Old 01-31-2023, 02:56 PM   #99
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
Originally Posted by Ansix Auto View Post
Good question.. I'm not sure if I have a good answer. A DIY kit is a bit of a half measure, you might as well just fully DIY then?
I'd def be willing to pay for the convenience of all the parts sourced and ordered from one location, and clear instructions for assembly. Though, I am but one rando on the internet. XD
nissanfanatic is offline   Reply With Quote
Old 02-01-2023, 12:35 AM   #100
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by zeroomega View Post
I would hope some company can build a similar product with reasonable price. The market for this might not very big or profitable though.
At least you can build a CAN bus interface with an Arduino by one prebuilt PCB like http://docs.longan-labs.cc/1030008/ .
Only need to connect a power, an oil pressure sender and CAN bus lines of the option connector behind the audio.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
nissanfanatic (02-01-2023)
Old 02-01-2023, 12:54 AM   #101
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
That is an interesting option. I didn't know that. If I don't have knowledge to build a PCB I probably would use that. My customized board is much better though. The Atmega32U4 only has 10bit ADC while the ESP32C3 has 12bit. The oil pressure sensor is output 0.5v to 4.5v analog data so a more accurate ADC, the better. I also uses 2 CAN transceiver instead of one, the car's CAN bus data are copied to another isolated CAN bus, which is read by the data logger. The oil pressure data is sent to the isolated CAN to avoid causing CAN ID collision with car's CAN bus, which may trigger an CEL (very unlikely but possible).
zeroomega is offline   Reply With Quote
Old 02-01-2023, 07:36 AM   #102
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by KillerBMotorsport View Post
Again, the pressure drop off or light throttle is not the concern here. Pressure drop at WOT is very much the concern, and easy to duplicate on the dyno.
The accumulator would be drained to whatever its minimum would be and recharged under load. I would do it at 1,000 RPM increments to start with. On the dyno you can prolong the pull, shorten it, or hold it at a certain RPM and just hold full load continually. So, you can set up some pretty severe conditions while very closely monitoring oil pressure, temperature and flow.
I didn't know it was easy - how exactly do you simulate low oil pressure?
Blighty is offline   Reply With Quote
Old 02-01-2023, 08:41 AM   #103
jes
jes's Avatar
Drives: FRS
Thanks for the info
Hey, great link
jes is offline   Reply With Quote
Old 02-01-2023, 12:44 PM   #104
KillerBMotorsport
KillerBMotorsport's Avatar
Recharge the accumulator.
You're not simulating oil pressure loss under no/low load; you're simulating the effects of what happens when you recharge and lose oil pressure under load.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Blighty (02-01-2023)
Old 02-01-2023, 07:36 PM   #105
Blighty
Ahh, I see now. Sorry, pretty slow to catch on.
So its more about just how much the load of filling the accumulators is what you want to test, not so much recreating the tracks low pressure environment events and how if the accumulator stops dips past a certain level.
More concerning to you is whether the pressure required to refill the accumulator makes a worse situation in high RPM, and that is what you can test on a dyno (albeit probably in a full pressure environment, not just a 'above 25psi' environment).
Old 02-02-2023, 06:50 AM   #106
KillerBMotorsport
Correct. Engines don't pop under no/low load with a partial oil pressure loss like what is being observed in the corners.
Correct. When the accumulator recharges, there will absolutely be an oil pressure loss to the engine, and under full load. The worst time to have ANY oil pressure drop. Is this a 5psi drop or a 25psi drop? No one knows, but physics doesn't lie. Anytime you create a hole in a pressurized system, there WILL be a pressure drop.
Blighty (02-07-2023)
Old 02-02-2023, 11:34 AM   #107
gnarjunkie
Drives: '23 GR86, '17 BRZ
There's a lot of corners out there that aren't at low/no load though. Half of our local tracks out here in CO have high-G, high speed corners where you are flat or nearly so through the apex.
gnarjunkie is offline   Reply With Quote
Old 02-02-2023, 07:25 PM   #108
KillerBMotorsport
If you have logs showing heavy load right-hand turn starvation, please share them.
So far I've only seen data that supports starvation initiated at braking/lift/rise going into and continuing through a right-hand turn.
Old 02-03-2023, 01:37 PM   #109
gnarjunkie
I have no data. Just pointing out that higher-g corners could still be a high load situation.
If it is only being observed in lower load corners though then that's great. My impression was this was being seen on higher-g right hand corners, especially if there's also elevation gain happening.
Old 02-03-2023, 05:49 PM   #110
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Another part of what the accumulator may do is, at low rpm/oil pressure, it discharges some oil to create an overfull condition. This would mitigate the problem of oil moving away from the pick-up in a high G turn. There is still the issue of recharge under load but the higher the oil pressure, more pressure exists in the accumulator restricting how fast it will recharge. So, hypothetically not taking too much needed pressure from the engine internals. More testing is definitely needed.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 02-03-2023, 06:11 PM   #111
nissanfanatic
Drives: 2023 BRZ
Yea my thought on the elevation gain is that causes less accel/some decel. I kind of think a right hander plus decel causes oil to slosh forward and to the left,which is the least desirable for the pickup location.
It would be nice to test this on a skidpad or something where you can load the car laterally and then mess with accel/decel to try and reproduce the pressure drop.
Old 02-03-2023, 08:22 PM   #112
gnarjunkie
That would make sense.
There's a couple corners on local tracks that have a short braking zone followed by a big sweeping uphill right hand corner that's pretty close to or at full throttle depending on the car. I haven't gotten to track my 86 yet (bought it during winter), but in my STi I was pretty much flat through the curve and over the rise.
AD08R tire pressure Drag Race pro_turbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-13-2021 04:04 AM
Oil pressure drops to zero after a cold start? MINOCIN Engine, Exhaust, Transmission 24 07-10-2014 02:57 PM
Darren drops his phone onto the Formula D track... DarrenDriven Northwest 2 07-22-2013 03:30 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
FRS @ willow springs (1.8 mile race track with 12 corners) scionnut Southern California 7 08-04-2012 02:29 AM
