#4803 |
Drives: '17 BRZ Series Yellow Edelbrock SC
Cyl 2 denso plug fail
Check it out y'all! Anyone got any idea of the cause? The core is pushed in 3/8" but the tips aren't bent.
#4804 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
@tomm.brz I'm not making them anymore, but CSG and Delicious made their own versions of my adapter now. I'm not sure if it's on their website, but you could probably call and order it.
#4805 | |
Drives: 2016 Scion FRS Release Series 2#439
Last spring I had an electrode break off of a Denso while lapping. P0302 (cylinder 2 misfire resulted) with a long expensive tow home. Zach has recommended switching to the HKS plugs at one heat range colder. They’ll go in for spring.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) Last edited by Muskoka800; 03-20-2023 at 10:13 AM. Reason: Correction |
#4806 | |
HKS would be HKS-50003-M50HL for one step colder for anyone too lazy to look it up. Also, those are the coldest plugs from any manufacturer I could find, end of the line. Last edited by B T; 03-23-2023 at 10:08 AM. Reason: info added |
#4807 | |
I'm running a stock pulley and 93. And my tune is from Delicious with ECUTEK. I think I'm gonna go to a colder plug. With the stock plugs bring >$30 any way, there's no reason not to. Though I think I'm gonna drop it on a dealership, I hate doing the plugs in this car! Last edited by snowtaipan; 03-21-2023 at 11:37 AM. |
#4808 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Not really possible. You have to remove some fuel lines and replace them when you change the injectors. You would spend far more time trying to do it with the SC installed than just removing it.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#4809 | |
I’ve always been happy with NGK over many years in snowmobiles and auto’s.
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4810 |
May have to give them a try, Zack has expressed a little concern over my spark in the past but never said anything about a specific brand plug.
#4811 |
Drives: brz 2017 hksv2
hks plugs ARE ngk
they cost few, and easy to find.. worth the buy either the 45 for NA or 50 for FI |
#4812 | |
Drives: 2013 FRS
Tuning will be better now too that the map is away from volatile air in the manifold. Thanks for posting this! Helped me figure out exactly what I needed to do! PS how do I thank you on the actual post? I see people "thanked" so and so for their posts but I'm not sure where to find that button. |
#4813 | |
So, I haven’t seen the NGK plug for our car but can say the the HKS has a single electrode (old style) while the Denso’s, as we’ve all seen, have the similar large Centre electrode and two shorter ones at each side. It was the large one that broke off in my #2 cylinder.
#4814 | |
Drives: Silver FR-S
I also changed all the coils. Car is back to awesome!
#4815 | |
Drives: Subaru brz 2014
Sent from my SM-S908B using Tapatalk |
#4816 |
yoy just have to email edelbrock and ask them if they have a tune with your calibration.. lhd or rhd doesn t matter really the tune is the same, you need to find your current oem calibration
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
