| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: '04 STi, '12 Mazda 3 Hatch
Why 0° Camber?
Why do cars like the Twins come with 0° front camber and no built in adjustment? Does runnning 1° or so increase tire wear that dramatically? Even if that's true, they were clearly willing to sacrifce running costs (MPG) for sportiness, so why not tire life? This is the case with many sporty cars, but then there are several other non-exotic sports cars that do have adjustment and negative camber with the stock specs. Adding some adjustment doesn't seem like it would add real expense to production and giving up a tiny bit of tire life seems like a trade off any buyer of a 2 door car would accept. Why are the manufacturers so far away from what the buyers want on this item?
| The Following User Says Thank You to Lelandjt For This Useful Post: | Carsnguitars (04-13-2023) |
#2 |
Drives: 17 Asphalt 86
Production costs are mainly to blame for lack of front camber combined with McPherson strut design. A simple camber/crash bolt can add around 1° or just over 2° if you run both.
-1 to -2° up front doesn't change tire wear much from my experience, toe on the other hand has much greater effect. I've roasted inner shoulders running toe out up front. |
#3 |
Famous Potatoes
Drives: '15 ultramarine
People, and even performance shops used to look at me crazy when I told them I wanted/ran 1° negative camber. 1981.
I guess I was ahead of my time. Edit: I'm tAlking a car I autocrossed. Streetcar should be 0. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | norcalpb (04-10-2023) |
#4 |
Drives: 1994 Lexus ES300
Why do you want camber by default?
#5 |
Drives: 2023 brz limited 6mt red
Brz understeers from factory when pushed hard into corners. People that drive on the streets that don’t want to go to prison or into a guardrail you won’t notice it too much. People that track will notice the difference. The crash bolts neutralize any under steer which nets a “quicker” turn in.
If you drive on the street only or never driven on track I wouldn’t bother with it factory is good enough..
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
#6 |
Drives: '13 Whiteout
Factory goes for understeer which is the safer option for inexperienced drivers on the street.
#7 | |
Cost for a slot or eccentric bolts seems like a non-issue. Every car I've driven with 0°, then 1° felt better. Less scrub and more precision in the first half of a turn. I don't think I saw significant tire wear from such little camber and some sports car do have that much in their "street" spec. |
#8 |
#9 |
Famous Potatoes
#10 | |
Drives: '22 BRZ
The car is being built to a certain price point and at some point in time engineers decided to go with the cheaper MacPherson up front instead of double wishbone. And this decision was probably made like 13 years ago or whenever they were designing the first gen. I think to perfect the second gen they could have put the Toyota 1.6T in there detuned to 200hp instead of the boxer and front double wishbone but I am not sure how much that would affect the cost and if its realistic at all, but one can dream. |
#11 | |
Drives: '22 BRZ
#12 | |
Drives: '23 BRZ Limited
I run -2.5 and zero toe on my street car. Massive grip and sensational turn in. And -2 in the rear with a touch of toe-in. See above. We are talking functional camber, not the -8 crap you see on tiltly wheel cars with 215s on 10" wide wheels.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#13 |
Drives: It has 4 wheels
Probably for best possible braking predictability under many different conditions as well as to understeer when pushed to legally cover themselves.
Nobody should run 0 camber on Mcpherson struts if you go around corners, street or not. |
#14 |
Drives: '22 BRZ
As mentioned, OEM understeer. Basically all vehicles have it.
2022 BRZ
| SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 02:43 PM |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 02:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 04:40 PM |
