Old 03-20-2023, 10:37 AM   #1
rsf5048
Drives: 2013 FRS
Engine Ground Strap Locations
Can anyone tell me where the Factory engine ground Strap Locations are? Any one have any pictures?
rsf5048 is offline   Reply With Quote
Old 03-21-2023, 05:18 PM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I know there's one on top of the transmission that's forgotten all the time when people do clutches.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 03-21-2023, 07:10 PM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I believe there are 2, one on each side of the engine. I believe I have 2 pictures but they are covered in UV dye. I need to find them
The Following User Says Thank You to Breadman For This Useful Post:
Wally86 (03-23-2023)
Old 03-21-2023, 07:26 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Bottom of each head. Sorry the photos aren't super clear, jacked my car up quick
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
B T (10-04-2024), Opie (03-26-2023), soundman98 (03-25-2023), Wally86 (03-23-2023)
Old 03-21-2023, 08:56 PM   #5
After almost 10 years on this forum those are the clearest pictures of the straps I have ever seen posted!
Capt Spaulding (03-25-2023), DarkPira7e (03-21-2023), soundman98 (03-25-2023), Turdinator (03-22-2023), Wally86 (03-23-2023)
Old 03-22-2023, 01:18 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Three like what was mentioned. One on either side of the front bottom of the motor going to the frame rail, and one off the passenger top-rear of the motor/transmission going to the transmission tunnel.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 03-25-2023, 06:33 PM   #7
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Anyone ever had problems with inadequate grounding on these cars?
15 years ago I had a Maxima and went nuts on improving the ground connections. I still have a length of 4/0 gauge wire and terminals to match. Still re-learning how to walk and getting a little bored.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-25-2023, 06:49 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
not really. i don't notice any of the dimming issues past cars have had.
all i upgraded was the battery-to-body ground connection for my amp install.
Old 03-27-2023, 11:04 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not really. I think the biggest grounding issue that comes up is the DI driver not being tight as it grounds through itself.
soundman98 (03-27-2023)
How I support the engine with a tie-down strap when removing the transmission Ultramaroon DIY (Do-It-Yourself) Guides 27 08-31-2023 02:01 PM
Photoshoot locations in PDX? Seiryuu Northwest 12 05-23-2020 03:47 AM
E85 locations cuddefred AUSTRALIA 7 10-28-2017 06:13 AM
Owner locations Wheelsoffracing Scion FR-S / Toyota 86 GT86 General Forum 5 09-13-2012 10:47 AM
E-85 locations Hawaiian Engine, Exhaust, Transmission 5 09-01-2012 05:07 PM
