Old 03-10-2023, 12:08 PM   #29
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by terboboost View Post
Where did you find this dyno chart? I can't find anything on US or Japanese site.
It was kinda buried. If you go to hksusa.com under products / engine / camshafts then select the one for our cars you'll get this (which was run with their SC kit): http://hksusa.com/products/22002/AT005/678
For the NA graph I found it under products / engine / capacity upgrade kit / pick Scion / select the detail on 21004-AT002 - PISTON FULL KIT FA20 2.1L and it will bring you to: http://hksusa.com/products/21004/AT002/583
One thing to note, the CR shown on the capacity kit page is 12.4 which is less than what is listed on their complete engine which uses the capacity kit. Makes no sense.
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
terboboost (03-14-2023)
Old 03-10-2023, 12:23 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Uplink View Post
Ok, mystery solved. So after a bit of digging around their site (they have still not responded to my e-mail) I was able to find some ballpark numbers indirectly. If you look at the page for the camshaft they use in the Stage 0 engine, they have a dyno graph. Unfortunately, that graph is the 2.1L capacity kit + cams + supercharger... because of course it is. But if you look at the 2.1L capacity kit used in the Stage 0, it has a dyno graph of just that and the cams, NA. It's basically a little better than going with a 2017 FA20, netting +12hp and +18ft/lbs (209 & 169) over a stock 1st gen. But you're also getting a beefed up engine rated to well above the transmission's reliability plus it's a complete drop-in replacement. All-in, it's not a terrible option.
It's been said before, so I will repeat. FA20's already have a kind of poor rod/stroke ratio. The HKS capacity kit makes this worse.
https://www.motortrend.com/how-to/05...-stroke-ratio/
Old 03-10-2023, 01:43 PM   #31
Uplink
Uplink's Avatar
Good read, thanks!
Do we know for sure the kit does make it worse? They don't list the length of the rods so we can't do the math. All we know is stroke increases from 86mm to 90mm. According to the MT Article, there are ways of offsetting the ratio problem with longer rods/shorter pistons in a stroked engine. Maybe they did that to keep things closer in line.
[EDIT] They actually say in the spec sheet: "Specific connecting rods have been designed to suit the longer stroke." Seems like they might have addressed the issue.
Old 03-10-2023, 02:20 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Good read, thanks!
It's a long read, but the info is in here. I think our rod to stroke is like 1.2:1 or something. I can't remember.
https://www.ft86club.com/forums/showthread.php?t=63901
Old 03-10-2023, 03:41 PM   #33
Uplink
Uplink's Avatar
Yep, that's stock, 103.3mm rods / 86mm stroke. On the HKS spec sheet they are using a custom rod / 90mm stroke but they don't give the actual rod length so we can't figure out what the ratio is in the upgrade. If they're able to counter the math a little by going with a slightly (5mm) longer rod that would bring the ratio in line with stock and you'd be no worse off.
Old 03-13-2023, 11:32 AM   #34
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Unless they've moved the wrist pin at least 7.1 mm higher in the piston body (relative to the piston top), there's no way to match the stock rod to stroke ratio. You need a 4.8mm longer rod to match the ratio with the increased stroke, plus allowing for an additional 2mm of travel (half the stroke increase), plus about 0.3mm additional combustion chamber height (I.E. shorter piston height) to match the stock compression ratio.
It's not impossible, but it's unlikely there's that much room to raise the wrist pin / reduce piston height without compromising piston strength. Bear in mind that a 10:1 CR piston in an otherwise stock motor would have a piston height only about 2mm shorter than stock, so over 7mm difference is a LOT.
More likely the "specific connecting rods...designed to suit the longer stroke" are simply shorter than stock to maintain the piston height, making the rod to stroke ratio worse than stock.
EDIT: it does say on the spec sheet that the pistons are "shorter height", and they use a 1.5mm smaller connecting rod bolt size, so maybe they've been able to maintain near-stock rod to stroke ratio...again, it's not impossible.
That said, does a shorter rod to stroke ratio necessarily make a design "bad"? Not really.
It means it will be more biased toward low-end torque vs. high-revving power, and *may* be subject to a bit more wear over time due to the additional side-loading, but it doesn't make the motor an instant hand grenade...
Last edited by Tatsu333; 03-13-2023 at 11:39 AM. Reason: Added info from HKS spec sheet
Tatsu333 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tatsu333 For This Useful Post:
NoHaveMSG (03-13-2023), Uplink (03-13-2023)
Old 03-13-2023, 11:46 AM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe he had the measurements in the NA build thread for the HKS stroker and they did what they needed to make it fit, not improve the ratio. It's one of the reasons he did his own custom rod and piston kit, along with wanting more displacement.
Old 03-13-2023, 02:39 PM   #36
Tatsu333
Also worth noting, everything I've found says stock FA20 rods are 129.3mm long, giving a rod to stroke ratio of 1.50:1.
Old 03-13-2023, 04:08 PM   #37
wbradley
Sarcastic SOB
wbradley's Avatar
There was I guy here I am going to say he was from South Korea iirc, a few years ago that had a fully HKS stroked engine but also with reduced compression pistons and forced induction.
Old 03-13-2023, 05:16 PM   #38
RedReplicant
Drives: None
Someone on FB in New York is selling the low comp HKS 2.1 kit right now too. No idea how to link a FB post but it is in the group named FRS/BRZ/86 Marketplace.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
Uplink (03-13-2023), wbradley (03-14-2023)
Old 03-13-2023, 07:38 PM   #39
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, you are right, I am wrong on that. I dunno where I got 1.2:1 from.
Old 03-13-2023, 10:10 PM   #40
Uplink
Uplink's Avatar
They do some interesting things with the full S1-S3 engines for FI, like oil jets to help cool the pistons.
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
2015 FR-S Tech Specs Document - no engine upgrade 5AD86D Scion FR-S / Toyota 86 GT86 General Forum 83 04-26-2014 04:33 PM
Cam specs?? brn12345 Engine, Exhaust, Transmission 6 11-12-2012 05:04 PM
2 ENGINE VARIANTS: Old article leaked accurate info consistent with today's specs switchlanez Scion FR-S / Toyota 86 GT86 General Forum 8 04-17-2012 04:50 AM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
