Old 09-19-2019, 03:34 AM   #197
Project_1796
Drives: Scion FRS 10 series
Yes copy the table from 6000 row on advanced max a table, log and adjust
Project_1796 is offline   Reply With Quote
Old 06-12-2020, 06:48 PM   #198
TheFox
Drives: 2017 Toyota 86 Asphalt AT
Hey, any thoughts on my situation:
Have 2017 86 AT, installed billet blocks with the OFT tune that is edited based on Shiv's directions. 1000km later had coolant explode over engine bay and overheating occur. Blue coolant had turned green. Took to shop and they're suspecting a blown head gasket and want to tear apart the engine. Pressure test show a leak once engine warms up. The said they checked the water pump and radiator which are fine. What else could be the cause before this large repair.
Thank you.
TheFox is offline   Reply With Quote
Old 06-13-2020, 04:32 AM   #199
tomm.brz
Drives: brz 2017 hksv2
Shit happens
Difficult to say it was the tune since I have hard time thinking some knocks on NA can destroy this engine since the knock control
unless it was knocking like crazy and you didn t check with logs
So not much else to say
Old 06-13-2020, 04:50 AM   #200
steve99
Drives: FT86
Thank you.
When those power blocks installed you needed to remove intake manifold and their is some coolant lines going to throttle body, maybe those got dislodged or damaged ?.
Unuual that blue coolant could turn green, unless Green coolant used to top up, mixing coolant types is not recomended If oil was in coolant it generally turns into sludgy mess.
Old 06-14-2020, 07:28 PM   #201
TheFox
Thanks for the help everyone
Old 08-01-2020, 09:58 PM   #202
Vicgbbjj
Vicgbbjj's Avatar
Hey Shiv, I just intalled the power blocks on my FR-S and now the car seems to be dying at idle. I have to give it gas upon turning the key to keep the car to even turn on. Do you know what might be the issue?
Vicgbbjj is offline   Reply With Quote
Old 08-01-2020, 10:39 PM   #203
Lantanafrs2
Drives: 2013 frs red
Check your installation first. Vacuum leaks via pinched o rings or the vacuum tube that connects to back of manifold would be my first concern
Lantanafrs2 is offline   Reply With Quote
Old 08-28-2020, 11:19 AM   #204
_search
Originally Posted by crabarts231 View Post
I just installed my BPB, my current tune is V4.0.3 Stage 2+. I have the same question as Hiko. Should I modify my "knock correction advance Max A" as Shiv's instruction back to 2014 or just leave it as original map with BPB?
Timing Compensation Per Cylinder A/B are both set to 0 in V4.0.3. Should have no concern in this part.
Hey, did you end up modifying or leaving the map as it is? I'm also running V4.0.3 Stage 2+ and just pulled the trigger on some BPBs. I can't seem to find a definitive answer on "to tune or not to tune".
_search is offline   Reply With Quote
Old 03-11-2022, 08:44 AM   #205
Wingnutt
Drives: Pearl White 2014
Apologies for the Necro but I was wondering if there is still no suggested changes for E85 when running the BPBs?
Im runing the Stage 2+ E85 tune: Stg-2-Plus-E85-v4.03-LC-FSS-ZA1JB00C.
Wingnutt is offline   Reply With Quote
Old 03-11-2022, 12:20 PM   #206
PulsarBeeerz
Drives: JRSC BRZ SOLD
They don't work well together. 949Racing tried it with Delicious tuning and they just are not compatible.
PulsarBeeerz is offline   Reply With Quote
Old 03-11-2022, 03:22 PM   #207
Wingnutt
"Not compatible". How do you mean? I'm running E85 with them (and the tune I listed) and have been for a while with no issues. Or do you mean there is just nothing to really gain by adjusting the tune?
Old 03-11-2022, 03:39 PM   #208
PulsarBeeerz
Oh sorry, yes nothing to be gained. Delicious tuning tried to get them to work with each other but they lose too much VE after 6500 where E85 really shines. Also I have seen a couple cases where E85 eats at the O-rings supplied by Crawford causing leaks.
Old 12-25-2022, 12:58 PM   #209
BradH_NC
Drives: 2013 FRS
Is it necessary to edit the OFT tune?
If I install the Billet Power Blocks, do I necessarily need to edit the OFT tune? Or will the engine run well without editing the OFT tunes?
BradH_NC is offline   Reply With Quote
Old 12-28-2022, 09:21 AM   #210
BradH_NC
Drives: 2013 FRS
Update
OpenFlash told me “ Yes it is safe but just not ideal for peak power.”
Hopefully this helps someone. It appears from the dyno graphs that editing the files will only make a few hp difference at 7000rpm. I don’t trust myself editing the file in Romraider, so I’m going to leave it alone.
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
