Old 03-06-2023, 08:54 AM   #15
nomtimesthree
Drives: GR86
Originally Posted by KillerBMotorsport View Post
Good question! We use an advanced TPV material that is far superior to the silicone pieces, and the overseas stuff. It's OEM level of material and should last 100K miles without issue.
Another thing to note, is that this style flapper valve (originally designed and used by BMW) was made for installation on vertical baffles. Never in a horizontal application. The aftermarket got a hold of it and right or wrong, put them on everything. If you look at horizontal installs, they sag open. Not only that, but because they sag open and are installed incorrectly on a horizontal surface, the heat causes them to take a set, in the open position. This can happen after only a couple of heat cycles, rendering the flap valves functionally useless. When used correctly on a vertical surface, they only open 1-2mm.
Love this kind of info and analysis sharing you bring to the community. As a prospective customer, it makes me want to support your product.
nomtimesthree is offline   Reply With Quote
The Following 2 Users Say Thank You to nomtimesthree For This Useful Post:
KillerBMotorsport (03-06-2023), Pat (03-06-2023)
Old 03-07-2023, 09:19 PM   #16
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Is there any chance a similar baffle can be made for the first gens? The FA20 game needs KillerB!
ballsdeep is offline   Reply With Quote
Old 03-08-2023, 08:46 AM   #17
BioRebel
Drives: Mini Cooper S
At this point, our experience with boxer engines: EJ, FA, and 911s. We have done more testing on these engines than anyone else in the industry. With that experience, we have a good understanding for where oil goes under various conditions. Although, that in no way means you skip testing I would bet $1,000 that this part will definitely not make things worse
Didn't mean to imply y'all don't know your stuff. But I would love to see a before/after video with some telemetry like we saw in the other thread. I know you might not be able to provide this now but I'd love to see it eventually.
BioRebel is offline   Reply With Quote
Old 03-14-2023, 03:10 AM   #18
bradsm87
Drives: It has 4 wheels
This somewhat explains why it takes so long for RTV sealant to dislodge and needs hard driving for some of the bits to dislodge. If oil is ending up in the front cover area, hard cornering transitions would likely dislodge excess sealant over time.
bradsm87 is offline   Reply With Quote
Old 03-14-2023, 06:47 AM   #19
KillerBMotorsport
KillerBMotorsport's Avatar
Great question, but I don't have an answer. We have never had a Gen 1 FA20 BRZ engine here for development. If anyone has one with the pan off, we can compare pics and see how close, or far off, they might be. Based on how Subaru makes changes over the years and the production methods, I would not be surprised if they were very similar, but I am totally speculating.
Same here. Data always rules the day
It's everywhere in the engine! Many assume addressing the lower pan section is a fix, but that is just a small percentage of where it's used. On our development engine you can see it oozing out of places on the inside and outside.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
DocWalt (03-15-2023)
Old 03-15-2023, 05:11 AM   #20
KillerBMotorsport
We've got a couple units available if anyone wants a Beta unit to try out. All it costs you is installing time. Shoot us a PM if you're interested in being a tester
Old 03-24-2023, 10:56 AM   #21
mike2100
mike2100's Avatar
Drives: 23 BRZ
What would beta testing consist of? Are you looking for cars that see track time? Thanks
mike2100 is offline   Reply With Quote
Old 05-04-2023, 09:35 AM   #22
brokenblinker
Drives: 2023 Neptune
Well, its over a month later. Any track data yet @KillerBMotorsport? I can hardly contain my excitement for this.
brokenblinker is offline   Reply With Quote
Old 05-23-2023, 11:32 PM   #23
gnarjunkie
Drives: '23 GR86, '17 BRZ
Bumpity bump @KillerBMotorsport
gnarjunkie is offline   Reply With Quote
Old 06-02-2023, 02:35 AM   #24
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Bumping this up for a new solution @KillerBMotorsport
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 06-26-2023, 04:09 PM   #25
900BRZ
Drives: 2022 Subaru BRZ
Hi, just wanted to share some preliminary testing I’ve been doing to set a baseline before installing the prototype baffle. I made a video documenting the testing setup and the results:
The summary is: I can consistently reproduce oil pressure drops on right-hand corners, many of which are significant enough to cause concern for bearing damage.
