Old 03-16-2023, 06:32 PM   #5881
stacyu18
Drives: 2014 subaru brz
what tune are you using
stacyu18 is offline   Reply With Quote
Old 03-18-2023, 03:08 AM   #5882
waifu_zn6
waifu_zn6's Avatar
Drives: 2015
anyone running with the CARB tune since install? hows it been?
waifu_zn6 is offline   Reply With Quote
Old 03-18-2023, 11:40 AM   #5883
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Ignore Your Doctor View Post
car going to the dyno next week, we got jrsc high boost pulley, walbro 450 pump, id1050x injectors, delicious flex fuel kit, and a 4 bar map sensor.
excited to see what kind of numbers the car makes!
IF, if time or curiosity allows, do a run with the hood closed vs open. I'm willing to bet power drops by 20-30whp. My kit sounded way better with the air intake in the Jackson's location but performed better with the intake in the bumper like OEM.
PulsarBeeerz is offline   Reply With Quote
Old 03-19-2023, 11:49 AM   #5884
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
I cant remember for the na tunes but the supercharger one was with hood closed and a big ass fan blowing. It was like 75 degrees too.
I am probably gonna put some vents in the hood to help with airflow just havent gotten around to it
Ignore Your Doctor is offline   Reply With Quote
The Following User Says Thank You to Ignore Your Doctor For This Useful Post:
PulsarBeeerz (03-19-2023)
Old 03-21-2023, 12:42 PM   #5885
Wingnutt
Drives: Pearl White 2014
Is there any way to quiet the whistle a bit at idle, in sick of people thinking i have a squealing belt.
Wingnutt is offline   Reply With Quote
Old 03-21-2023, 12:56 PM   #5886
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
What whistle are you talking about? The one from the recirculation valve?
Old 03-21-2023, 01:07 PM   #5887
Wingnutt
Yes, it occurs at idle and goes away as soon as any throttle is applied, so i figure is the recirc valve making that sound
Old 03-21-2023, 01:47 PM   #5888
tomm.brz
Drives: brz 2017 hksv2
it s kinda normal
also the hks supercharger whistle a little bit at idle quite often
Old 03-21-2023, 01:50 PM   #5889
Breadman
Breadman's Avatar
Idle at WOT I guess. It also does it when you are engine braking and just rolling around. It is how the system works. All that air is being forced into your engine hitting your closed throttle plate and has no where to go but out the recirculation valve.
Old 03-21-2023, 06:36 PM   #5890
Wingnutt
So is there a different valve that is quieter?
Old 03-21-2023, 07:08 PM   #5891
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
The valve in the kit is quietest valve you can get. It's a OEM valve used on many turbo vehicles.
JDMChris is offline   Reply With Quote
Old 03-21-2023, 08:29 PM   #5892
Wingnutt
Well crud, i was hoping there was a trick or method to mage it not whistle so much at idle.
Old 03-23-2023, 09:31 AM   #5893
PulsarBeeerz
I been running a GFB T9225 diverter valve since last October. I actually bought it, hope for some more noise. But, if anything it is quieter than the kit BOV at all throttle positions including idle.
Jackson Racing is offering a quieter alternative to the one that comes in the kit as well. https://jacksonracing.com/product/hi...-bypass-valve/ "Great for enthusiasts not wanting to be noticed but wanting the performance and reliability benefits of a quality BOV."
Old 03-23-2023, 02:34 PM   #5894
JDMChris
Drives: 2016
It's not quieter than the standard Bypass Valve in the kit. It is quieter than a Blow Off Valve.
The Following User Says Thank You to JDMChris For This Useful Post:
Decep (03-30-2023)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
