Old 03-31-2023, 07:05 PM   #1
g e
10 year old BRZ - Replace all hoses?
My BRZ turns 10 in November and I plan to run it til it or me drops dead.
Question about the longevity of radiator hoses, heater tubes, etc.
I believe in proactive maintenance and don’t want to be stranded somewhere due to a failure of a $30 hose.
What is a suggested interval for replacing all rubber hoses?
g e is offline   Reply With Quote
The Following 2 Users Say Thank You to g e For This Useful Post:
ddevl_86 (05-19-2023), humfrz (04-14-2023)
Old 03-31-2023, 07:44 PM   #2
Teseo
Drives: frs
After coolant replacement (10 years/100kmiles). Good time to replace the radiator cap/neck assembly and thermostat.
Old 03-31-2023, 09:16 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
How many miles are on it? I agree with the poster above.
Old 03-31-2023, 09:28 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
depends on the conditions they're subjected to. have you looked at them?
Old 04-01-2023, 10:39 AM   #5
g e
About 65,000 miles.
Old 04-03-2023, 12:10 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I picked up 2013 brz in jan 2013 and currently it has 55k. As long as hoses dont leak and look in good condition, should be fine. Replacing with new anyway? Why not! New is eliminating future problem anyway.
Sent from my SM-S918U using Tapatalk
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
humfrz (04-14-2023)
Old 04-14-2023, 01:36 AM   #7
When and if they start to leak.
Bubba says to toss a roll of duct tape in the trunk and not worry about it.
g e (04-14-2023)
Old 05-19-2023, 11:52 AM   #8
ddevl_86
theddevilinme
ddevl_86's Avatar
Drives: 2013 Scion FRS [H8R]
Exactly this!!
Found this dream car for $10k at 95k. Im gonna baby it as best I can, but it's going to be my last car I hope haha
We're all just living to die - might as well enjoy the ride!
ddevl_86 is offline   Reply With Quote
Old 05-19-2023, 03:56 PM   #9
wheelhaus
wheelhaus's Avatar
I'm in a similar boat; 70k 11 years old. I had a very similar question recently and all the above was the same feedback I got. If you're parked outside in really hot dry desert conditions all the time you probably need to replace rubber parts sooner than if you're parked in a garage in more moderate climate. But if the hoses still feel soft and rubbery then they're probably perfectly fine. If you see a bit of cracking or they feel dry and hard, certainly consider replacing. If it's a matter of convenience during other work and/or provides peace of mind, then by all means have at it.
Old 05-19-2023, 11:01 PM   #10
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I remember with my 2004 WRX, when I did the radiator as precautionary maintenance around 125k (they're well known to split at the end tanks past this interval) I did the hoses too. This was in 2016, so the hoses had 12 years and 125k on them.
I think it really depends on the hose and even construction in 2004 vs probably 10 years later. Generally speaking, I'd inspect them visually. Mine were looking kinda ratty and old. If yours looks ok and are pliable, I'd just run them. Maybe if you're doing a coolant change and really want to change them, do it then - because you don't want to be doing a coolant change to last the next 60k+ and have to redo it all again to replace the hoses in 2 years/20k.
There are other hoses, but many less than a WRX. I know on that car all the ones around the turbo were well cooked, hard, and literally breaking if you pushed on them at 125k and 12 years. I replaced all of them, but the BRZ doesn't have that.
Absolutely do check and replace your PCV valve and even associated lines/hoses that usually come with the OEM PCV valve part number. People always forget this even exists. Should be really changed every 30k and speaking of which, mine is due now that it's at 40k.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
g e (05-23-2023)
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 04:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
HPS Silcone Hose Intake pipe, radiator hoses and heater hoses set for sale Sylvas808 Engine, Exhaust, Bolt-Ons 9 07-21-2017 11:39 PM
Year End Sale! Save for the last time this year with RallySport Direct! RallySport Direct Engine, Exhaust, Bolt-Ons 3 12-30-2015 12:22 PM
Year End Sale! Save for the last time this year with RallySport Direct! RallySport Direct Exterior Parts - Lighting 3 12-30-2015 12:20 PM
