#4831 |
Drives: brz 2017 hksv2
log is a bit short i hoped to see a more vary log of you driving around, also not even hot enough and i don t know the rpm to idle tables in your delicious tuning tune, 65 Celsius only maybe it s really commanded that high?
Does it sits at 1150 rpm also when fully warm at 88 Celsius? Only "weird" thing i can see from this short log is a bit positive fuel trim, but not by too much, could not be relevant , as i never have seen a delicious tune with a perfectly spot on maf scaling/SD Volumetric efficiency, they rely really much to Ecutek closed loop correction and subaru oem fuel trims to make everything look good usually fuel trims go positive when there is a small leak in exhaust btw |
| The Following User Says Thank You to tomm.brz For This Useful Post: | brandonblt2 (04-17-2023) |
#4832 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#4833 |
a leak in the muffler is too far and hardly a problem.. anyway
you have racerom 11 old tune with probably lot of bugs Ask delicious to send you a more updated tune because the currently one you have gives you the dtc and high idle I ve heard other times of similar problems... ALL with delicious canned tunes. All of them. Ask delicious to fix this Or change tuner |
#4834 |
Drives: 2013 BRZ Limited 6MT
A question for the folks that have installed the works oil cooler / regulator on the car. How did you route this hose coming off the throttle body? Installing it as intended, when you put the silicon coupling on it pushes the hose so far it makes contact with the belt. How did you do it? Any creative routing suggestions?
#4835 | |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
#4836 | |
Drives: 2020 Subaru BRZ (Edelbrock SC)
I am a dumbass and applied O-ring silicone lube to my dry K&N filter. Maybe this is why I am still experiencing hesitation and -18% long term fuel trims? What is the part number for the dry filter, I am going to order a new one and reclean my MAF sensor. Last edited by GPhilly; 05-01-2023 at 04:03 PM. |
#4837 | |
Did issues come back long term after replacing the PCV valve? I am having the SAME exact issues you were having. Only thing I replaced so far were the intake manifold gaskets which seemed to help for about 100 miles or so. It seems to have helped short term trim, but car still drives like shit and sees bad LT trim. Last edited by GPhilly; 05-02-2023 at 08:05 AM. |
#4838 | |
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 Last edited by brandonblt2; 05-05-2023 at 12:12 PM. Reason: bypass valve is older style |
#4839 | |
I have not checked it yet. I do hear loud hissing on start up but cannot tell where it is coming from. Did they send you a new one? |
#4840 | |
I don't believe a smoke test will damage the solenoid but I'm no expert. My car had a hissing sound that progressively got louder over time. I could definitely tell it was coming from the drivers side of the engine bay. How is your idle? Is it high? If so another way to test it is pinching the vacuum line that runs to it or removing it completely and plugging it with your thumb and seeing if your idle drops a few rpm and is more stable. As for the part I just went and brought it straight from Edelbrock it was $70. Probably could have gotten it for free if I really tried but, I just wanted the part asap. Be fore warned if you do end up having to replace the bypass valve you will have to remove the supercharger to reinstall the upgraded version. The one they sell is V2 of the bypass valve. It is a lot bigger compared to V1 which you didn't have to remove the supercharger to install.
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 Last edited by brandonblt2; 05-05-2023 at 10:52 AM. Reason: Corrections |
#4841 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Read this post. https://www.ft86club.com/forums/show...postcount=2368 The bypass valve is just a spring loaded silicon diaphragm attached to a metal rod that moves when vacuum is applied. Just don't apply too much vacuum or pressure when testing, you'll see the normal operating values in that post. It's super easy to check. If you have the first version, i.e. 3 mounting screws, it's probably leaky. V2 has 2 mount bolts and is much beefier, not to say that it couldn't develop a leak. And yes, replacing V1 with V2 requires SC removal. |
#4842 |
Drives: Subaru brz 2014
What diameter to make my exhaust system?? 76mm(3") 70mm(2.75") 64mm(2.5")
I have the edelbrock supercharger kit ![]() ![]() Sent from my SM-S908B using Tapatalk |
#4843 |
Drives: 2016 BRZ Hikari
Hey everyone, having a weird issue with a high idle at low speeds when pushing the clutch in. It did this intermittently in extreme heat last year but this year after the winter is doing it everytime once the car has warmed up. At low speeds, when I put the clutch in, the car wants to idle at ~2000rpm for a few seconds...
I've checked the bypass valve, it's the updated model, and it's holding pressure and vacuum without leaking. I've added a log short log of driving it to recreate the problem after a half hour drive to get it up to temp and a video of its behaviour as well... https://datazap.me/u/hikari1/high-id...?log=0&data=30 https://drive.google.com/file/d/1VW6...ew?usp=sharing
2016 BRZ Hikari Edition @BRZHikari1 Build Thread: http://www.ft86club.com/forums/showthread.php?t=107326 |
#4844 |
Drives: 86 (FR-S)
I have to say that I’ve got a very new Edelbrock SC and a Delicious tune. The warmer the weather has become the more erratic the idle is. It’s super annoying. Right after startup and after driving a fair distance, everything is wonderful… no issues. Get in the car and restarting after going to the grocery and it’s a complete disaster. Idle bouncing and car trying to die. It sucks and I’m about to switch to a tune from CSG. I just want to know… is there anyone out there with this supercharger and a Delicious flex fuel tune that ISN’T having these types of issues at all?
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
