Old 04-17-2023, 01:21 PM   #141
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by norcalpb View Post
Dang it, this was my largest fear with this kind of mod as I just got a relatively expensive alignment done.
Dropping the rear a quarter inch or whatever won’t ruin your alignment, raise the rear up to match what it was before and you’ll be bang on.
ineedyourdiddly
Old 04-17-2023, 01:27 PM   #142
norcalpb
norcalpb's Avatar
Shouldn’t effect ride height. You are just changing the pickup point for the trailing arm. It may require slightly stiffer spring rate. MCA even states there's doesn't effect alignment.
I’m not sure who makes the bracket in @makinen ‘s 2nd link, but the author mentioned a 5mm drop. I think a stiffer spring is recommended in the first link because the subject car is on stock suspension, and lowering the rear 5mm on stock spring rates may cause one to excessively ride the bump stops.
“ The bracket is about 22mm before installation.
17mm after installation
I think it's because the angle of the rod has changed and the load on the suspension has increased.
Of course, I adjusted the car height to restore it.
After this, adjust the alignment again and it's done.”
Old 04-17-2023, 01:29 PM   #143
norcalpb
norcalpb's Avatar
Unfortunately I am on springs/shocks so no ride height adjustability…but the drop is report-ably only 5mm so that’s not even noticeable to most.
Old 04-17-2023, 02:01 PM   #144
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interesting. I wonder if it is changing the anti squat so much at that position in the travel that it is causing a bit more sag.
Old 04-17-2023, 07:51 PM   #145
makinen
makinen's Avatar
Drives: Toyota 86
I've ordered GP Sports one a month ago and am waiting for its production. After collecting information from the reviews, I've prepared two things.
Slightly stiffer rear springs of GT86(FRS) as BRZ rear springs used currently, and the Subtle solutions 1/4" spacers. GR86 rear springs could be better but GT86's were free for me.
FYI the spring rates
https://www.ft86club.com/forums/show...3&postcount=11
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-17-2023, 09:38 PM   #146
whataboutbob
AutoX-10/10ths every run
RLCA with different coilover mounting points allows you to change the motion ratio which can be used to mimic stiffer springs fyi. I have my coilovers on the outermost mount on the SPL RLCAs and did not have to adjust the ride height/spring rate after installing the MCA traction mods.
Build thread:Here
Old 04-18-2023, 02:20 AM   #147
Compelica
Compelica's Avatar
Drives: 86 GT
Am in the process as well of swapping my rear 4K springs to 6K after installing the MCA traction mod, I was bottoming out too easily even on daily driving.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 04-18-2023, 03:25 PM   #148
norcalpb
norcalpb's Avatar
Did you notice a change in the static ride height when parked? Or just changes in the travel?
Old 04-19-2023, 10:58 AM   #149
Compelica
Compelica's Avatar
Drives: 86 GT
Did not notice that it changed, although I had my ride height re-adjusted during the installation.
Old 04-25-2023, 01:32 PM   #150
yberther
yberther's Avatar
Drives: '13 SWP Limited
Thanks for all the comments and recommendations in this thread!
I ordered and also found out the MCA is redesigning these, so they are currently discontinued. I was told a couple months before the new design will be available.
Hope to try them out once I get them in.
yberther is offline   Reply With Quote
Old 04-26-2023, 06:26 AM   #151
Compelica
Compelica's Avatar
Drives: 86 GT
Will it be a redesign with the same relocation point, or otherwise?
Old 04-27-2023, 02:55 PM   #152
yberther
yberther's Avatar
I asked but no response yet, I can't imagine so though? I wonder if it has to do with the international patent application as a couple other companies have come out with something similar.
Old 05-04-2023, 05:51 PM   #153
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Hi Bob, does the outer mounting on the arm equates to 'softening'? Thank you in advance.
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 05-04-2023, 08:51 PM   #154
whataboutbob
Lutfy
Hey,
BLUF: The outer position equates to creating less leverage on the coilover, which in effect makes the spring seem stiffer.
There's probably a math equation that can be applied, but here's what I think is an accurate analogy.
Consider the point at the end of the RLCA to be the end of a cheater bar. Consider the point at which the coilover is mounted to the RLCA to be where the force of the cheater bar (i.e. your tire moving up in travel) is attempting to compress the coilover spring. If you decrease the distance between these 2 points by moving the coilover mounting point toward the end of the RLCA, you are effectively shortening the length of your cheater bar (i.e. you have LESS leverage). This reduced leverage is why I *think* that in this configuration your suspension will feel/act like you have stiffer springs.
I *might* be wrong, but this is how I understand motion ratio to work.
Build thread:Here
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
