Old 03-21-2023, 02:01 AM   #15
marco_mc22
Drives: Toyota 86
It's the double wishbone design in the rear. The front is macpherson strut. A lot of other performance oriented cars use double wishbone or double a-arm on both ends. They chose not to in the twins because of how wide the boxer is, not enough room for upper control arm in the front. Or at least that is the rumor as to why.
It’s just cheaper, way cheaper, especially if you can use same Subaru parts of other platforms ahahah
marco_mc22 is offline   Reply With Quote
Old 03-21-2023, 11:25 AM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I know. I had always heard packaging being tight as a rumor. Cost above all is probably the primary.
norcalpb (03-21-2023)
Old 03-22-2023, 09:30 AM   #17
It can and probably is a bit of both. Each of these things does not exist in isolation from the other.
foshjowler (03-22-2023), NoHaveMSG (03-22-2023)
Old 03-22-2023, 09:35 AM   #18
Racecomp Engineering
They certainly weren't going to design an all new suspension architecture for the BRZ/86...the existing Subaru design was the only way (tweaked obviously for the specific car).
- Andrew
Old 03-22-2023, 11:37 AM   #19
- Andrew
You mean they aren't hand built to individual specifications by master craftsmen?
Racecomp Engineering (03-22-2023)
Old 03-22-2023, 03:18 PM   #20
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
I did the upgrade some people mention in the thread. 2019 low mileage dampers and whiteline lowering springs, and camber bolts up front. It made the car more compliant over harsh bumps, even though it was lowered. Balance on track is way more neutral than the oversteer bonanza that was the original set-up. I still fry my tyre walls, but at least slightly less so. The alignment made and balance change was great, could attack much harder into the corners, and it feels more agile aswell.
Would ideally want less camber at the rear, but i dont have any adjustability there, at least not for now.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
The Following 2 Users Say Thank You to CedN For This Useful Post:
jflogerzi (03-31-2023), NoHaveMSG (03-23-2023)
Old 03-31-2023, 12:32 AM   #21
jflogerzi
jflogerzi's Avatar
Would ideally want less camber at the rear, but i don't have any adjustability there, at least not for now.
The rear camber won't mater much. adjustability in the rear is very simple and cheap to add when rdy.
2013 Series 10 FRS #553
Old 07-24-2023, 09:43 PM   #22
Spairo
Drives: 2013 FR-S 6 spd in Halo
I am going to revive this thread with a question. I am about to replace my rear upper controls since I found a torn boot on the drivers side upper ball joint. Are the two inner bolts on the UCA adjustable for alignment?
They don't look to be, but then I found this in the factory manual:
c) Inspect and adjust the toe-in and camber. (1) Inspect the toe-in and camber. Inspect the toe-in and camber. If the values are not within the specified ranges, adjust the installation bolt holding the rear suspension member to the vehicle body, or the bolt holding the upper control arm and rear suspension arm so that the values fall within the specified ranges
The question really boils down to: After getting an alignment in the spring, do I have to shell out another $140 for an alignment after I replace the UCA's?
Thanks,
Go Fast, Take Chances
Spairo is offline   Reply With Quote
Old 07-24-2023, 10:22 PM   #23
1. No two manufactured parts are exactly the same,
2. Even when reassembling the same parts, they won't go together exactly the same way.
Yes, always verify/adjust alignment after making any changes to related components.
Old 07-26-2023, 07:50 PM   #24
Spairo
OK. So obviously, that's not what I REALLY wanted to hear, but am I missing something, or is the only adjustment in the rear (with factory parts) the toe?
Old 07-26-2023, 09:20 PM   #25
Ohio Enthusiast
Drives: 2018 BRZ
Yes, there is no rear camber adjustment without going aftermarket.
The service manual instructs using crash bolts ("service bolt") for front camber adjustment. Front caster and rear camber are non adjustable and the manual states "inspect the suspension parts for damage and wear" without recourse for adjustments.
negative camber
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
t86rs rear suspension. stock but 2.6 degree neg camber??? Crunk81us Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 10-18-2016 04:55 PM
Spc control arms and negative rear camber question pbirmingham1988 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-20-2016 01:57 PM
Rear negative camber and adjustable arm Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-07-2016 12:36 AM
Advice on negative rear camber Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-27-2013 10:38 PM
