Old 01-22-2023, 02:24 AM   #1
TkMash
Drives: 2013 scion fr-s
Frs rear end
So I have a frs with a ls3 in it making around 500whp and 500 ft lbs of torque. I'm looking for possible options to rebuild the rear end. I am stuck between going with a ford 8.8 rear end swap and just upgrading the axels. I wanted to see if there is any after market diff that I can upgrade to that will handle the power I'm sitting at and bolt right up. The car will also be used for drag racing and will be launched so i need a diff that can take a beating. I guess I'm just trying to see if there are cheaper options than the ford rear end that will get the job done.
TkMash is offline   Reply With Quote
Old 01-22-2023, 03:42 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If all it's gonna do is straight line get an 8.8.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
DarkPira7e (01-22-2023), soundman98 (01-22-2023), weederr33 (01-23-2023)
Old 01-23-2023, 12:49 PM   #3
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
The OEM differential can handle the power no problem.
The axles will be the weak link. Driveshaft shop makes upgraded axles, or you can look into using stronger oem axles with a bit of fabrication and research. Someone on FB is using 350Z axles for example.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
The Following User Says Thank You to terboboost For This Useful Post:
Falkon240 (01-23-2023)
Old 01-29-2023, 12:38 AM   #4
TkMash
i want the car to be able to do both drag and track. its not gonna be an all out drag car i just want to be able to take it out there every now and then and have some fun.
The Following User Says Thank You to TkMash For This Useful Post:
x808drifter (01-29-2023)
Old 02-07-2023, 02:50 AM   #5
Kynans
Ultra Junior Member
Kynans's Avatar
Drives: 2013 Scion Frs First Edition
The 8.8 is used mainly for drag, I haven't seen anyone so far using it for track. IMO best practice is to upgrade the axles / hubs if needed and place an adjustable 2 or 1.5 way lsd from OS Giken, Tomei, or Cusco. Get some good Poly or solid mounts for the load transfer.
I've got about 470 wtq with an OS with stock ring and pinion.
That's how I would do it.
PS. If you upgrade the diff, make sure you change all the bearings and such.
I'm curious on what you decide, I to have though about an 8.8 swap, I will only swap for durability and track use tho.
Sent from Tapatalk
"I like to pretend I'm fast but I'm really not"
Kynans is offline   Reply With Quote
Old 02-07-2023, 09:09 AM   #6
Grady
Grady's Avatar
The rear end is the strongest part of the drive line. First is transmission, then half shafts, then rear end. Not sure where the driveshaft fall in place but never heard of anyone having any issues with it.
The Following 2 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (02-07-2023), x808drifter (02-09-2023)
FS: AP Racing Sprint kit, OEM rear rotors and calipers, front and rear pads, extras zdr93523 Brakes, Suspension, Chassis 10 02-15-2018 04:13 PM
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 12:27 PM
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 05:48 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 05:46 AM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
