Old 12-31-2022, 12:42 PM   #1541
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by ML View Post
My k24 is at my engine builder and he opened it up to find the #4 piston ringland was cracked. At my last event it was smoking enough to get black flagged, but still ran fine so this would explain that. He also said the main bearing had a bit of scoring. Motor had 140k miles on it when I got it and I only replaced the timing components and oil pump. If I had to guess to a cause probably knocking which was probably from 140f intake temps at points, but if I remember correctly it always smoked a little bit since I first got it. oh well, forged pistons, rods, cams, valves, valve springs, guides, seals and all going in it now with 9.5 compression and 500hp goals. Just pray I don't have the built k curse...
Pump gas?
Old 12-31-2022, 12:49 PM   #1542
ML
ML's Avatar
Drives: 13 White MT FR-S
Pump gas?
last year? yes. In the future? yes but will do meth injection if I have to.
Old 12-31-2022, 01:28 PM   #1543
RedReplicant
Drives: None
Might be worth switching to a Bosch knock sensor, the stock ones are kinda useless
I think you can put together the weird adapter bolt, sensor, and pigtail for like $40 if you search around for oem part numbers rather than paying for the named Bosch sensor. Reuse the existing knock sensor wire for signal and sensor ground for the other wire.
RedReplicant is offline   Reply With Quote
Old 12-31-2022, 04:50 PM   #1544
funkjaw
Drives: 16' WWB
Originally Posted by RedReplicant View Post
Same Dynapack dyno, original back in May. 205whp. Made 202whp on a Dynojet in NASA config after this.
Original chart is overlaid to see the difference.
Changes are Drag Cartel DICs and a Bosch 74mm TB, maybe 10-15f ambient difference. 230whp.
I was honestly expecting 215whp or so, best case. Pump 91.
Also made two flat tune maps for 205whp and 200whp. Pretty fat ~2000-2200 rpm power table top.
That's freakin awesome. You basically made more power EVERYWHERE which is a huge achievement. Those DICs are good for ~10whp gain or so from what I have seen, but you gained 25whp, so seems like the Bosch TB net you 10whp? (then the other 5whp from the weather change...?)
funkjaw is offline   Reply With Quote
Old 12-31-2022, 05:14 PM   #1545
ML
ML's Avatar
Yeah I have one, couldn't get it to work either
Old 01-01-2023, 02:04 PM   #1546
RedReplicant
Drives: None
I'm not entirely sure what it was, I wish I'd dyno'd just the TB back to back.
That is ... strange.
Old 01-01-2023, 02:25 PM   #1547
funkjaw
Drives: 16' WWB
I'm not entirely sure what it was, I wish I'd dyno'd just the TB back to back.....
I'ma ask my tuner if he can do this for me and will report the results.
Old 01-03-2023, 05:17 PM   #1548
funkjaw
Drives: 16' WWB
Clutch Pedal Issue
Not sure if this is a twin problem, a kswap problem, or a me problem - but when I shift at high RPMs say 7k+ especially in higher gears 3rd+ the clutch pedal often loses a lot of it's travel. For instance one time shifting at 8k from 5th-6th when I pressed the clutch pedal in it refused to come off the floor and I had to physically lift it up with my foot then press it back down to make the shift (similar to bleeding a clutch). In all other scenarios such as just cruising around and and keeping the RPMs in normal range the clutch pedal does not have this issue.
Any thoughts?
Clutch is Action Clutch stage 2
https://actionclutch.com/products/st...2013-2016-2-0l
Clutch master and slave are OEM
Fluid is Motul RB600
Flywheel is the Kpower race version
With Verus clutch fork
Old 01-03-2023, 05:33 PM   #1549
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Sounds like a failing slave cylinder to me?
captain awesome is offline   Reply With Quote
Old 01-07-2023, 01:40 PM   #1550
sfruski
Drives: Many
Any thoughts?
(Twin Problem) Try overfilling your clutch fluid reservoir. A previous issue I had with high RPM downshifts: Even at the full line, air would get in under hard braking and shifting. Once I overfilled the resevoir, the issue went away. I discovered this after had already put in a new master, slave and repeated fluid changes.
sfruski is offline   Reply With Quote
Old 01-09-2023, 11:38 PM   #1551
RedReplicant
Drives: None
Been dealing with intermittent fueling issues for a while, suddenly got a lot worse today when prepping the car for the classing dyno / events this fri-sun.
MAP was reading wonky, wiggle plug and it goes crazy. Pull on the wires to make sure they're seated and one came right off.
Seems like it was barely holding on this whole time.
Also, sat on the phone with Haltech Australia for about an hour and a half tonight - the push button to start not working once changed is on the list to be fixed for the next version, apparently. He was going to have me roll back to 3.0.2 or something to fix it but aint nobody got time for that.
Probably going to have to go to a JY and cut a Honda plug in order to get this done in the next couple days, gotta do what you gotta do.
Old 01-12-2023, 11:20 AM   #1552
redlined600
redlined600's Avatar
Drives: Fr-s
Do you think that was caused by a bad crimp?
redlined600 is offline   Reply With Quote
Old 01-12-2023, 11:36 AM   #1553
RedReplicant
Drives: None
It looks like the wire got nicked during stripping and eventually failed
Old 01-13-2023, 01:26 PM   #1554
RedReplicant
Drives: None
This is what the unrestricted pump 91 tune made on a dynojet with the nasa smoothing
Something is up with the tune at vtec transition, so I need to get that figured out. It also present is on my "205whp" and "200whp" tunes dynos so it isn't an anomaly like I assumed before.
Car made 205whp and 206whp average on the 200whp and 205whp tunes so I get to add ballast. They basically made the expected power with heatsoak but blew me up otherwise, which I'm not real happy about.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 03:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 01:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 01:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 04:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 01:00 AM
