Old 04-07-2023, 08:21 PM   #4341
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Does 1st gen RCE yellows fir 2nd gen struts? @Racecomp Engineering
Stonehorsw is offline   Reply With Quote
Old 04-07-2023, 08:43 PM   #4342
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by autoracer86 View Post
Thanks for that. I had a look at the kit and it makes more sense now. Is there much height adjustment being done when using the bushing inserts ? I honestly never even though about this aspect till now ha
I don't believe so but I am not familiar with that kit.
autoracer86 (04-07-2023)
Old 04-10-2023, 04:58 AM   #4343
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
Anyone know for the front end roughly:
- How much toe changes per degree of camber? Like X amount of added negative camber ~= Y amount added toe in?
- How much X amount of turns on the tie rod = Y amount of toe in / out?
2023, BRZ if it makes a difference.
grippgoat is offline   Reply With Quote
Old 04-10-2023, 10:08 AM   #4344
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't remember off the top of my head. But I did post about this a few years ago. Try searching.
Old 04-10-2023, 10:31 AM   #4345
Short answer no, we're working on 2nd gen springs.
- Andrew
Stonehorsw (04-10-2023)
Old 04-10-2023, 05:49 PM   #4346
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
How tie rod turns affect toe, toe affecting camber and vice-versa
I'd like to have this info too. I did most of it at one time but can't find my notes.
Pat, can you give us some hints as to what to look for and where in a search? I've tried and have struck out!
Scargod is offline   Reply With Quote
Old 04-10-2023, 08:37 PM   #4347
grippgoat
I found this thread. https://www.ft86club.com/forums/showthread.php?t=104005
Haven't gone all the way through it yet, but is that the one you were thinking of?
-Mike
The Following 2 Users Say Thank You to grippgoat For This Useful Post:
Pat (04-10-2023), Tatsu333 (04-11-2023)
Old 04-11-2023, 10:46 AM   #4348
-Mike
That's the one i was thinking of lol. I remember he posted that and I double checked the next time I did an alignment.
- Andrew
Old 04-11-2023, 06:04 PM   #4349
Scargod
Track Day Junkie
Scargod's Avatar
I have created a Google doc that spells this out and could come in very handy.
I'm having people review it before I publish it and I need to confirm the length of the steering arm (centerline of the hole to center of spindle).
Anyone?
Old 04-12-2023, 02:16 AM   #4350
bradsm87
Drives: It has 4 wheels
I have the SPL kit and I didn't like the way the car felt with the subframe raised. It felt a bit looser with trying to put power down on corner exit.
I think using the parts shop max kit (raises the rear of the subframe a little more than it does the front) as well as re-drilling the trailing arm bolt hole lower would give you the best of both worlds.
bradsm87 is offline   Reply With Quote
Old 04-12-2023, 12:10 PM   #4351
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
For classing I am not allowed to alter suspension pickup points. Otherwise MCA traction mod would have happened long time ago.
Old 04-12-2023, 07:47 PM   #4352
Scargod
Track Day Junkie
Scargod's Avatar
My takeaway from reading 80% of that long thread from 2017 is that if you have your car significantly lowered "for racing" and have the supporting mods, that it may do little to help.
More interesting to me is if there is a "rear steer" issue with our cars if they are lowered. I have Lime Rock and some others where "bumps" and getting light are an issue and I've already had one issue that seems like it was related to the rear getting light and it snapping on me.
Old 04-13-2023, 07:28 PM   #4353
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So went to my first autox event with the new setup. I was pretty happy with the front end, but looking for some ways to get the rear a bit more willing to rotate on throttle.
Current setup:
-Lowered about an inch on T2s set to recommended settings
-2.3° camber up front, 1.8 rear
-0 toe front, 2mm total toe in rear
-19mm Perrin front sway on soft
Ideas I had:
A. Change the front sway bar to the stiff setting.
B. Reduce toe in the rear.
C. Driver mod.
Also: "Build Thread"
Old 04-13-2023, 08:44 PM   #4354
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Current setup:
Ideas I had:
C. Driver mod.
Reduce toe in rear for starters. Stiffening the front sway will have the opposite of desired effect.
Edit: I forgot you have T2's. Give it a couple more clicks of rebound in the rear.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
marco_mc22 (04-15-2023), Spuds (04-13-2023), yberther (05-03-2023)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
