Old 03-01-2023, 08:59 PM   #24095
Teseo
Drives: frs
How ironic the donut media ej tear down #3 gets posted today with some bent valves…
Go to Smeedia channel. He debunk those aficionados, ton of knowledge
Old 03-01-2023, 10:01 PM   #24096
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
oooof.
Well if you need a head I have a longblock sitting here I am not sure I am going to do anything with.
My true Subaru ownership process will be complete if I own three blocks at the same time right? Might hit you up next week.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
NoHaveMSG (03-01-2023), RToyo86 (03-02-2023), Tcoat (03-03-2023)
Old 03-01-2023, 10:17 PM   #24097
apex_gr
@apex_blue (IG)
apex_gr's Avatar
Drives: 2016 FR-S
I changed the air filter with an HKS one. Guarantee I got like 15 horsepower just like that and replaced the worn USDM door sill guards because they were all banged up with the JDM all plastic black ones. Too bad my old ones were cause I liked the metal lol.
apex_gr is offline   Reply With Quote
Old 03-02-2023, 09:06 AM   #24098
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A couple of years ago, my timing chain broke after #3 ingested something, then losing the intake rockers, which jammed and bent the cams, breaking the timing chain. No damage to piston and no bent valves. Go figure.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (03-02-2023), strat61caster (03-02-2023)
Old 03-02-2023, 12:23 PM   #24099
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol sounds about right
This longblock I have on a stand is my 3rd, I got it for free when I bought a transmission. It has a spun rod bearing from the J02 recall and I got it to rebuild the short block. Like I said, if it turns out you need anything shoot me a PM.
Old 03-02-2023, 06:19 PM   #24100
strat61caster
I watched their video:
“Subarus are extremely temperamental” -Smeedia
I only mentioned the Donut video because it was a similar failure, zero influence on how I’ve built my engine which is OEM spec with header and tune.
ineedyourdiddly
Teseo (03-02-2023)
Old 03-02-2023, 07:27 PM   #24101
Did someone say donut videos?
Jdmjunkie (03-02-2023), strat61caster (03-02-2023)
Old 03-03-2023, 04:21 PM   #24102
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Clean for 5 Minutes
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
DarkPira7e (03-06-2023), Overdrive (03-14-2023), Stephen W. (03-06-2023), The Red One (03-06-2023), Ultramaroon (03-03-2023)
Old 03-06-2023, 10:20 AM   #24103
Compelica
Compelica's Avatar
Drives: 86 GT
Did a 320km drive across hills and valleys before finally ending at a recreational park beside a river.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following 8 Users Say Thank You to Compelica For This Useful Post:
bcj (03-06-2023), DarkPira7e (03-06-2023), JD001 (03-06-2023), Myriad (03-13-2023), Overdrive (03-14-2023), soundman98 (03-06-2023), Stephen W. (03-06-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 01:28 PM   #24104
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Smeedia's knowledge is fairly shallow still, I would not take his word as gospel. Look back at his videos a couple years ago and you'll understand.
For someone who saying the engines are great, his content is punctuated by unintended failures and engine pulls on standard builds
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (03-06-2023), soundman98 (03-06-2023), strat61caster (03-09-2023)
Old 03-06-2023, 01:55 PM   #24105
Sasquachulator
Pavement Grey
Originally Posted by RToyo86 View Post
Clean for 5 Minutes
I just accept the natural matte dirt finish that nature provides.
I mean...its a free "wrap" so why not.
Old 03-06-2023, 02:53 PM   #24106
Teseo
Drives: frs
Better knowledge that donut guys thought
The Following User Says Thank You to Teseo For This Useful Post:
Old 03-06-2023, 04:56 PM   #24107
DarkPira7e
DarkPira7e's Avatar
Unequivocally, with Subaru engines
Teseo (03-06-2023)
Old 03-09-2023, 12:11 PM   #24108
strat61caster
They’re dead Jim
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
Clipdat (03-09-2023), DarkPira7e (03-09-2023), NoHaveMSG (03-09-2023), soundman98 (03-09-2023), Ultramaroon (03-09-2023)
