Old 01-23-2023, 03:32 PM   #1
SpeBud07
Drives: 2013 FRS
Traction Control issue
I have a 2013 FRS that is having a weird traction control issue. My driveway is up a little hill (and I do mean little) and every time I pull into it, the car bucks and the traction control light comes on. I turned off the TC via the button on the console and it still does it.
I have Racecomp SS-1s on the car, so maybe I'm getting a tire leaving the ground and it doesn't like it?
Sorry if this isn't the right forum.
SpeBud07 is offline   Reply With Quote
Old 01-23-2023, 03:41 PM   #2
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
If you haven't confirmed whether or not this is the case, then you might as well do that first before we all go chasing our tails. Lifting the inside rear would definitely explain what you're experiencing.
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 01-23-2023, 03:45 PM   #3
WNDSRFR
Drives: FR-S,GTI
Which TC button are you using?
The SS button or the VSC button?
OFF SPORT
And are you pressing it or holding it?
Try pressing and holding the SS button until the TRAC and SS lights illuminate.
OFF OFF OFF
The Following User Says Thank You to WNDSRFR For This Useful Post:
SpeBud07 (01-23-2023)
Old 01-23-2023, 03:49 PM   #4
WNDSRFR
Drives: FR-S,GTI
OFF SPORT
OFF OFF OFF
Whenever I post this, the text gets rearranged. I'm trying to desrcibe the different buttons and indicators but I think you know what I mean.
Old 01-23-2023, 03:49 PM   #5
SpeBud07
Drives: 2013 FRS
OFF SPORT
OFF OFF OFF
The button on the left (car with squiggly lines under it) just to make sure I don't misname it again. I did just press it, and it didn't light up the dash light, so I think you're right it wasn't really "off."
My theory on the back left lifting is only because it started after the SS-1 installs, but I haven't parked it on the drive at the approach angle to make sure. It's a solid theory at this point. Good to know that will create that behavior.
Old 01-23-2023, 05:11 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
With a Torsen LSD, it acts as an open diff if there is no torque load on one wheel IE, it's in the air. The TC is using the brakes to engage the caliper on that wheel to get it to grab and lock. This is likely what you are feeling. My car does it all the time on inclines as it is both low and stiff. I can't hit transitions straight on or I scrape, but a slight angle causes one of the tires to lose contact with the ground. Completely normal.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
RedReplicant (01-23-2023), strat61caster (01-23-2023), x808drifter (01-24-2023)
Old 01-23-2023, 07:07 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yup that, is the torsen and traction control system working as intended. I’ve found that if you can do it faster it smooths it out because grabbing the brake on the left rear will jerk the car less at higher speeds.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
NoHaveMSG (01-23-2023), RedReplicant (01-23-2023), x808drifter (01-24-2023)
ABS/Traction Control issue SnoopDodd Issues | Warranty | Recalls / TSB 9 12-24-2020 07:58 PM
Traction control issue, won't turn off slyphen Issues | Warranty | Recalls / TSB 18 08-23-2016 11:37 AM
Traction control and VSC Sport mode issue Grazed Issues | Warranty | Recalls / TSB 10 11-29-2015 02:58 AM
Traction control issue? mit_peid Issues | Warranty | Recalls / TSB 30 08-24-2013 05:17 AM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 09:13 PM
