Old 01-25-2023, 07:38 AM   #407
Originally Posted by alex87f View Post
Their range is getting old and they've struggled with new product timelines. At this rate, the Cybertruck may be old stuff by the time it's released.
I think some of the struggle with timelines is that they don't have the capacity to build new products, particularly ones that may rival the Model 3 in volume. Better to hold off then underproduce perhaps?
Old 01-25-2023, 10:51 AM   #408
MyHybridBurnsGasAndTires
Drives: what
cybertruck is vaporware
MyHybridBurnsGasAndTires is offline   Reply With Quote
The Following User Says Thank You to MyHybridBurnsGasAndTires For This Useful Post:
NemesisPrime909 (02-04-2023)
Old 01-25-2023, 12:58 PM   #409
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Old 01-25-2023, 01:13 PM   #410
Irace86.2.0
Munro has a breakdown of the Octovalve and Supermanifold too. Years old, but worth highlighting.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (01-25-2023)
Old 01-27-2023, 06:21 PM   #411
Irace86.2.0
More aftermarket buttons. See what you did to my algorithm @Dadhawk
It’s clickbait. It isn’t from Tesla.
Dadhawk (01-27-2023)
Old 01-27-2023, 07:27 PM   #412
Sorry about that.
Irace86.2.0 (01-27-2023)
Old 01-29-2023, 08:43 AM   #413
soundman98
ProCrastinationConsultant
soundman98's Avatar
It's fox news, so mileage may vary, I intend to try to look into the study more later. But the study is claiming that it's currently cheaper to use a gas vehicle than an ev.
I suspect the numbers can be gamed to make ev or gas an advantage, and they're either not accounting for something, or factoring too much of something else.
https://www.foxbusiness.com/economy/...onsulting-firm
Old 01-30-2023, 01:41 AM   #414
Sasquachulator
Pavement Grey
AFAIK Electricity prices will be significantly lower if you charge from home, and theres a low chance gas prices will ever beat that.
HOWEVER its where you live and if you are charging at fast charging stations where the electricity prices seems to vary considerably, and thats where its possible for it to cost more than a gas car. But because of its wildly varying amounts you cant simply conclude that it will cost more to charge an EV than it would to fill up a gas car.
The thing with EV's that no one wants to admit is that the savings are a long term thing. You won't see the savings until you first make up that price difference between equivalent EV and ICE and that could take several years to cancel each other out.
Old 01-30-2023, 02:08 AM   #415
Irace86.2.0
The analysis compared "mostly charging at home" and "mostly charging commercially" with ICEs, and they found that mid priced ICEs were cheaper to fuel than both EV scenarios, but that luxury EVs were definitely cheaper, noting that we don't have enough economy or truck options to compare. They did not consider the full cost of ownership, including things like maintenance expenses, but they did include the cost to drive to a charging location or gas station. I'm assuming they are talking about a supercharger station and not a free level two charging location. It doesn't really say if they are including hybrids in the quoted figures for ICEs.
By their calculations and the article's comments, ICEs were cheaper the EVs to fuel, but then gas prices shot up, and now that gas prices are back down, ICEs are back to being cheaper.
I agree that there is something off because the cost in fuel savings per year is typically posted on the Monroney sticker, and it is a significant savings:
soundman98 (01-30-2023)
Old 01-30-2023, 02:25 AM   #416
Irace86.2.0
I found the report:
https://s3-prod.autonews.com/2023-01...4%20Update.pdf
Pretty sparse, even for a preview, but it seems that they are not including the savings in maintenance, and they are not transparent about what cars are included in each category, so are all hybrids excluded or included in the ICEs? Is a Model 3 mid or luxury on their account? But here is the interesting thing: they included the cost of the home chargers to the equation; I don't know if they calculated the average cost to install a 240v system in the garage or run a line outside, and to install a level two charger, and it is unclear if they are averaging that price over the life of the car or of the life of the owners or just that first year of install. They don't really explain, but if they didn't include that cost then the price of the mid level EV would be cheaper to run, as you can see below.
It really doesn't make sense to add that price, especially without explaining the price better, but the main reason why it doesn't make sense is because it would be considered a home upgrade, which would increased the resale value of the home like installing an upgraded furnace or water heater or whatever. The cost would be recuperated. It is also a one time purchase where someone could install the system in their garage in their twenties, and then use it until they die in the eighties, so the cost isn't significant over the life of the household.
Considering that fact and the fact that they didn't include maintenance costs or detailed explanations, I'm calling
Old 01-30-2023, 08:00 AM   #417
Not sure they considered all scenarios when charging at home. For example, if I had an EV I could charge for free at home (between 11p and 6a, up to 400KwH per month) and I can charge at work for free, within view of my office window.
Irace86.2.0 (01-30-2023)
Old 01-30-2023, 11:51 AM   #418
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Cost of install and value added is going to very greatly on the home and area. For me it would be cheap, I have a 50amp and 30amp 220 breakers with nothing hooked up to them and could run it myself. My parents just payed 7-800 bucks including the cost of the level 2 charger to have theirs installed. If you don't have enough service to your house it is going to be very expensive. I think in 5-10 years it may be a bigger deal to have a house with a charger already installed. In my area, it is more of a novelty.
Old 01-30-2023, 08:41 PM   #419
soundman98
soundman98's Avatar
I found the report:
i was really hoping to figure out where the financing for the study came from. i bet it's not from tesla or rivian.
i could understand adding the charger install cost if they were accounting for all maintenance costs for any energy source, but by only doing it for ev's, it's like only counting tires as the entire maintenance cost for an ice..
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Irace86.2.0 (01-30-2023), NoHaveMSG (01-31-2023)
Old 02-23-2023, 01:12 AM   #420
Irace86.2.0
New California Engineering HQ at old HP facility.
knowitallsavingtheworld, longwindedcocksuckers
Which truck? EAGLE5 Other Vehicles & General Automotive Discussions 35 11-18-2014 01:49 AM
Help me help my mom buy a truck bdanisi Other Vehicles & General Automotive Discussions 18 11-09-2013 11:45 PM
UPS Truck vs. My new FR-S Bullschmidt91 Scion FR-S / Toyota 86 GT86 General Forum 99 03-26-2013 08:43 PM
GBS Premium 6MT Available, just came off the truck... Opie BRZ First-Gen (2012+) — General Topics 0 09-12-2012 02:53 PM
BMW M3 truck!?! RRnold Other Vehicles & General Automotive Discussions 15 04-03-2011 03:47 AM
