07:07 PM
FS: Recaro Pole position leather peebking Canada Classifieds 0 03-10-2016 04:08 PM
