Old 02-06-2023, 10:42 PM   #1
jrhudson
Drives: 2016 scion frs
P0455 - Large evap leak
Hello,
IAG stage 1 built motor.
Jdl turbo
I have been dealing with a P0455. I havent smelled any fuel and did open up the fuel pump area to check for leaks but i havent seen or smelled anything. Ive checked if my fuel cap was loose, it wasn’t. My fuel pump lock ring is tight and at the old marked blue lines. I’ve ordered a new fuel pump assembly gasket and fuel cap to replace these old ones. I pulled off the intake manifold to check on thse hoses and is all clamped up and no punctures. i think im leaking fuel somewhere because ive taken it to work for a week and fuel mileage is terrible. Half a tank of gas would get me about 90-100 miles and thats mostly cruising on the highway.
Anyone dealt with this before?
jrhudson is offline   Reply With Quote
Old 02-06-2023, 10:50 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Are you sure it's not because they are using the evap solenoid for your ebcs? They are supposed to disable the code. fuel mileage might be terrible because of tuning if it's still a work in progress / you're ripping on it more. With larger injectors, any time you're not at 1 lambda it's going to be straight up dumping fuel. Could definitely be something with the fuel system though. I would park over cardboard for a while
Also, check the evap solenoid under the intake manifold, those certainly need to be clamped if you've got boost. Old threads seem to find resolution by re-seating the in cabin gas tank cover, even if you've checked that, maybe give it another once-over?
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
jrhudson (02-06-2023), x808drifter (02-09-2023)
Old 02-06-2023, 11:28 PM   #3
jrhudson
My tuner has already disabled the EVAP codes. I haven't been going into boost at all when i brought it to work. Highway cruising only. i know fuel mileage is going to be bad, but I feel like I shouldn't be using that much fuel just cruising on the highway.
Yea, the intake manifold is off right now and all hoses are clamped down and no punctures to them. Yea, the plan was to check the fuel assembly today but it got late so ill do that tomorrow. I'll pull the whole pump assembly out, maybe I'll find something amiss.
good idea on the cardboard.
The Following 2 Users Say Thank You to jrhudson For This Useful Post:
DarkPira7e (02-07-2023), x808drifter (02-09-2023)
Old 02-07-2023, 07:58 AM   #4
Grady
Grady's Avatar
If you are leaking enough fuel to affect fuel milage you will see the leak.
Obviously your evap codes are not disabled.
Really can not narrow it down but ether something was not put back together right or shitty tune. You are probably not looking for a disconnected line but a couple of lines that are crossed.
The Following 4 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (02-07-2023), jrhudson (02-09-2023), Tcoat (02-07-2023), x808drifter (02-09-2023)
Old 02-09-2023, 11:57 AM   #5
jrhudson
I think the evap codes that were disabled were the disconnect ones to do with the ebcs p0451/p0453 not the ones that detect leaks.
I havent been able to check the fuel pump yet, ill do that later this weekend but when i was under the car i saw a dried stain on the fuel tank looked like it was coming from the fuel pump area. I already ordered a new fuel pump gasket just in case if its needs more than a readjustment.
Old 02-09-2023, 09:49 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
What the actual fuk
What's the point of disabling EVAP component circuit codes and leaving the leak detection running? If you've got disconnected components and the DTCs don't set to disable leak monitoring, the leak detection can't run/will fail.
DUH!
Old 02-20-2023, 08:59 PM   #7
jrhudson
Originally Posted by RZNT4R View Post
What the actual fuk
DUH!
Hmm i guess youre wrong
Well, the point of that is since the EVAP canister was leaking…it detected the leak. Replaced that and its been 6-10 drive cycles now with 2 refuels, no more codes
Not everyone is a professional mechanic so no need to assume everyone just knows the same info you got. cheers
Old 02-21-2023, 09:33 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by jrhudson View Post
Not everyone knows how a car works or uses common sense so no need to assume everyone just knows the same info you got. cheers
FTFY
Old 02-21-2023, 12:39 PM   #9
jrhudson
Originally Posted by x808drifter View Post
FTFY
an attempt to feel smart it looks like here. lol
The Following User Says Thank You to jrhudson For This Useful Post:
fableluke (02-21-2023)
Old 02-21-2023, 01:51 PM   #10
Not sure what is funnier here.
The fact that money was wasted on a fuel pump before any diagnosis was completed or OP shitting on the people that were trying to help him in spite of his lack of information or understanding.
Guess they are both funny in their own way.
Grady (02-22-2023), Wally86 (02-22-2023), x808drifter (02-24-2023)
Old 02-21-2023, 04:38 PM   #11
Or sad.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Grady (02-22-2023), Tcoat (02-22-2023), Wally86 (02-22-2023), x808drifter (02-24-2023)
Old 02-24-2023, 02:54 AM   #12
x808drifter
LMGTFY
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (02-24-2023)
P0455 & P0456 keeps returning Toyarzee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2018 11:04 PM
P0455/P0456 - Will go into limp mode Kojiro Issues | Warranty | Recalls / TSB 23 02-22-2018 10:58 AM
P0455 MonoRaven Issues | Warranty | Recalls / TSB 5 12-07-2016 11:57 PM
P0455 EVAP Code after New Direct and Port Injectors Installed? (Vortech Supercharger) Figo Forced Induction 8 10-04-2016 01:40 PM
EVAP Solenoid Ryan P Forced Induction 0 06-25-2014 08:43 AM
