Old 03-03-2023, 01:39 AM   #5867
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by JDMChris View Post
It is not bad. A custom tune will net you barely any gains. If you had a issue with the CARB tune.... You installed something incorrectly, or had other modifications which the CARB tune does not support.
i do have the Carb tune in my computer and no i do not need it as i live in italy, having Tuned many of them and also people who had the Carb tune before, it is indeed not so good. maf scaling is off for the majority of cars, no engine load limiter at low load, cam timing thst have no sense and make abrupt swinga, too rich, timing too low, it just gives you a good "pull" in open loop, then when you drive at low speed low engine load, it drive shitty. Exactly like the OP stated
Also the things about custom tuning giving BARELY any gains is false, specially for stock Internal with stock compression, but if you are stating so it makes me think you have actully no real idea of what we are talking about
I feel sad for people forced those aproximative Carb tunes
Old 03-03-2023, 03:11 AM   #5868
PikachuBRZ
waiting on yellow gas
PikachuBRZ's Avatar
Drives: 2017 BRZ Series.Yellow #247
are these on 100% stock cars aside from the JRSC or cars with no cats and full exhausts? it makes a big difference
"Straight roads are for fast cars, turns are for fast drivers" - Colin McRae
PikachuBRZ is offline   Reply With Quote
Old 03-03-2023, 08:18 AM   #5869
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by Wingnutt View Post
Hello folks, I just joined forced induction fraternity and I have a question(s).
I opted for the JR C38 factory tuned kit, which of course comes with the ECUTEK and a tune for the System.
So while doing "spirited" driving the setup feels great, loving the extra power.
That said, during normal civilized driving I.E. low rpm (below 3000 or so) slow acceleration etc its a bit.. rough. when accelerating at partial throttle it is not smooth, i can only describe it as "lumpy" which I admit sounds kinda retarded, but you get the idea its just not a nice smooth pull.
Also at idle the rpm surges up and down from 500 to 1000 rpm and twice now (in 3 days) the car has just died while in neutral at a light.
Ive been around FI cars a while and I know the symptoms of a boost/vacuum leak but that doesn't seem to be the issue, and of course Ive checked. My guess is its the tune.
From what I understand then "factory" tune that is included is based on a car that is otherwise stock and the SC being the only mod. I have a fully cat-less setup, so Ive got more flow, so I think the factory tune is very likely sub optimal.
So, coming from openflash (when I was running NA E85) there were quite a few "off the shelf" tunes for different setups (header/exhaust etc) is there anything like that for this system or do I have to dole out more $$$ to get a custom tune, if that's the case what E-tune company do you guys like the most?
Thanks for any help and answers!
- Jason
I also have a c38 and while i cant speak for the factory tune because I'm small pulley, I will ask how long did you let it idle after you flashed it? Even after a 10 minute idle for the ecu to relearn everything I still has a weird idle and if i clutched in too fast at a stop the engine would die. Zach said shitty idle control makes a subaru a subaru. About 1/2 way thought the tank it stopped doing that and it is now a certified ripper.
But like others have said it might be your tune but I think id start with the easier and cheaper step of idle relearn first.
Old 03-03-2023, 12:14 PM   #5870
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Sure bud.
JDMChris is offline   Reply With Quote
Old 03-03-2023, 12:25 PM   #5871
tomm.brz
glad for you you know better, i guess you never have opened a carb tune made by Jackson, neither ve seen logs of it, but probably there is no need for you, your aknowledge is beyond that, sorry for bothering you then : )
Old 03-03-2023, 01:32 PM   #5872
Wingnutt
Drives: Pearl White 2014
Unhappy
I spoke with Chris at Jackson this morning and he confirmed that yes I do need a custom tune, that I can certainly drive around with the CARB tune but basically try to avoid high rpm and or WOT until I get a custom tune.
He told me to reach out to Zack at Counter space which I've been trying to do but when I call the only option is to leave a voice mail.
So it looks like I spent an extra $1000 for the ecutek and factory tune and I'm going to be out another $600 or so for a tune and an apparently another $100 or so for a map sensor ...
Wingnutt is offline   Reply With Quote
Old 03-03-2023, 02:15 PM   #5873
PulsarBeeerz
Drives: JRSC BRZ SOLD
Email them for support they are very punctual.
PulsarBeeerz is offline   Reply With Quote
Old 03-03-2023, 03:31 PM   #5874
PikachuBRZ
PikachuBRZ's Avatar
on the plus side you have all of the ecutek stuff already so that whole $1000 wasn't wasted. I just paid $1150 just for the ecutek and tune on an NA car
Old 03-03-2023, 11:38 PM   #5875
Wingnutt
Thumbs up
Counterspace couldn't seem to return my calls so I called delicious tuning and somebody actually answers the phone there so I went with them.
Nice folks.
I Ordered a map sensor and the JRSC tuning package from them.
Old 03-04-2023, 11:17 AM   #5876
PulsarBeeerz
Nice folks.
You'll be in good hands.
Old 03-06-2023, 03:01 PM   #5877
jflogerzi
jflogerzi's Avatar
Both are well known Tuners for FA20 motors.
2013 Series 10 FRS #553
Old 03-08-2023, 03:31 PM   #5878
CSG Mike
CSG Mike's Avatar
I bet he has.
Old 03-08-2023, 03:38 PM   #5879
CSG Mike
CSG Mike's Avatar
Nice folks.
E-mail is always preferred (per the recorded message you heard when you called), as it allows for more punctual service.
While some folks prefer to chat on the phone, a lot of information gets lost in translation, or forgotten. An e-mail exchange is a great reference when you need to go back for more information.
Also, CSG prioritizes servicing customers who have already paid for services/goods, before taking money from new clients when existing clients are still waiting. Apologies if nobody got back to you in a timely manner, voicemails are lowest on the totem pole and are only addressed when all e-mail inquiries are replied to.
Old 03-16-2023, 04:25 PM   #5880
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
car going to the dyno next week, we got jrsc high boost pulley, walbro 450 pump, id1050x injectors, delicious flex fuel kit, and a 4 bar map sensor.
excited to see what kind of numbers the car makes!
Ignore Your Doctor is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
