#225 |
Drives: 2013 BRZ Limited 6MT
Anyone have an installation tool for rent or sale?
#226 |
#227 |
Drives: WRB 14 BRZ
Just wanted everyone to know I had what sounded like an exhaust leak at start up but without an actual leak. 60k miles on the car and tracked the last 1000 of it. This was a 2014. I used a tool on Amazon that said it did Subaru and gm. Wasn't perfect and ruined one seal(bought 7 on purpose) but I got it all done and ran perfect afterwards. Have tracked it a couple times since then and all is good. I also reused the hard fuel line.
#228 | |
Drives: 2016 scion frs
#229 | |
Drives: 2014 Toyota FRS
I have #3 which tbh Im not looking forward to replacing EVERY injector as they are like $260 a piece.
#230 | |
FYI, as long as the numbers match, like for example, you have #3 DIs but if you replaced them all 4 injectors with #1s or #2s they will still work. i purchased a used set on ebay for about $100 and they were different numbers(3) than my original ones. (2s) |
#231 |
The Stig's African Cousin
Drives: 2014 wrb brz
Anyone know how to remove stuck Direct injectors? Mine did not pop off with the fuel rail they stayed in the block. Tried pulling them by hand but they're super tight and stuck really good. Any tools that can work like a sliding hammer that can attach to the injector?
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#232 | |
I didn’t end up doing the replacement but I’m thinking I should. |
#233 | |
You brought a set of used DI for $100 total?? That sounds like a crazy price. I wouldn't trust used DI's especially at that price.
#234 |
Yup. Well it works fine. Theyre in the motor and no issues.🤷*♂️ Like over 5k miles already. Also..you can get them checked and cleaned.
| The Following User Says Thank You to jrhudson For This Useful Post: | brandonblt2 (07-27-2022) |
#235 | |
waiting on yellow gas
Drives: 2017 BRZ Series.Yellow #247
"Straight roads are for fast cars, turns are for fast drivers" - Colin McRae
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| Direct Injector Failure Poll | track_warrior | Issues | Warranty | Recalls / TSB | 553 | 01-12-2017 06:12 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 09:31 AM |
