Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-29-2023, 11:22 AM   #57
DarkSunrise
DarkSunrise's Avatar
Short term, mild mods for a street/canyon/track build. Double camber bolts, wheels/tires, quiet CBE, and pads/fluid. Most of these are done. Might add an e85 tune and hopefully pick up 15-20 whp with the oem cats in place.
Long term, we’ll see. If I start tracking regularly again, I’ll add my old track mods from my 1st gen. RCE T2 coilovers, wilwood BBK, and an aggressive alignment. Stickier tires. Any proven oiling mods.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Racecomp Engineering (02-13-2023)
Old 02-06-2023, 04:16 PM   #58
Jakuzure
Drives: 2023 SUBARU BRZ
Short term: Floorliners, winter tires and wheels, dash cam, etc
Long term: front bumper swap after the mid cycle facelift drops, new wheels once the stocks wear out, maybe some kind of lift
Jakuzure is offline   Reply With Quote
Old 02-13-2023, 01:42 PM   #59
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by ballsdeep View Post
BRZ Dual Air Oil Separator to be Released soon...
that's great news, will your offering be available by July??
Not sure how I missed this, but they were released a while back
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
ballsdeep (02-21-2023)
Old 02-14-2023, 11:55 AM   #60
Snoopysvet
Snoopysvet's Avatar
Drives: 2023 Wr Blue Pearl BRZ manual
Keeping it stock
2023 BRZ
Snoopysvet is offline   Reply With Quote
The Following User Says Thank You to Snoopysvet For This Useful Post:
vindiesel (02-19-2023)
Old 02-14-2023, 12:09 PM   #61
Pat
Pat's Avatar
Drives: 2023 BRZ
In order:
Android Auto Bluetooth adapter
Hood struts
Fire extinguisher
Remove carbon intake filter
Mount wheels and 10 mm spacers in front with CSG nuts. Ensure no rubbing on the rear fenders. Might have to use OEM wheels until camber gained through lowering.
Overlays
Detail and ceramic coat
Tint and PPF
Dash cam
Trunk handle
AOS
Order Pilot Sport 5 tires from Next when I have 8” wheels. The Michelin Pilot Sport 5 will be available in 50 dimensions spanning in sizes from 17 to 21 inches when it becomes available worldwide on March 1, 2022. Goodyear Eagle F1 Asymmetric 6 is just as good all around, and a little quieter.
Garmin Catalyst mount (research more)
Nixspeed for
Wheel studs
Spacers
BBK with pads and fluid
Coilovers
Front sway bar end links
Oil cooler
Horn
Throttle pedal spacer
Perrin steering rack lockdown when changing transmission fluid and engine oil
Fumoto valve
Differential cover when changing fluid
The Following User Says Thank You to Pat For This Useful Post:
RaceAddict (06-25-2023)
Old 02-14-2023, 12:15 PM   #62
BioRebel
Drives: Mini Cooper S
You installed this yet? Curious to know how it feels on the BRZ.
BioRebel is offline   Reply With Quote
Old 02-14-2023, 01:20 PM   #63
Pat
Pat's Avatar
Drives: 2023 BRZ
I had it on my first gen car only. I could barely feel a difference after 100,000 miles on the original bushings. I took it off the first car and figured since I still have it I'd put in on my new one. If I didn't already have it I probably wouldn't buy it.
BioRebel (02-14-2023)
Which path to take o.O Goz Scion FR-S / Toyota 86 GT86 General Forum 22 03-06-2015 06:37 AM
Need help deciding which path to take for suspension... Lemar58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 05-08-2014 01:06 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 07:08 PM
Upgrade path for Autocross mechaghost Tracking / Autocross / HPDE / Drifting 7 07-30-2012 12:49 PM
