Old 03-20-2023, 10:39 AM   #1639
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Originally Posted by moosefro View Post
The oil cooler side of my jackson dual radiator/oil cooler isn't hooked up yet. Although I was babying it the first track day and the last one was in the snow so they might not be representative of normal track use. With the temps I was seeing I was considering not hooking it up at all. But as we get into the summer and I start pushing harder I might see a need soon.
Early on before the kit was released Kpower said they weren't running an oil cooler and I believe others are finding out it just doesn't require the same cooling as the fa20.
In fact, is there a chance of undercooling the oil? If I understand things correctly there's a temp range that's most ideal under stress and we may be considerably below it a lot of the time.
captain awesome is offline   Reply With Quote
Old 03-20-2023, 12:23 PM   #1640
RedReplicant
Drives: None
I pulled the 25 row Setrab out of mine last week since oil temps weren't making it over 185f (one among a few reasons). I've got two events this upcoming weekend, we will see how it does.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
captain awesome (03-20-2023)
Old 03-20-2023, 09:39 PM   #1641
ML
ML's Avatar
Drives: 13 White MT FR-S
Y'all might wanna check this gasket. Had it on since december 2021 and never noticed the HUGE air leak. No wonder the supercharger only made 8lbs last year.
The Following User Says Thank You to ML For This Useful Post:
RedReplicant (03-20-2023)
Old 03-20-2023, 09:57 PM   #1642
captain awesome
Wears Pants
What TB are you using? Also can you flip the gasket 180? When I changed from the stock fa20 TB to the 74mm I don't recall the cutout on the gasket. I'll dig through my spares and see if it's there or not.
Old 03-20-2023, 10:59 PM   #1643
ML
ML's Avatar
This was between the adapter and the manifold. Did I put the wrong gasket on?
Old 03-20-2023, 11:43 PM   #1644
RedReplicant
Drives: None
That's an OEM style B-series gasket, KPower made one that has the extra passages removed
https://kpower.industries/products/b...le-body-gasket
The KPower 74mm adapter to TB gasket isn't even worth using, if you've got that, guarantee it is leaking too - replace it with a hand cut gasket. The KPower BRZ adapter to TB gasket needs to be trimmed out with a razor blade or it eats a solid 2mm of inlet size once torqued.
Lonewolf (03-26-2023)
Old 03-21-2023, 08:29 AM   #1645
captain awesome
Wears Pants
Looks like my gasket had the same cutout but it was flipped and sealed fine. I'd post a pic but this dang forum requires image hosting from another site. Uggh.
The Following User Says Thank You to captain awesome For This Useful Post:
ML (03-21-2023)
Old 03-27-2023, 01:24 PM   #1646
RedReplicant
Drives: None
Results from pulling oil cooler.
PB lap / TT5 lap record and previous session in ~80f ambient data displayed. Previous session was 60% out lap, five laps within ~1 sec of PB, and cool down lap. 216f was peak oil temp, no heat exchanger, no oil cooler.
The Following 4 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (03-27-2023), endless_pain (03-29-2023), ML (03-27-2023), redlined600 (03-28-2023)
Old 03-27-2023, 03:18 PM   #1647
ML
ML's Avatar
what oil? congrats on a record!
Old 03-27-2023, 03:45 PM   #1648
RedReplicant
Drives: None
Thank you, I just run 5w30 Pennzoil platinum full synth. Not super picky about oil.
funkjaw (03-28-2023)
Old 03-28-2023, 01:25 AM   #1649
funkjaw
Drives: 16' WWB
That's what I run (or the ultra platinum if I can find it), good stuff.
funkjaw is offline   Reply With Quote
The Following User Says Thank You to funkjaw For This Useful Post:
RedReplicant (03-28-2023)
Old 04-02-2023, 11:09 PM   #1650
RedReplicant
Drives: None
Secure and wrap your engine wiring harness where it runs near the coils, mine wore through the Raychem and into the bundle of wires.
I'm going to call KPower tomorrow about a replacement engine harness minus injector subharness since I also had a couple of main pins come uncrimped. I've got events in a couple of weeks, fun stuff. With any luck they've got one in stock and with any greater luck I can get some kind of discount since they are $1600.
If not... well. https://www.corsa-technic.com/item.p...facturer_id=45
The Following 6 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (04-03-2023), DocWalt (04-03-2023), endless_pain (04-03-2023), Irace86.2.0 (04-03-2023), ML (04-03-2023), villainous_frx (04-02-2023)
Old 04-03-2023, 09:38 AM   #1651
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I have been waiting on my engine harness since November. So might be a good idea to have a backup plan.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
RedReplicant (04-03-2023)
Old 04-03-2023, 11:31 AM   #1652
RedReplicant
Drives: None
I appreciate the heads up. Settles that
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
