Old 01-03-2023, 09:17 PM   #1
Bunsin
Car Goes Bang
Drives: 2013 FRS, 2014 BRZ
Potholes and weak rear toe arms don't mix...
Well today was exciting. While driving to work in the rain I hit a number of potholes in a row and the drivers side rear tow arm broke. The ABS and some quick hands kept me from a full spin into oncoming traffic. I was running lightweight aftermarket toe arms with anodized bearings. Even though the corrosion was starting to show (I've had them on for about 7 years now), they still moved freely and were set up fairly neutral without binding. Not sure how but the inner bushing housing snapped. Going with Whiteline rear adjustable toe arms this time.
Bunsin is offline   Reply With Quote
Old 01-03-2023, 09:41 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
No pics? no brand name to help us know what product failed? Glad you managed to avoid a catastrophe but help us avoid the same with better info
Old 01-04-2023, 01:16 AM   #3
marco_mc22
Drives: Toyota 86
Hardened steel or aluminium? Did the bushing housing snap? Or the adjustable stud?
marco_mc22 is offline   Reply With Quote
Old 01-04-2023, 09:24 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
And this is why I'm not a fan of running aftermarket suspension links/arms/primary structural components. Almost never necessary, and nowhere near the level of analysis and testing as OEM.
Old 01-04-2023, 01:51 PM   #5
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
There are aftermarket companies that do a thorough amount of testing, though. Verus Engineering is a good example. Their aluminum rear LCAs are far lighter than stock, and look far flimsier, but they did lots of FEA and testing to ensure they are robust enough to stand up to abuse, and as a result they've been on my car for over 6 years now, and have seen endless Chicago potholes, seasons of autocross, and even some VERY violent impacts with road debris.
You're right, though. There are plenty of companies that do NOT do that kind of testing, which is why buying those kinds of parts requires actual research and not just blindly buying whatever is cheapest or on sale at the moment.
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
Old 01-04-2023, 02:25 PM   #6
Bunsin
Car Goes Bang
Originally Posted by RACECAR go brrr! View Post
There are aftermarket companies that do a thorough amount of testing, though. Versus Engineering is a good example. Their aluminum rear LCAs are far lighter than stock, and look far flimsier, but they did lots of FEA and testing to ensure they are robust enough to stand up to abuse, and as a result they've been on my car for over 6 years now, and have seen endless Chicago potholes, seasons of autocross, and even some VERY violent impacts with road debris.
I'm running RSR coilovers and LCAs but the toe arms were Versus. Indianapolis is in the freeze thaw zone so potholes abound. I've hit some pretty bad ones and never had an issue before this. The breakage makes sense if the bearings were bound, but I checked them in Nov when I switched to winter tires on the OEM wheels and everything was OK.
Old 01-04-2023, 02:40 PM   #7
Bunsin
Car Goes Bang
Sheesh couldn't wait a minute to get the broken parts off the car and the new ones ordered
Old 01-04-2023, 02:43 PM   #8
Bunsin
Car Goes Bang
See pic in the response above. The bearing housing is aluminum.
Old 01-04-2023, 02:46 PM   #9
DarkPira7e
DarkPira7e's Avatar
The way things typically work here, you can't blame me.
Thank you for posting a photo!
Old 01-04-2023, 03:25 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Do you mean "Verus"?
"Verus"?
Indeed, Verus:
Old 01-04-2023, 03:31 PM   #11
RACECAR go brrr!
Damned spell check!
Old 01-04-2023, 03:46 PM   #12
Clay_from_Verus
Clay_from_Verus's Avatar
Drives: 2013 Subaru BRZ
Hey man! Sorry to see this happened. Can you please email me with photos and more details on what happened? We do not manufacture the rod ends and I've never seen one fail like that. clay@verus-engineering.com
Clay_from_Verus is offline   Reply With Quote
Old 01-04-2023, 03:51 PM   #13
Clay_from_Verus
"Verus"?
Indeed, Verus:
These rod ends are FK units, and we've never had one fail like that. That's wild.
Old 01-04-2023, 05:24 PM   #14
norcalpb
norcalpb's Avatar
OP how close are you Verus HQ? It may be a good idea to drop off the broken bearing with them so they can send it to FK for inspection.
wanted: rear control arms, toe arms & trailing arms Turbo Canada Classifieds 0 08-14-2018 12:18 AM
Need to buy: stock rear lower control arms/toe arms and intake elbow CoolHandMoss Want-To-Buy Requests 6 07-12-2018 08:44 AM
Megan racing rear lower control arms , toe arms, rear traction arm fcdrifter20 Brakes, Suspension, Chassis 11 01-03-2016 08:11 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
