Old 04-08-2023, 08:37 PM   #19755
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Originally Posted by CB750F View Post
Looked at it.
Your power must be back if you got the garage door to open…
Since there are lots of Chocolate Rabbits around for tomorrow its a reminder that you have to pick up a new battery to replace that 8 yr old exhausted one ..
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
Dadhawk (04-08-2023)
Old 04-14-2023, 12:56 PM   #19756
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
A few days ago, but changed up the gauge cluster face.
Oxyg3n is offline   Reply With Quote
The Following 3 Users Say Thank You to Oxyg3n For This Useful Post:
Busybee (04-16-2023), KMA KiCKz (04-14-2023), villainous_frx (04-14-2023)
Old 04-16-2023, 11:00 PM   #19757
Oxyg3n
Oxyg3n's Avatar
Took it to 86 Cafe
Busybee (04-17-2023), Clipdat (04-17-2023), MrSkubi (04-17-2023)
Old 04-17-2023, 10:28 AM   #19758
almostquick
Drives: 2017 BRZ PP
Very nice. Where did you get the gauge cluster faces from?
almostquick is offline   Reply With Quote
Old 04-17-2023, 05:29 PM   #19759
Oxyg3n
Oxyg3n's Avatar
@almostquick thanks. Got them from revlimiter.net
Old 04-22-2023, 07:34 AM   #19760
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Finally had the time for the Fumoto valve, changed the oil (Idemitsu) and the filters. I was a little concerned due the slope but everything went smoothly.
Her favorite shoes are also on!
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following 6 Users Say Thank You to Busybee For This Useful Post:
Clipdat (04-22-2023), JD001 (04-22-2023), new2subaru (04-22-2023), RToyo86 (05-02-2023), Teseo (04-23-2023), The Red One (04-22-2023)
Old 04-22-2023, 09:33 AM   #19761
JD001
JD001's Avatar
Drives: Subaru BRZ
Finally got round to booking my BRZeeeeee in to get the KW V3s setup as at the moment it's running with the KW "out of thd box" set-up which is too low for me.. Decided to also have the Superpro rear suspension arms and the toe links installed.. Just curious to see what the extra rear camber adjustment does to the car's handling... The front camber bolts were definitely noticed, sharper turn-in.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Busybee (04-22-2023), Clipdat (04-22-2023)
Old 04-22-2023, 09:36 AM   #19762
JD001
JD001's Avatar
Drives: Subaru BRZ
So you didn't manage to talk to the guy across the road about using his nice flat driveway?
Old 04-22-2023, 04:13 PM   #19763
Busybee
Busybee's Avatar
To be honest I didn’t want to bother both of them. Everyday they have 2-3 cars. Was a little worried but now I am very OK to do my basic maintenance here.
The Following 4 Users Say Thank You to Busybee For This Useful Post:
Clipdat (04-22-2023), JD001 (04-22-2023), soundman98 (04-23-2023), Teseo (04-23-2023)
Old 04-22-2023, 04:39 PM   #19764
The Red One
Pro Couch surfer
My driveway has a much steeper incline that yours,
I have kept 2 pieces of good size 1/4 cut logs just to block any movement when doing seasonal tire changes,
seems to have worked for past 20 years as I can still write about it.
Any serious under car work I do in my very narrow garage.
The incline driveways get you quite paranoid and im always rechecking if I enabled the Parking brake when the car is running before I get out…
Busybee (04-24-2023)
Old 04-23-2023, 09:52 AM   #19765
Teseo
Drives: frs
If you have that kind space, why not go with ramps?
Old 04-23-2023, 10:44 AM   #19766
WNDSRFR
Drives: FR-S,GTI
My driveway has the same incline angle as my ramps. So with the car facing downhill on the ramps, it's level to do oil change.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
Busybee (04-24-2023), Sapphireho (04-23-2023)
Old 04-23-2023, 01:22 PM   #19767
Muffled
Those nifty jack stands probably help too. I've never seen a style with those kinds of feet.
Muffled is offline   Reply With Quote
The Following User Says Thank You to Muffled For This Useful Post:
Old 04-23-2023, 04:06 PM   #19768
soundman98
ProCrastinationConsultant
soundman98's Avatar
I don't recommend ramps. The few I've tried using loved shooting out at random times during the loading/ unloading process. On vehicles with ample ground clearance
A jack and stands is slower but more predictable.
