#1555 |
At the track
Drives: '14 FRS - Former e92 M3
What does this unrestricted number turn out to in avg whp?
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#1556 |
Drives: None
I don't have the dyno files for that run but I would guess in the 215-218whp area.
I need to add a 2x 25lb weights to the car and probably run 3/4 tank plus to be safe this weekend, ughhh.
#1557 |
At the track
Sweet, that's kinda what I was thinking, stoked to hopefully get my parts in soon this is right where I want to be!
#1558 | |
Drives: 2013 toyota 86
The Kswapped s2k dont seem to have these promblems. |
#1559 | ||
Drives: None
I suspect the Bosch TB will have fewer issues since there is a much, much larger gap taken up by the silicone coupler compared to the BRZ TB. I will say to make sure to tie your harnesses down so nothing flexes as the car drives, my MAP sensor repair broke again after an hour of track time, fixed it by using longer pigtails and making sure there is no stress on the wires. semi related https://grassrootsmotorsports.com/articles/superk/ Quote:
#1560 |
Drives: None
Heard a couple of interesting things today, ASM doesn't run oil coolers on the GLTC K cars, they use the stock rear vent on the valve covers instead of different ports, and they weld a tab to the header so it can be supported by one of the transmission bolts.
#1561 |
Drives: Fr-s
This matches up with what Andy told me. Just to add a bit more detail, they also use the expanded capacity oil pans.
I'm not sure if they are welding a different tab on, but the the oem s2 config also has a support bracket to the header.
#1562 |
Drives: None
The one I saw had a tab welded on and it connected to the second bellhousing bolt from the bottom right.
You have any more nuggets you're willing to share? Finding info on their cars is difficult, haha.
#1563 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Any idea what weight oil they are running without the coolers? Pretty sure they are running Unit2 oil pans which are 9 liters based on the web description. I think the k power pan is around 7?
Also curious about the exhaust tab. If you guys see any pics worth sharing it would be appreciated. Intake and exhaust brace are at the top of my to do list now besides finally drilling my dip stick hole correctly..... |
#1564 |
Drives: None
I don't know what the official kpower capacity is, but unless you fill it to the twist in the stick you're going to get oil pressure drops on track anyway.
#1565 |
Wears Pants
My dipstick is shortened to the top dot currently since it was a pain to get it to seat with the kpower dipstick hole blunder. Unfortunately I didn't catch this until the engine was already in the car. I wonder if pulling the pan is worth the trouble if I need to keep it above that point anyway. That means I could do head/cams in situ which would be a bit less work overall.
#1566 |
Drives: 16' WWB
Welp, had to get a tow home last night...
Started my car up after getting McDonalds, drove about a block, then car just died. Started it back up, it would idle (although struggle), but not take any throttle input without dying. Eventually I gave up trying to get it to run and had it towed home. This morning trying to start it it cranks but won't start at all. Here are the codes it was reporting. ![]() I had a Bosch 74mm TB that I have been meaning to install, so I went ahead and threw it in using the Kpower adapter plate and harness. Calibrated, confirmed it works, but still same thing: crank, no start. Any ideas? I'm stumped. Checked all connectors around the car, everything is plugged in, nothing looks loose or damaged... |
#1567 | |
Drives: None
What is your MAP sensor reading at rest with the car just in ACC mode or whatever? Also, the KPower 74mm adapter rubber gasket only has like .5mm in two spots, so make sure it is actually sealed if your MAP is reading a sane value. Also, here are some header brace pictures ![]() ![]()
#1568 | |
Drives: 16' WWB
The Kpower fuel pump ECU bypass connector is warped on the pin for the red wire due to excessive heat. This was causing the power to the fuel pump to be intermittent as the male and female pins were losing connection due to the heat warp. ![]() ![]() I'll email Kpower to see what they say, but I will likely just permanently solder the wires together or maybe put in a delfi connector as they are a lot more robust than the Kpower connector. As for the TPS codes I'm not really sure why there were present, but to be safe I threw in my Bosch 74mm TB anyways. |
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
