Old 02-07-2023, 11:29 PM   #4327
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by cjd View Post
Do you need the 5.25 drive bays? Airflow is probably ok but can do much better for the price, just no bays.
i'm old fashioned. i still like to run a dvd-r/w drive. and my current setup has a 5.25 fan controller panel i'd likely integrate into the newer build as well, though the bios fan control is supposed to be much better than the old x58 sabertooth board i'm running now.
x808drifter (02-09-2023)
Old 02-08-2023, 08:42 AM   #4328
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
How often do you use the DVD drive? If it's less often than once a month you might want to consider an external drive instead.
Also: "Build Thread"
soundman98 (02-08-2023), x808drifter (02-09-2023)
Old 02-08-2023, 09:47 AM   #4329
cjd
cjd's Avatar
Drives: 2017 BRZ
I'll second the external drive for a better case. Also yes... If you have pwm fans in particular, bios or software control is so much better. I've set fan curves and they are silent most times, ramp up when in use. I had to get past the drive thing myself... I've used it 10 times in 2+ years. Already had the external for laptops. Same issue for me with sd?cf cards when I take photos. External is slightly less convenient. No regrets.
That said... I understand.
The Following User Says Thank You to cjd For This Useful Post:
Old 02-08-2023, 08:49 PM   #4330
soundman98
soundman98's Avatar
lol, i use that computer less than once a month!
oddly, newegg's cheapest windows 11 OS was on a dvd. last time i was able to get 10 on a flash drive, but didn't even see that as an option anymore.
Old 02-08-2023, 10:49 PM   #4331
cjd
cjd's Avatar
Drives: 2017 BRZ
You create your own flash drive these days. Download direct.
If you're done with the old computer you may be able to just "upgrade hardware" on the old license.
Old 02-08-2023, 11:55 PM   #4332
soundman98
soundman98's Avatar
the old 'license' has been used on 4-6 other pc's, i've lost track. i got my monies worth out of it!
cjd (02-09-2023)
Old 02-09-2023, 12:52 AM   #4333
alphasaur
friendly
Drives: 17' 86
started playing with newegg's pc builder app. nice setup, it eliminates some of the options that don't work so there's less scrolling
but $2k...
https://newegg.io/f5d0b4f
I would seriously consider a 6800xt over that 3060ti for the same price, a 3060ti for $540 is a huge stretch in terms of value. You can find 3060ti's all day in the $450 range, IMO spending $540 on one would put you in a completely different tier of performance (go 6800xt if you don't care about raytracing or 3070ti).
Also why not 13600 vs the 12700? It's the better CPU across the board
https://www.techpowerup.com/review/i...ore-i5-13600k/
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 02-09-2023, 03:38 AM   #4334
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by gav_abr View Post
It looks pretty good, but for some reason I've always had a completely irrational hatred of anything Harry Potter related.
I disliked it before that was the cool thing to do.
I hated it till people started dying on the regular.
"How long does an owl live?
About 6 books."
God my sister wanted to kill me for that joke.
The Following 4 Users Say Thank You to x808drifter For This Useful Post:
bcj (02-09-2023), Dadhawk (02-09-2023), soundman98 (02-09-2023), Spuds (02-09-2023)
Old 02-09-2023, 06:52 PM   #4335
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Picked up the Asus ROG Zephyrus 14 for a really good deal! I got it not because I need a gaming laptop, per se, but because I also need a computer for work. We were supposed to be issued laptops well over a year ago, but the people who are in charge are too lazy. So I figured, if I'm going to get a laptop, why not get something I can do work and game with! The specs also seem pretty damn good too. Ryzen 7 and a 3060 means I can enjoy many of the games I typically play. But I also don't plan do really play that many anyway.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 02-09-2023, 09:00 PM   #4336
soundman98
soundman98's Avatar
definitely some improvements i could make. i'm was mostly playing. i didn't research anything, just spec-sheet-raced to an end result.
i'm still attached to the stigma that any i7 is a better processor than any i5..
Old 02-09-2023, 09:18 PM   #4337
Spuds
The Dictater
Spuds's Avatar
Top of the line i5s have, for the most part, been the Intel sweet spot for gaming. Less expensive in both dollars and watts than the i7 or i9, yet fast enough that your typical game limitation is always going to be graphics. Removing the overhead of the extra cores lets you overclock with less, and therefore more stable, total power if you feel the need for more speed.
Basically, in order to get the most out of the i9s for example, you have to also buy a really expensive motherboard and a bigger power supply. It's great if you are a numbers junkie, but it doesn't really improve the experience unless you have specific processor-intensive work.
soundman98 (02-09-2023), x808drifter (02-10-2023)
Old 02-09-2023, 10:28 PM   #4338
soundman98
soundman98's Avatar
i've never really messed with overclocking, i create enough problems just the way the hardware comes.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Captain Snooze (02-17-2023), Spuds (02-10-2023)
Old 02-10-2023, 12:45 AM   #4339
alphasaur
friendly
Drives: 17' 86
Would usually hold true but 13XX is a pretty massive improvement over prior gens so the i5 takes the win
The Following User Says Thank You to alphasaur For This Useful Post:
soundman98 (02-10-2023)
Old 02-15-2023, 07:55 AM   #4340
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
20+ Hours into Hogwarts Legacy.
Game is very vast. To the point where you forget there is main quest, and all you want is just explore. I've read that there's people with lower VRAM allocation that are having issues, which is not the case if you have, say, an AMD GPU. I can only assume an update will show up at some point.
The only bug that I have encountered is that the robe can go stiff and look all weird, but that is it. Only has happened once.
You can explore as much as you want, but, gotta remember, you're in school, so you need to attend classes to learn more spells that will unlock more places and abilities.
Might take me a while to 100% this game. But so far I highly recommend it.
spcmafia is online now   Reply With Quote
The Following 3 Users Say Thank You to spcmafia For This Useful Post:
Jdmjunkie (02-15-2023), Spuds (02-15-2023), Wally86 (02-16-2023)
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 04:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 06:37 PM
