View Poll Results: What will the average MPG be?
20 MPG avg 1 1.96%
22 MPG avg 1 1.96%
24 MPG avg 7 13.73%
26 MPG avg 15 29.41%
28 MPG avg 9 17.65%
30 MPG avg 18 35.29%
Voters: 51. You may not vote on this poll
Old 04-19-2011, 10:18 PM   #29
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by Allch Chcar View Post
This discussion would be better served in the engine tech thread.
I will add this. For example only: in tests like the EPA increasing the Engine efficiency is 1%:3% for every bit of improvement. While weight lost and aerodynamics improved is like 3%:1%. From the EPA fuel economy website.
DI doesn't increase efficiency by more than 3-5%, which is a lot. But 3% more efficiency points at the engine would be something like 12% more MPG on the road.
In general too high of compression can be bad for power after a certain point even though it generally means more efficient combustion. Ask the turbo guys and they'll unanimously demand low compression with a stout stock block. Gasoline Direct injection is better than port or throttle body injection but there are still limitations on the power vs fuel efficiency range for pump gasoline. Ethanol(E85) has a wider curve because but the same theory still applies.
Yes no doubt light weight and aero design of the car will do more for the fuel economy. However I was just replying back to the comment about the high compression.
tranzformer is offline   Reply With Quote
Old 04-19-2011, 10:52 PM   #30
Allch Chcar
Drives: N/A
You misunderstand me sir. Increasing the compression ratio is more cost productive than reducing weight or aerodynamics together for FE. It's just that it can be bad when under heavy loads like heavy acceleration etc.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 04-19-2011, 10:58 PM   #31
tranzformer
Drives: Zoom Zoom
I got you.
Old 04-20-2011, 08:02 AM   #32
Matador
hashiryu
Drives: Mk4 Supra
Only because of having to severely retard timing or make other compromises in engine tune to prevent detonation and protect the engine. Lots of Turbo guys will obviously demand that, but lots of tubro guys only think in terms of static compression ratios. Boost + Compression will result in the same dynamic compression ratios inside the combustion chamber when running, if not higher.
Anyway, High compression + Boost on DI for the win
Matador is offline   Reply With Quote
Old 04-20-2011, 12:52 PM   #33
Allch Chcar
Drives: N/A
I got you.
GOOD.
I know, "boost retards" or w/e. I was just using that for a vague example.
I hear ya on high compression + Boost .
-Allch Chcar
Old 04-20-2011, 01:54 PM   #34
boostedscooby
Drives: subaru sti
anything over 30mpg will make this car sell and if subaru and toyota make this happen i will be getting one a.s.a.p
boostedscooby is offline   Reply With Quote
Old 04-20-2011, 02:18 PM   #35
tranzformer
Drives: Zoom Zoom
Old 04-20-2011, 02:26 PM   #36
Allch Chcar
Drives: N/A
So in other words expect Scion tC like MPG...
-Allch Chcar
Old 04-20-2011, 02:30 PM   #37
tranzformer
Drives: Zoom Zoom
No better. This is going to use the new FB20 engine from FHI. That FB20 in the new Imprezza is going to get 27 city 36 highway in the heavier Imprezza (like 3000lbs?)
Old 04-20-2011, 02:35 PM   #38
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
I'd be sooooo happy if it got this milage.
iff2mastamatt is offline   Reply With Quote
Old 04-20-2011, 02:37 PM   #39
tranzformer
Drives: Zoom Zoom
Sorry I was thinking you meant more the older tC mileage of like 20/27. I think it could be close to the tC if not a little better.
Old 04-20-2011, 02:43 PM   #40
Allch Chcar
Drives: N/A
The new tC MPG score is at least a starting point anyway. Now that we know the Scion is getting the 2.0L I'd hope it would get noticeably better MPG than the 2.5L in the tC and not just because it's going to be in a smaller car.
-Allch Chcar
Old 04-20-2011, 02:50 PM   #41
tranzformer
Drives: Zoom Zoom
Yeah but it is hard comparing the 2AR-FE straight-4 vs. the FB20.
I would be curious to see how the FB25 would compare against the 2AR-FE straight-4.
Old 04-20-2011, 03:03 PM   #42
Allch Chcar
Drives: N/A
We may never know, as far as I know there isn't an FB25 yet. Subaru put a FB20 in the Forester of all things to presumably help with the MPG. And the press releases says that the FR-S(that's what they're going to call it) will be using the FB20.
Originally Posted by http://pressroom.toyota.com/releases/scion-fr-s-concept-reveal-jack-hollis.htm
The naturally aspirated two-liter engine features Toyota’s D4-S injection system… which utilizes both direct and port injection… resulting in increased horsepower and torque throughout the entire powerband. We all know that it’s not hard to make horsepower and torque…but it IS hard to do all that AND get great MPG. The FR-S Concept tackles all three.
There is big differences between the old EJ and the 2AR-FE but the new FB is closer in design to a regular straight 4. Narrow bores with long strokes for example.
-Allch Chcar
Toyota FT-86 Price Poll +1 Scion FR-S / Toyota 86 GT86 General Forum 173 02-11-2014 08:22 PM
Poll on age demographic of Potential FT86 owners [es vi: eks] Scion FR-S / Toyota 86 GT86 General Forum 66 10-13-2012 02:36 AM
The individual income/salary poll xantonin Scion FR-S / Toyota 86 GT86 General Forum 79 05-06-2011 10:49 PM
Why there isn't a poll option in this forum? Blokatos Off-Topic Lounge [WARNING: NO POLITICS] 3 11-24-2009 01:45 PM
