Old 12-16-2022, 07:54 AM   #225
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Joveen View Post
Wow. The build took off last we spoke. Built block and all sheesh
Sent from my SM-F936U using Tapatalk
You've been focused on more important things! Hoping everything is still going well for you and your girl
Old 12-19-2022, 12:21 AM   #226
Joveen
Joveen's Avatar
Drives: Bone stock
We have 6 months to go before the wedding day. I'm deciding on keeping the car so I grab parts when I have "fun" money available.
Joveen is offline   Reply With Quote
Old 01-08-2023, 09:40 PM   #227
DarkPira7e
DarkPira7e's Avatar
Got the intercooler on! MAF deleted w/ GM IAT. Had to re-weld the top pipe so it hasn't been cleaned up or smoothed out.
Need to work on the fueling map, boost comes on MUCH harder than before. Extremely happy so far!
Old 01-10-2023, 02:57 PM   #228
DarkPira7e
DarkPira7e's Avatar
Spent most of today tuning the VE table, no MAF to blend automatically reveals a lot of underlying issues with fueling! Mostly good now, drove the car for hours around town and on the interstate. Love this thing!!! Can't wait for warmer weather so I don't just light the tires up in ever gear. Onset of boost spins 4th at 55mph easily
Old 01-29-2023, 10:34 AM   #229
DarkPira7e
DarkPira7e's Avatar
New 3" front pipe and over pipe from JDL! Current setup is 2.5" and it's a harsh change right at where the wastegate merges into the downpipe.
Old 01-30-2023, 07:02 AM   #230
KillerBMotorsport
KillerBMotorsport's Avatar
Have you considered going with a better IAT sensor? We ditched the old-style GM sensors years ago because the response rates are horrible compared to something more modern. T1 makes some nice fast response IAT sensors that work exceptionally well.
KillerBMotorsport is offline   Reply With Quote
Old 01-30-2023, 10:29 AM   #231
DarkPira7e
DarkPira7e's Avatar
I hadn't, I went with GM because it's familiar and I was able to get an adapter to connect to my OEM MAF harness. I'll definitely keep this in mind if I need something snappier. Does the T1 use the same pinout and connector? Thanks for the info!
Old 01-30-2023, 12:24 PM   #232
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
She needs a wash, that I'd be more than happy to work on it haha!
spcmafia is offline   Reply With Quote
Old 01-30-2023, 01:21 PM   #233
KillerBMotorsport
A tech that is no longer with us did the install. I can ask the next time I run into him, but it couldn't have been that eventful, no issues about installing it comes to mind.
It gives much better feedback than that mid-80s GM sensor. I highly recommend it for high RPM boosted applications.
Old 01-30-2023, 01:54 PM   #234
DarkPira7e
DarkPira7e's Avatar
This is pretty clean for me, hahaha
Do you really think the faster response is necessary for IAT? I understand the appeal but as long as I'm under a certain range, I wouldn't think polling speed is something to be too concerned with (unless running something like water meth ). Thanks again for the input!!
Old 01-30-2023, 03:03 PM   #235
KillerBMotorsport
IMO, yes. Why use a sensor design that is 35+ years old on a car that has a much faster and more powerful ECU. If your temps are spiking and you don't know it, it can be problematic. Maybe not the first time, or 100th time, but the more precise feedback you have from the engine, the more accurate the tuning tables will be, which equates to more power and long-term engine safety.
The bigger question is why wouldn't you want a sensor that has a much better response rate?
Old 01-30-2023, 03:21 PM   #236
spcmafia
spcmafia's Avatar
*Need to detail intensifies*
Old 02-08-2023, 10:48 PM   #237
Joveen
Joveen's Avatar
Drives: Bone stock
How does the new exhaust sound
Sent from my SM-F936U1 using Tapatalk
Old 02-09-2023, 08:50 AM   #238
DarkPira7e
DarkPira7e's Avatar
Haven't gotten to move the car yet, we had a foot or two of snow drop and temps as low as -20f. Soon hopefully I'll have everything cleared so it can roam freely! I suspect it's just going to be a little deeper, the cat should flow very well so I doubt resonance or volume will be impacted much
brz, frs, iag, jdl, turbo
Joel's BRZ - Low Budget Time Attack Build DIY Member's Car Journals 403 11-19-2024 07:39 PM
Cxracing turbo problem Kalebhall Forced Induction 10 11-16-2017 07:57 AM
Tony's Budget Turbo Build glorydays Member's Car Journals 22 01-25-2015 11:02 PM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 09:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 08:44 AM
