Old 07-08-2022, 09:03 PM   #15
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by 949 Racing View Post
Shop video with some extra info about Xidas. Let us know if you have any questions!
Nice to see at 1:57 in the video that you explain that the bottom bracket adjustment is intended to fine-tune the extents of the suspension movement, not "tHiS iS HoW yOu AdJuSt RiDe HeIgHt" like frequently recommended elsewhere.
Follow the build thread for my GR86!
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
DocWalt (11-08-2022), Racecomp Engineering (07-09-2022), Ultramaroon (03-01-2023)
Old 07-08-2022, 09:18 PM   #16
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Thanks. The difference here is that most folks talking about ride height adjustment there are talking about a 2 piece shock that has a hollow adapter (bottom bracket) at the bottom. The actual strut cartridge in those stops well short of the strut flange.
So with 2 piece shocks that are intrinsically too short, the owner needs to decide if they want to compromise bump or droop travel, because they can't have both. Thus the "adjust ride height here" narrative. It gets confusing, that's one reason we made the video. To highlight the benefits of our configuration. Watch the 2 piece video linked in the description to see more on that subject.
Xidas are a 1 piece full length shock with a clamp on strut flange. In our case, the shock actually extends well below the strut flange. Different beastie
949 Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to 949 Racing For This Useful Post:
timurrrr (07-11-2022), wparsons (02-22-2023)
Old 07-08-2022, 09:21 PM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yup, totally noticed that!
Old 11-01-2022, 08:12 PM   #18
949 Racing
949 Racing's Avatar
Kits from the next batch on sale. They'll be here early December
front and rear coaxial mounts & camber plates also on sale
https://949racing.com/product/xida-c...-frs-brz-gt86/
Old 02-14-2023, 02:29 PM   #19
949 Racing
949 Racing's Avatar
Next batch due here first week April 2023. Taking pre-orders now.
The Following User Says Thank You to 949 Racing For This Useful Post:
RedReplicant (02-14-2023)
Old 02-26-2023, 02:45 PM   #20
RedReplicant
Drives: None
Didn't see it listed on the 949 site, but do these take the >=40mm shaft diameter hit for NASA ST/TT5?
https://nasa-assets.s3.amazonaws.com..._5-6_Rules.pdf
Page 14, 6.1.9 point 7
RedReplicant is offline   Reply With Quote
Old 02-26-2023, 05:22 PM   #21
949 Racing
949 Racing's Avatar
The 86 Xida inverted strut is 43mm shaft diameter
RedReplicant (02-26-2023)
Old 02-26-2023, 06:57 PM   #22
RedReplicant
Drives: None
The 86 Xida inverted strut is 43mm diameter
I was afraid of that Thank you
edit: wait, strut diameter is 43mm but what is the shaft diameter inside the body? Sounds like it might be legal... if so...
Old 02-26-2023, 08:15 PM   #23
949 Racing
949 Racing's Avatar
43mm is shaft diameter.
Strut casing is 55mm.
Who or what is this NASA rule intended to penalize?
Old 02-26-2023, 08:19 PM   #24
RedReplicant
Drives: None
Seems like it is some rule that has stuck around since the letter classing days, I am not sure who angered the powers that be to set it in motion. What a pain.
Old 02-26-2023, 08:31 PM   #25
949 Racing
949 Racing's Avatar
Yah. For some platforms, everything is inverted. For other platforms, there is nothing available that's inverted. Dumb.
We're not going to downgrade Xidas to avoid the hit though. Ironically, the original single adjustable Xidas for the NA/NB Miata were built to get around the NASA rules penalizing reservoirs and multiple adjustments. But switching to a standard small shaft strut is just too much of a functional compromise for everyone else not running NASA.
Old 02-26-2023, 08:48 PM   #26
RedReplicant
Drives: None
We're not going to downgrade Xidas to avoid the hit though. Ironically, the original single adjustable Xidas for the NA/NB Miata were built to get around the NASA rules penalizing reservoirs and multiple adjustments. But switching to a standard small shaft strut is just too much an functional compromise for everyone else not running NASA.
Yeah, can't blame you in the slightest there. I was really happy with the Xidas on my NB Maybe when I get a wild hair up my ass to add power and play in 4 again.
The Following User Says Thank You to RedReplicant For This Useful Post:
villainous_frx (02-27-2023)
Old 02-28-2023, 07:03 AM   #27
nomtimesthree
Drives: GR86
GR with Xida on Touring Springs (250/250). This is about 140mm ride height. Most cars will be able to get down to about 130mm on Touring and 120-125 on 500/500 or 600/600 Race.
Wheels are 17x9 +48 Gen 4 6UL. We stopped making these wheels in 2017 and they are sold out. Working on Gen 5 wheels for early next year.
How close is this to stock ride height? Can these go to stock ride height?
How is clearance with the 17x9 +48 and 245/255 40 tire? Thanks!
nomtimesthree is offline   Reply With Quote
Old 02-28-2023, 07:29 AM   #28
marco_mc22
Drives: Toyota 86
For reference, stock ride height for 2017+ cars with showa base dampers is 155-160, PP Sachs is 150-155.
Older cars should be a little higher but I’m not sure.
marco_mc22 is offline   Reply With Quote
alignment, blub, tractive, xida
949 Racing Xida coilovers GT86/GR86 949 Racing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 126 05-16-2022 06:25 PM
BC Racing Coilovers, Tax Season Specials! WE stock BC Racing @OAKOS! OAKOS Automotive Brakes, Suspension, Chassis 162 04-17-2017 03:14 PM
*** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** Sonic Motor Brakes, Suspension, Chassis 489 07-29-2016 02:15 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
