Old 01-30-2023, 09:57 AM   #15
AutoCulture
AutoCulture's Avatar
Drives: Toyota GT86 (ZN6)
Originally Posted by Ernest72 View Post
It’s a cosmetic mod, why spend the money.
We shouldn't spend money on a cosmetic mod? What?
AutoCulture is offline   Reply With Quote
The Following User Says Thank You to AutoCulture For This Useful Post:
finch1750 (01-30-2023)
Old 01-30-2023, 10:51 AM   #16
Sasquachulator
Pavement Grey
you can...
but he probably means it isn't worth the trouble to even do.
especially if all you want out of it is just a nicer looking intake manifold
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
Ernest72 (02-05-2023), x808drifter (01-31-2023)
Old 01-30-2023, 07:14 PM   #17
Grady
Grady's Avatar
I would disagree! It is his car if he wants it and can afford it who gives a S#!T. It is his car, his money, and his happiness.
The Following 7 Users Say Thank You to Grady For This Useful Post:
AutoCulture (01-31-2023), finch1750 (01-30-2023), Jdmjunkie (01-30-2023), Pedro13 (02-01-2023), PulsarBeeerz (02-01-2023), Tcoat (02-01-2023), Teseo (01-31-2023)
Old 01-31-2023, 01:11 AM   #18
AutoCulture
Originally Posted by Sasquachulator View Post
you can...
I mean there is nothing to lose from it. I am planning on modifying my intake and exhaust next, thought might as well also do the manifold.
Old 01-31-2023, 02:16 AM   #19
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Yes, this is a guy here in Japan who did it on his pre-facelift BRZ and he went from 170.03PS to 172.82PS. Details here with dyno photos:
https://86-agent.com/?p=1003
Obviously 2HP is a very very tiny gain, this is not what I am hanging onto. Just strengthens the "why not" argument I guess.
To give a bit of context, a K&N (or any other name brand) in the stock airbox has been dyno tested to net 4-5 whp gain. So 3 whp is really minimal.
It's:
-spending big bucks on a cosmetic mod one cannot see
-terrible hp / $ return if you want to mod for power
Unless you're building a show car that'll spend some time with the hood open, I can't really see the point.
That being said, if you decide you like it, knock yourself out . There are much worse mods to make (*cough* pop tune *cough*).
alex87f is offline   Reply With Quote
The Following 2 Users Say Thank You to alex87f For This Useful Post:
Teseo (01-31-2023), x808drifter (01-31-2023)
Old 01-31-2023, 10:17 AM   #20
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Just money.
Old 01-31-2023, 10:32 AM   #21
Sasquachulator
Pavement Grey
If you're gonna go through the trouble of making the manifold work, its probably a better idea to do the intake and exhaust upgrades at the same time instead of at 3 different times. Might as well make that work not go to waste.
Old 01-31-2023, 05:51 PM   #22
AutoCulture
Yeah, that's what I meant by might as well do the manifold together with the exhaust and intake. I want to do them all together
Old 02-01-2023, 08:10 AM   #23
The grand total rated increase for the facelift cars was 5HP. That includes all the changes to the intake, manifold, exhaust, valves and tune. Thinking you are getting anything even remotely measurable out of just that manifold is optimistic at best. It does look much nicer though!
Do you have the ability to tune? If not you are probably wasting your time and possibly asking for nothing but problems as the stock tune will not be setup for this manifold.
Pedro13 (02-01-2023), x808drifter (02-01-2023)
Old 02-01-2023, 10:44 AM   #24
alex87f
Meow
alex87f's Avatar
Isn't it heavier too? Be careful not to raise that CoG too much!
The Following User Says Thank You to alex87f For This Useful Post:
bcj (02-01-2023)
Old 02-01-2023, 12:51 PM   #25
PulsarBeeerz
Drives: JRSC BRZ SOLD
It weighs maybe 1lb more.
PulsarBeeerz is offline   Reply With Quote
Old 02-01-2023, 02:50 PM   #26
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I thought there was an issue where the pre-facelift DI ECU bracket (which grounds it) wouldn't bolt onto the new intake manifold
Old 02-01-2023, 03:16 PM   #27
Sasquachulator
Pavement Grey
There's been so many little changes to this motor that getting ANYTHING from a facelifted motor to work on a pre-facelift motor is a complete pain in the ass and may not even be worth the trouble. MAYBE less so with an AT equipped one since only the facelifted MT models got the red intake manifold and the +5hp/+5torque bump.
Of course in this case theres no real point in persuing an AT motor since it uses the exact same black plastic manifold as every prior year.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Tcoat (02-06-2023)
Old 02-01-2023, 03:17 PM   #28
PulsarBeeerz
The MY17 has bespoke ECU/Fuel rail covers. Just bolt them on and it’s fine. Or a bit of cutting and the MY13s fit. Or one can use the Verus ECU brackets that work on all Gen1s.
DIY: pre-facelift to facelift steering wheel and cluster swap TRS DIY (Do-It-Yourself) Guides 16 10-22-2024 02:12 PM
86 Facelift TRD diffuser on a Pre-facelift Sam86 Cosmetic Modification (Interior/Exterior/Lighting) 6 04-10-2022 09:50 AM
GT86 2017 facelift bumper installed on pre-facelift 2015 model yoongjun Cosmetic Modification (Interior/Exterior/Lighting) 2 01-20-2021 11:28 AM
Facelift vs. non-facelift axlebacks alex87f Engine, Exhaust, Transmission 4 04-16-2020 09:26 PM
Facelift LED headlight to Pre facelift? teppei Cosmetic Modification (Interior/Exterior/Lighting) 0 09-17-2017 07:25 AM
