#127 |
That Guy
Drives: 2013 asphalt FRS MT
It mostly just makes the rear more predictable IMO
| The Following User Says Thank You to Calum For This Useful Post: | jeepmor (04-22-2022) |
#128 | |
Professional wrench
Drives: 2020 BRZ ST RS
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
| The Following User Says Thank You to JohnH For This Useful Post: | jeepmor (04-22-2022) |
#129 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Oh man, now I'm chomping at the bit to get these put on. The extra power boost provides in these cars makes the stock setup a lot more twitchy.
I see less toe and more camber alignment notes. Anyone have any numbers to share? I have camber bolts up front already, and rear LCA arms and this MCA mod sitting on the bench. I'm taking notes on all this but don't have any numbers to go on. Is there a thread on alignments and the numbers that I've missed. I have looked, but only find the more here, less there commentary. I don't mean to detract from the thread, but do see how it all ties together as a package for handling, not just bolt on magic. |
#130 | |
Drives: 17 Asphalt 86
My last alignment was done trackside at a shop run at the facility. I sort of just let the guy do what he wanted after giving him some guidelines on the car being daily etc. Took the car out and made 3 separate adjustments to fine tune it. I've also tried 0 toe front 1.5mm[1/16] toe rear, 3mm toe in rear[this was a misunderstanding via tech], 0 toe front and 0 toe rear. I like having around 1.5mm toe in rear, and 0 toe front or touch of toe out. If you want the front end more stable on highways stick with 0 toe front. Last edited by RToyo86; 04-23-2022 at 12:26 AM. |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | jeepmor (04-23-2022), Racecomp Engineering (04-23-2022) |
#131 |
This is the MCA traction mod thread, I won't hijack this off course with any more alignment questions. Thanks for input, but I'll do some reading and start a new thread on alignments if I have more questions.
#132 |
Drives: 2022 BRZ
Just wanted to followup on this thread. I tried getting the MCA traction mod, only to find out they were backordered, and shipping from Australia costs a ton. I ended up find the GP Sports traction mod due to this thread. It's unique due to the way it reinforces the subframe bushing, and includes a rear subframe bushing as well.
I really liked this mod more than I thought I would. Highly recommended. The rear suspension feels more compliant, with the same springs. |
| The Following 6 Users Say Thank You to Wangspeed For This Useful Post: | DocWalt (04-17-2023), MrSkubi (04-17-2023), MyHybridBurnsGasAndTires (04-16-2023), norcalpb (04-16-2023), RedReplicant (04-16-2023), yberther (04-25-2023) |
#133 | |
Drives: Toyota 86
Some reviews that I found in minkara told that rear springs should be changed to the strong ones.
| The Following User Says Thank You to makinen For This Useful Post: | norcalpb (04-16-2023) |
#134 |
Drives: 2022 BRZ
#135 |
Drives: 2023 GR86
GKTech has released something similar, at an extremely good price point.
https://us.gktech.com/fr-s-gr86-brz-...-mod-arm-combo |
| The Following 2 Users Say Thank You to MConte05 For This Useful Post: | norcalpb (04-16-2023), RedReplicant (04-16-2023) |
#136 | ||
#137 | |
Drives: 2022 BRZ
I investigated that one. I don't like the direction that they mounted the spherical bearing at the subframe. It's going to max on alignment, which is really bad. Even in the pictures on their site, at full droop, you can see it either maxed or near max. |
| The Following User Says Thank You to Wangspeed For This Useful Post: | DocWalt (04-17-2023) |
#138 |
Drives: Toyota 86
Yes, several reviews mentioned.
https://ameblo.jp/naughty-bear/entry-12371533584.html https://minkara.carview.co.jp/userid...2485/note.aspx
| The Following User Says Thank You to makinen For This Useful Post: | norcalpb (04-17-2023) |
#139 | |
#140 |
Drives: Crapcan
Shouldn’t effect ride height. You are just changing the pickup point for the trailing arm. It may require slightly stiffer spring rate. MCA even states there's doesn't effect alignment.
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 06:34 PM |
| Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 02:49 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