This is with low-grip GT Radial SX2 tires and minimal modifications. I’m running OEM coilovers, OEM ride height, and just have minor alignment changes on the front end from offset strut mounts and camber bolts. Rear end is entirely OEM. I’m also running a Jackson Racing oil cooler and Motul 8100 EFE 5W30 motor oil.
The prototype baffle is going on my car today and I’ll be at Thunderhill 5-Mile on July 1 to test the baffle.
900BRZ is offline   Reply With Quote
The Following 27 Users Say Thank You to 900BRZ For This Useful Post:
ACT86 (06-26-2023), Arthur-A (06-26-2023), Blighty (06-28-2023), Bonburner (06-29-2023), Compelica (06-28-2023), DarkSunrise (06-27-2023), drift86 (06-28-2023), Espi (06-27-2023), fredzy (06-27-2023), Frost (06-27-2023), gcmak (06-27-2023), Gearhead23 (06-26-2023), G_Ride (06-27-2023), Jdmjunkie (06-26-2023), justinco (06-26-2023), makinen (06-27-2023), MrSkubi (06-27-2023), Mr_Brian (06-26-2023), OldBiker (06-26-2023), Racecomp Engineering (06-27-2023), RacingredGR86 (06-26-2023), raisingAnarchy (06-26-2023), simpleisbest (06-26-2023), Sport-Tech (06-28-2023), vindiesel (06-26-2023), ZDan (06-29-2023), zeroomega (06-26-2023)
Old 06-26-2023, 05:03 PM   #26
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
This video needs stickied…I know a baffle would be cheaper then this. A remade oil pan and the deeper part centered with oil pick up tube? Or a deeper high capacity oil pan to insure no drop? Even if oil is getting trapped in other parts of the engine extra capacity would negate the pressure drop would it not? Or hell a pick up tube that has a bend center of the current oem oil pan?
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 06-26-2023, 05:41 PM   #27
raisingAnarchy
Drives: '20 Tundra, '84 SpecE30
This is a fantastic video, thank you for taking the time to put it together. Honestly, it's giving me pause on taking delivery of the GR86 I've been waiting for in a few weeks.
I was surprised to see such massive pressure drops even at less intense corners, like in your video around the 10:10 mark. It's showing around 0.9g through the right hander, yet that's still enough to lose 50% of oil pressure.
raisingAnarchy is offline   Reply With Quote
Old 06-26-2023, 06:36 PM   #28
900BRZ
Thank you! Yeah I think those are interesting ideas. May need a new header to install a deeper pan, but that is a possible route to go down. Similar idea to a slight overfill. Doesn’t solve the surging/sloshing, but may reduce the impact.
I have read about some modifications to pickups to remove bends (I believe this was in a forced induction FA20). They argued that the bend was causing cavitation and, thus, starvation. So in general I’m hesitant about bends unless they have significant testing, which seems lacking even in the factory FA24.
In theory this pressure drop could be a result of cavitation in the irregularly shaped FA24 pickup rather than lack of oil, but it’s hard to say without more research. At this point, I’m hoping that the prototype baffle works and I keep can tracking this car for years to come.
The Following User Says Thank You to 900BRZ For This Useful Post:
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 0 11-18-2022 05:15 PM
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 50 10-29-2022 07:36 AM
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 09:51 AM
FS: NEW Bluemoon Oil Baffle & Killer-B pick up tube. FRSH86 Engine, Exhaust, Bolt-Ons 2 04-20-2020 10:49 AM
Compatibility: Moroso Baffle and Killer Bee Oil sump Nightflo Engine, Exhaust, Transmission 3 04-27-2019 09:40 PM
