Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-30-2022, 02:36 AM   #29
X25
Sr. Spiritual Advisor
X25's Avatar
Drives: 2023 BRZ Premium
Originally Posted by Blighty View Post
Both cars can see it in standard mode, only the BRZ lets you show that while in track mode apparently. The GR86 has a special fixed gauge.
Wow, that pretty much makes BRZ a much better choice for track use. Tire pressures are as critical as oil temps for track duty.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4
'21 Tesla Y Long Range AWD
'19 Corvette Z06 Z07 (Track Build Thread)
X25 is offline   Reply With Quote
Old 12-30-2022, 10:41 PM   #30
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
In the paddock? Yes.
On track? Not so much, unless you're losing pressure due to a puncture.
I mean, people have been tracking gen1 cars with no such display.
Furthermore, many gen2 owners don't even put TPMS sensors in their track set of wheels.
Besides, what are you going to do if your tire pressure is 38 and you want 35?
Doing a cooldown lap won't help. I tried.
If you really need real time tire pressures, you might as well make the font larger
And btw that trick was also available on gen1 cars with Android Auto head unit (whether OEM or aftermarket).
Follow the build thread for my GR86!
Old 12-30-2022, 11:03 PM   #31
X25
X25's Avatar
Tire pressures provide a lot more than that.
I do have 2 sets of track wheels and additional front wheels; they all have TPMS. I highly recommend that you get them, too : ) I eventually settled with Autel's programmable sensors as well, so I don't even need to switch tire set using the button by the glove box anymore.
Tire pressures can:
  • Let you figure out if you're above or below your hot pressure targets, as you've also alluded to.
  • Let you figure out if you're overdriving one end of the car (e.g. are you overdriving front outer tire??)
  • Let you know if they started warming up (especially important in cold days) in the beginning of sessions.
  • If you are starting at low, not very safe pressures, they can also let you know if you're above threshold (usually 26 PSI) to go fast on straightways.
Anyway, I'd say I'd downright be worried if I don't know the tire pressures on a fast car (like a Z06). It's less critical for these cars, but still very valuable in my opinion.
YMMV
EDIT: Ohhh I just realized you have GR86 and that's why you were arguing if it's really necessary; now I got it, sorry.
The Following User Says Thank You to X25 For This Useful Post:
DriveDriftDogfight86 (01-29-2023)
Old 12-31-2022, 01:46 AM   #32
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Mcgiiver View Post
On the BRZ, the cold engine light shuts off very early,no where near normal operating temp. Then the oil temp requires at least 5 miles driving to reach 190.
From watching the gauge on my car, it definitely takes more than 5 minutes of city driving for the oil to hit 190.
Basically all new cars have the "cold coolant temp" light these days. From years of experience, I'm pretty sure all it means is that the heater will blow warm once it's off.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Is there a difference between gauge clusters UDSM brz vs EU/AU brz? wutangbrz BRZ First-Gen (2012+) — General Topics 1 01-24-2019 06:21 AM
Modded Gauge Clusters CThomas Cosmetic Modification (Interior/Exterior/Lighting) 2 03-21-2015 08:45 PM
