Old 02-17-2023, 02:27 PM   #225
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Tatsu333 View Post
Thanks for finding / posting that!
So from reading the article alongside the other photos there, it looks like a full FA24 motor swap using the 17-20 ECU and a number of wiring / sensor changes in the engine compartment to make that work.
I think it was @geraldjust that pointed out that the crank position sensor and reluctor wheel are the same type as the 17+ cars. So a full swap doesn't look like too much work for those years. It looks like cam positioning also plays nice with the 17+ car.
Old 02-17-2023, 04:19 PM   #226
Tatsu333
Drives: 2020 BRZ Sport Tech RS
The article does say that they initially got it running "by replacing and re-pulling the crank angle sensor wiring and several harnesses", but not much more detail than that.
Tatsu333 is offline   Reply With Quote
Old 02-17-2023, 06:07 PM   #227
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's hard to say for sure what they did. The translation loses some things. They may have just had to swap plugs or something for the sensors.
I guess I shouldn't say easy either, less hard would be more appropriate.
Old 02-17-2023, 10:56 PM   #228
Teseo
Drives: frs
Maybe wait until some company like Haltech do a wire/sensor adapter so it can be plug n play
Old 02-17-2023, 11:00 PM   #229
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think Haltech, but somebody will no doubt make a kit. It's going to be a bit more difficult on the pre facelift cars.
Old 02-18-2023, 03:53 AM   #230
makinen
makinen's Avatar
Drives: Toyota 86
Because they started from the Zenki 86, they have to replace some harnesses and sensors. If started from the Kouki, those are not hurdles.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 02-18-2023, 03:51 PM   #231
Tatsu333
A few parts of the article suggest that they had already swapped to a Kouki engine and ECU:
"After successful start of the late model engine in the first half..."
"...the ZN6 of the first period can be started with a late model engine..."
"From the start of the late model the other day, we succeeded in starting the FA24 by replacing and re-pulling the crank angle sensor wiring and several harnesses."
It appears from that info (and another post a couple before that one in the site's journal confirms it) that they had already done the work of swapping to a Kouki motor and ECU, so maybe some further changes were needed.
Old 02-19-2023, 10:08 AM   #232
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Might be a bit of a dumb question, but how much hp can one extract from a well-tuned FA20 (headers, intake, possibly cams, E85, etc.)?
My mechanic (who works almost exclusively on 86s) claims to have seen as much as 250hp from an NA FA20, with what I'd expect to be a much lower budget than a complete FA24 swap. Makes one wonder whether those extra 14hp are worth the money, although other variables like torque and further modding potential have to be taken into consideration.
alex87f is offline   Reply With Quote
Old 02-19-2023, 11:19 AM   #233
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My mechanic (who works almost exclusively on 86s) claims to have seen as much as 250hp from an NA FA20, with what I'd expect to be a much lower budget than an a complete FA24 swap. Makes one wonder whether those extra 14hp are worth the money, although other variables like torque and further modding potential have to be taken into consideration.
Wheel HP or crank HP?
The most I have ever seen on a dyno with a baseline is like 212whp. With no baseline the final number is always going to be suspect. Could have been making 238 stock and 250 modded. So when you look at the delta, not that impressive, even though the final number is big. Guys with low boost FI kits are only making 250-260.
Old 02-19-2023, 01:09 PM   #234
alex87f
Meow
alex87f's Avatar
Was thinking crank hp, based on around 195 stock crank hp so about +45whp.
Any idea of the weight difference between FA24 & 20? I'd guess it's negligible.
Old 02-19-2023, 07:14 PM   #235
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah 250 crank isn’t an unrealistic number. 212/250=.848. So 15ish% drivetrain loss is realistic in that scenario.
Old 05-23-2023, 01:50 AM   #236
tomm.brz
Drives: brz 2017 hksv2
Still i m not understanding how doable is this swap, fa24 short block into restyling fa20 with fa20 heads?
Did someone here figure out what s really needed?
Old 12-15-2023, 12:50 PM   #237
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Reviving this thread, it looks like there are a few shops in the US that either have it working or are working on it. I know of at least one that's offering the swap, which involves an FA24 short block and FA20 heads, but that's the extent of my information.
kmbkk is offline   Reply With Quote
Old 12-19-2023, 02:24 AM   #238
Four_wheel_drifts
Drives: Whiteout track car; lava donor
No one willing to talk about the fa24 spinning bearings at lower mileages than the fa20?
It would suck to replace a spun bearing 1st gen with a new second gen then pop the hybrid on your first track day.
Four_wheel_drifts is offline   Reply With Quote
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
