Old 04-26-2021, 11:06 AM   #3907
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
My co-driver and I used the Kumho tires again yesterday. The afternoon runs were in 57 F weather, full sun, on asphalt.
The tires work better when warm, but the Yokohama tires were still the faster tire. The feel of the Kumho tires was less "peaky" and we could get good and controlled rotation, but not as slidey as BFGs.
Sent from my SM-G973U using Tapatalk
sifl is offline   Reply With Quote
Old 05-21-2021, 10:42 PM   #3908
Harlock
Drives: 2017 BRZ
Hi all, I just wanted to check if my understanding of rule 14.8.h.2 is correct, 'On arm-and-strut (MacPherson/Chapman) suspensions, the lower arms may be modified/replaced OR other methods of camber adjust-ment as allowed by Sections 14.8.B, C, or F may be used, but NOT both.'
Does this mean I cannot have both camber plates & adjustable LCAs on the front?
Harlock is offline   Reply With Quote
Old 05-21-2021, 11:30 PM   #3909
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Correct.
You can do 14.8 B+C+F however with an adjustable offset camber bushing in the lca depending on what you mean by 'adjustable' but if you're looking at the Cusco or racer x or spl front lca then no, you'd have to ditch camber plates for those to be legal. Aside from the problem of them being spherical.
ineedyourdiddly
Old 07-15-2021, 11:05 AM   #3910
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Are lightweight crank pulleys allowed in STX? Need to replace my serpentine belt and thought I'd go ahead and do that too if it's allowed.
smg1138 is offline   Reply With Quote
Old 07-15-2021, 07:01 PM   #3911
M0nk3y
Yes, it is.
However, I don’t ever recommend it. Not balanced and juice isn’t worth the squeeze of the inevitable engine damage it’s going to do.
Kyle H. - #89 STX
Old 07-16-2021, 03:08 PM   #3912
smg1138
smg1138's Avatar
Oh ok guess I'll stick with the stock unit. Is the OEM serpentine belt the best way to go? I know there are poly belts, but have never tried one before.
Old 02-12-2023, 02:27 PM   #3913
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
For a dual purpose autocross/daily driver what toe settings are you running?
Sent from my SM-G986U using Tapatalk
kraftyone is offline   Reply With Quote
Old 02-12-2023, 07:08 PM   #3914
strat61caster
F -1/16”
R +1/8”
I’ve done +/-1/16 front, no big difference, zero is fine.
Rear I don’t like zero, wanders too much on the freeway, I like a sixteenth in, got a little more right now to try and give my codriver confidence.
ineedyourdiddly
Old 07-18-2023, 04:16 AM   #3915
dsp979
Drives: 2020 Halo 86 TRD
Just reg'd for my first event with the 86 at Crows Landing under DSP.
Car has from dealer (TRD Handling package):
Brembos, 18-inch wheels, Sachs dampers, underbody aero panels
I've since added:
TRD lowering springs, sway bars, front carbon fiber strut bar, aero stabilizing cover and rear lip spoiler.
Can't wait to try it out. Won't be as fast as the new GR86, but i'm just out to have fun. My last autox was Dec. 2017 with a knocking KA24E in my 240SX.
71, 72 Celica STs
85 "AE88" hatch, 89 S13 SE hatch (DD, autox car), 2020 86 TRD
dsp979 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
