CANADA Canada |
Thread Tools
Search this Thread
Sarcastic SOB
TOB replacement, where to go in the GTA?
My '13 FR-S with 77K km will need the TOB replaced this year. It was starting to sound noisy last fall but I barely drove the vehicle. I'm Thornhill, so ideally somewhere not too far.
-Anyone who has already had the job done and felt they were taken care of properly please tell me where you recommend for me to take my car. -Also, how long should a shop bill for this job in terms of amount of time? -Should I order and get the part from Subaru before I go for the repair? The only Subie shop I've ever dealt with previously other than the dealer was Ivan's Garage in Markham 8 or 9 years ago when I bought the supercharger but that doesn't necessarily mean he is the best option. TIA
#2 |
Drives: 2015 Scion FRS - Raven
I was fortunate enough to have room at home and did the work myself.
But I will recommend that along with the newest version of the throwout bearing. I would recommend replacing this along with the bearing. https://86speed.com/toyota-front-bearing-retainer-cover I had to do the job twice, after changing the bearing things still weren't smooth until I changed that input cover. The plastic part of the bearing rides along that shaft and the wear from the shaft on the new bearing can cause binding. So just replace both and don't forget to lube the shaft. ;-) It took myself and a friend about 6 hours the first time and 4 hours the second time. If there is work on my car that I can't do I take it to Advanced Power House on Woodbine. https://www.aphdyno.com/ |
The Following User Says Thank You to TRAKRAVN For This Useful Post: | wbradley (03-24-2023) |
#3 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
I used OEM bearing + clip from Toyota and a Verus fork + pivot, went to Ron's Quality Auto in London. I believe it was 3-4 hours including a fluid change (was doing a bunch of stuff in one go).
As for going to a shop, only you can decide that. At the time I didn't have space to do such a task, so it was worth it for me. |
The Following User Says Thank You to villainous_frx For This Useful Post: | wbradley (03-24-2023) |
#4 |
Sarcastic SOB
My 2 car garage is really cramped with stuff, barely able to move things around to remove snows and change oil on the STI so I'll have to bite the bullet. Since I've never dropped a transmission before, as I understand is necessary, probably better to pay for the work.
-Thanks for advice re: retainer cover which might also be worn. -The clutch fork, well again pending inspection. Clutch engages well, I wonder at what % is it best to change the clutch? Will have them change the diff and tranny fluid, which is more than ready by now. lol
#5 |
Wes
XIIImotorsports, they have all the parts, including the Verus clutch fork if you want it, in stock. Most reasonable rates around as well
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | wbradley (03-25-2023) |
#6 | |
Unless you have less than 50k kms on the clutch I'd replace it while the transmission is out. It's barely any more labor to do the clutch at that time, vs having to pull the transmission again to do it.
The Following User Says Thank You to wparsons For This Useful Post: | wbradley (04-05-2023) |
EPS ECU replacement | gpvecchi | Software Tuning | 4 | 02-13-2023 12:58 AM |
Best replacement TOB | Muskoka800 | Engine, Exhaust, Transmission | 69 | 02-19-2021 06:12 PM |
Hip replacement and the BRZ | g e | BRZ First-Gen (2012+) — General Topics | 10 | 07-06-2018 06:12 AM |
Replacement Key | 86 South Africa | AFRICA | 7 | 09-19-2016 03:58 PM |
Replacement fun? | Mooseknuckle44 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-01-2014 11:46 AM |
