Old 03-15-2023, 02:03 PM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Motul discontinue their 75w90?
I looked on line and the oil I've been running for the past whatever years was all sold out. I went on motul's site and only see this https://www.motul.com/us/en-US/products/motylgear-75w90 Did they just rename their product? If not, what is the goto trans and diff oil for someone that autocrosses and does track sprints?
Old 03-15-2023, 03:02 PM   #2
DarkSunrise
DarkSunrise's Avatar
It’s been OOS for a few months now, but I’ve been seeing a lot of stores saying they’re expecting new stock soon. In the meantime I’ve been thinking of giving Ravenol MTF-1 a try. It’s gl4/5 compatible and yellow metal safe like Gear300 and doesn’t have LS additive, but slightly thinner at 75w85.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Breadman (03-15-2023)
Old 03-15-2023, 03:04 PM   #3
Breadman
Breadman's Avatar
I might wait it out then. Not sure it is enough to matter but I don't think running thinner fluids while boosted is a smart move.
Old 03-15-2023, 03:15 PM   #4
DarkSunrise
Yep probably best to play it safe with boost!
2022 BRZ Build
2013 FR-S Build
Old 03-15-2023, 07:09 PM   #5
CSG Mike
CSG Mike's Avatar
It's been on global backorder for nearly a year. It's coming back.
In the meantime, if you order Motul Gear 300 or its variants from CSG, someone will contact you offering you appropriate alternatives and/or upgrades at no additional cost, until Motul is back in stock.
Teseo (03-16-2023)
Old 03-18-2023, 01:54 PM   #6
fableluke
Drives: BLue 2013 frs
i found some on amazon and i saw someone selling 5-6 unopened bottles for $20 each.
fableluke is offline   Reply With Quote
Motul Motylgear 75W90 ? (not Gear 300) manonastick Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 06-16-2014 05:40 PM
Motul Gear300 75W90 oil change interval? levinchow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-09-2014 12:20 PM
