Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-10-2023, 07:23 PM   #15
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
The change from near zero to -1.5 front with camber bolts was quite noticeable, even on the street. Didn't cause me any issues in the winter either (I wasn't sure if it would make it too twitchy on ice). Very happy with that mod.
I find many cars on the road today look a tad strange from the back, with negative camber on the rear wheels, but the fronts being dead straight. Once you see it, it is hard to "un-see" it lol.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 04-12-2023, 09:16 AM   #16
ZDan
ZDan's Avatar
Drives: '23 BRZ
I think it's pretty stupid they don't build these at -1.5* to -2* front camber instead of 0* plus/minus. Cost to manufacture is exactly the same, and it's not like it would result in "dangerous oversteer" or excessive "camber wear" (which isn't really much of a thing with most radial tires anyway). Pretty annoying to be pretty much required to get camber plates to track these cars...
OkieSnuffBox (04-12-2023)
Old 04-13-2023, 01:33 PM   #17
Ernest72
No need for camber if you drive the speed limit on public roads.
Old 04-13-2023, 02:07 PM   #18
Pat
Pat's Avatar
Drives: 2023 BRZ
No, there isn't a need for it. It just handles better, even within legal limits.
The Following 5 Users Say Thank You to Pat For This Useful Post:
DarkPira7e (04-13-2023), Jdmjunkie (04-13-2023), Ohio Enthusiast (04-13-2023), OkieSnuffBox (04-13-2023), removedonut (04-13-2023)
Old 04-13-2023, 03:18 PM   #19
foshjowler
Drives: 2022 BRZ; 2014 BRZ
There are a lot of things we don't need, yet here we are.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
The Following User Says Thank You to foshjowler For This Useful Post:
Old 04-13-2023, 03:37 PM   #20
ZDan
ZDan's Avatar
Drives: '23 BRZ
Having additional cornering grip available in an emergency benefits safety.
Saved me this AM as I was just making the yellow light for U-turn on way into work and my foot slipped off the brake! Got some understeer and scrubbed the winter tires I'm still on, but easily made the turn. Thanks to -2.5 camber (my "winter setting")!
Old 04-13-2023, 03:44 PM   #21
mr.whiskers
Drives: '22 BRZ
The next autocross event I went to after getting my 1.5 degree camber I did a 360 degree spin... I'd say for the street 0 camber is safer
mr.whiskers is offline   Reply With Quote
The Following User Says Thank You to mr.whiskers For This Useful Post:
vindiesel (04-13-2023)
Old 04-13-2023, 04:10 PM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
Nope. You just need more practice behind the wheel.
If you haven't reached the point you can steer the car with the throttle.....
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
Pat (04-13-2023), Stephen02 (04-13-2023)
Old 04-13-2023, 04:13 PM   #23
OkieSnuffBox
Yep, I could name all kinds of things we don't NEED. But if you aren't going to enjoy life, might as well just jump off a building and call it a day.
Old 04-13-2023, 04:48 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
Old 04-13-2023, 08:11 PM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
Unlikely the camber had anything to do with you spinning. 0 or 1.5 would make very little difference.
The Following User Says Thank You to new2subaru For This Useful Post:
ZDan (04-14-2023)
Old 04-13-2023, 08:47 PM   #26
Pat
Pat's Avatar
Drives: 2023 BRZ
I feel a big difference between zero and one and a half degrees.
Old 04-13-2023, 09:22 PM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
1.5 is a decent move on the right direction. But a lot more is needed to extract max grip. In any case if someone went from 0 front camber to -1.5, it’s absurd to ascribe any spins to this (not so) radical change in front camber. Also, this car suffers massively from being nose-heavy, so negative front camber is fricking crucial to get any kind of decent balance. -1.5 front camber is a step in the right direction but not nearly enough to balance the car.
For anyone who finds this understeery car to be too spinny with a mere 1.5deg front camber, I recommend a LOT more track time.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Jdmjunkie (04-13-2023), new2subaru (04-14-2023), OkieSnuffBox (04-14-2023)
Old 04-13-2023, 10:53 PM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
I've lived with three and a half degrees for the last 10 years. And have driven 5°. I'm not saying one and a half is ideal. Just that it is a significant difference from zero.
The Following 2 Users Say Thank You to Pat For This Useful Post:
Ultramaroon (04-20-2023), villainous_frx (04-14-2023)
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
