#1331 |
Had an interesting but short chat with someone who knows about the new version of the supercharger for the FA24.
They are very excited about the new version, but apparently it is still in the pre (metal) casting stage, and has not yet been tested on an engine. However, this is not too far away. There will be little to no interchangeability (of the main castings) between the FA20 version and the FA24 version. The inference was that it would not be worth trying to convert an older FA20 version to a new version by purchasing newer parts. |
| The Following 5 Users Say Thank You to grumpysnapper For This Useful Post: | DocWalt (03-22-2023), Irace86.2.0 (03-22-2023), Lucky Ookami (03-23-2023), M0nk3y (03-22-2023), YCK (03-22-2023) |
#1332 | |
Drives: Q5 + BRZ + M796
I'm trying to decrypt what you meant in your last paragraph. Are you trying to suggest the new supercharger won't be the old supercharger top with unique runners for the FA20 and FA24, such that someone could take their old/1st gen supercharger and have the legs machined off in order to make the old supercharger work with the new legs or something, so they could transfer their old supercharger from their FA20 to their new FA24? I doubt you meant they are switching to the TVS 1740 from the 1320, and you were talking about to upgrade blowers or something. The TVS 1320 is on our Audi Q5 3.0T, and it is recommended for 3.0-4.5L applications, but I could see them going with a bigger blower too in order to accommodate more power. I would be surprised if Edelbrock comes out with a different looking top to their supercharger considering they built their runners to be separate in advance.
#1333 | |
Drives: Toyota 86 GTS 2019
Yes it was at QR. I didn't log the ambient temp logged at the time. I'll get some fresh track log in a couple of weeks. Driving around town or highway speed my intake air temperature is at 20C above ambient temperature |
| The Following User Says Thank You to YCK For This Useful Post: | grumpysnapper (03-23-2023) |
#1334 | |
In other words it is not being built with any consideration for the old unit to be forwards compatible. |
#1335 | |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | grumpysnapper (03-23-2023) |
#1336 | |
Looking at it through my Ecutek Dashboard, my IAT is 5C higher than ambient temperature on a cold car. Does your IAT reads higher or the same as ambient when your car is cold? |
#1337 |
Drives: brz 2017 hksv2
Has the Harrop a TMAP? Anyway if you have a custom map, you can ask your tuner to modify the intake air sensor scaling in the tune to match the 5C offset and you have a more reliable reading
#1338 | |
Master Collaborator
The MAP and IAT sensors are separate on the Harrop, and Harrop supplies their own IAT sensor. Here's something to consider: Is the IAT sensor off, or is the ambient temperature sensor off? (the ambient temperature sensor being whatever is being used to check the temperature of the air surrounding the car in the morning.) The way to check would be to use an ice water bath on the ambient temp sensor. The result should be 0 deg. Celcius or 32 deg F. If that sensor is right on, the IAT is probably off and needs rescaling. I haven't pulled the IAT sensor out of my Harrop to see it's design so I couldn't say one way or the other if it's able to be submerged in water in order to check its accuracy, but if it's completely sealed, it can be checked the same way. I have the CARB tune file that Harrop supplies, but I've not checked to see if it can be opened and the IAT scaling checked. If anyone wants to know, I can certainly try and find out. Edit: I got curious on this myself so I attempted to open Harrop's CARB tune and it is locked. However.... I also have a copy of Harrop's non-CARB tune which is NOT locked and I can see the parameters as: IAT Sensor Voltage Min = 0.40 IAT Sensor Voltage Max = 4.71 Scaling at -40 deg. C = 4.736 Volts Scaling at +120 deg. C = 0.205 Volts Edit #2: Fixed the mistake where I had the Min and Max values transposed, and adding the note that all of these values are identical to our stock IAT sensor parameters. One other note, the Min and Max voltage parameters define the threshold values where the DTC P0112 and DTC P0113 will activate respectively. Hope this helps.
| The Following 5 Users Say Thank You to FR-S2GT86 For This Useful Post: | DocWalt (03-27-2023), grumpysnapper (03-31-2023), Irace86.2.0 (03-27-2023), tomm.brz (03-27-2023), YCK (03-27-2023) |
#1339 |
Master Collaborator
Anybody ever have issues trying to loosen the 5mm Allen head screws from the pulley hub? Mine don't seem to want to budge. Maybe Harrop used some LocTite on the threads? I'm afraid I might break an Allen key or worse, strip the hex head out on the screw. I'm thinking I might have to upgrade from an Allen key to a hex socket to get more torque on it, but I wanted to get some advice here first from someone that has changed one out already.
#1340 |
Master Collaborator
Follow-up from previous post:
Yes, I needed to step up to a 5mm hex bit socket, 3/8" drive, and yes, Harrop uses the blue LocTite on the threads. Had to run to the local hardware store to pick up both but the pulley change-out job is now complete. |
#1341 |
Can you paste here the harrop tune? curious what cam timing they run)
#1342 | |
....I'm on a Motec, I'll check with the engine guy when I get out to him next time. (Its due for a little tuning clean up, as its idling is a little inconsistant at the moment).Obviously one reading is out somehow... Is it all going well aside from that? Now we're coming into cooler weather, your car should feel super strong! |
#1343 |
Did you go down in pulley size?
#1344 |
Master Collaborator
Yes, swapped to the 85mm pulley. Currently logging and getting calibrations sent back to me by my tuner. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | grumpysnapper (04-15-2023) |
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 05:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 02:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 03:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 03:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 01:58 PM |
