| Software Tuning Discuss all software tuning topics. |
Drives: 2013 subaru brz black
OFT Idle cont. unusual??
Hello this was downloaded off my OFT I just repaired; wanted to see if it's normal before I flashed. I wanted to adjust idle rpms and needed to know if these numbers were in fact usable(they were already set.) Also would help if I should just stick to Idle Control - A
Maybe Ill troubleshoot and re-read the ECU and redownload. I was working on it and it seemed Right but I was working on a file that wasn't for my car model but preloaded were right just wanted to know if they were inverse as it didnt seem. Delta?? Or Negate ing the numbers from RPM limit |
#2 |
Please note the difference in Maps from first box which is St2 E85 from the under 2 boxes stage2 91
#3 |
Drives: brz 2017 hksv2
you Simple have bad definition not right for your tunes
any of those table have random values basically if you change any on those values and you save it and flash it, you will brick your ecu. |
#4 |
#5 |
you can find very good info in thw tuning section made by Steve99
anyway, which tune are you using? oft v4? v2? are your tune calid hacked? |
#6 |
Drives: WRB BRZ
#7 |
I'm using OFT v2 and I guess it was hacked since I had major trouble editing back when too. I can't get ecu_defs right with neither of my Stage 2 E85 tunes. CALID ZA1JA01C or technically B01C since mine's manual. Second hand OFT with E85 pop tune that I can't edit. I cannot find a definition file even for the base tune E85. I'll forget about it in the real world for a while since uhh... yea. I'll try with Stage 1 91 and see if I can piece it together but E85 or Stage 2+ has had 0 luck
#8 |
Drives: frs
Maybe flash back to stock, erase all maps from the tablet and start downloading all over again
| Tags |
| idle, numbers, odd, oft, tune |
| For Sale Mint Cont. Japanese 86 & BRZ Hyper Rev Magazine Issue : No.169,173,178,183 | Jimmy45brz | Miscellaneous | 0 | 03-07-2023 10:56 PM |
| FS: OEM Headers 150 local or 180 shipped cont USA | neilvosko | Engine, Exhaust, Bolt-Ons | 10 | 04-16-2018 10:59 AM |
| Sound Unusual? | Carwhisperer | Issues | Warranty | Recalls / TSB | 9 | 07-10-2013 08:40 PM |
| The Curse cont.. | MyGT86 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 07-09-2013 10:29 AM |
| FR-S Cont to Impress me, last event of year... | MarkRacerX | Tracking / Autocross / HPDE / Drifting | 9 | 10-09-2012 09:14 PM |
