Old 09-07-2022, 02:36 PM   #1191
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by weederr33 View Post
Maybe it does. But EV is not the solution for a very long time.
Why isn’t it a long term solution? Why is hydrogen better as a long term solution?
Same thing applies to Hydrogen. If it was being worked on with the same diligence, the "bar" above would over time get lower, and probably get within spitting distance of battery.
At this point, I'd take either as long as the infrastructure is close to reasonable. Unfortunately that leaves hydrogen out.
With hydrogen, we are running into hurdles that have to do with chemistry and physics that can only be improved so much.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (09-07-2022)
Old 09-07-2022, 02:48 PM   #1192
Like batteries? The challenges are no different really it is just that batteries received the focus and is where the money has gone so they won.
Dadhawk (09-07-2022), soundman98 (09-07-2022), Spuds (09-11-2022)
Old 09-07-2022, 06:36 PM   #1193
Irace86.2.0
That wasn't coincidence. They won for a reason.
Hydrogen will always be less efficient than BEVs, so that is a hurdle that is impossible to overcome. Electricity can be produced through renewables and stored in batteries to be used in cars, or electricity can be used to produce hydrogen, and then the hydrogen can be used to produce electricity again to put into a battery to run the car. This is like Rube Goldberg system. Just simplify.
The hurdles for hydrogen is the inherent need for more infrastructure to desalinate water, to produce hydrogen and to deliver/store/transport hydrogen, and there is a need for even more renewables than BEVs. Just comparing the efficiency of 73% versus 22%, we would need to produce 3.3x the amount of renewable energy to produce enough hydrogen to produce enough electricity to match the output of BEVs.
For BEVs, the main two problems are range and materials. Hydrogen fixes the range for planes or ships or off-road vehicles, but it isn't necessary for passenger vehicles or semis with high-density, solid state batteries and battery swapping. Sodium sulfur batteries will fix the range and materials issues. When swapping catches on and becomes modular and probably standardized, batteries will be even smaller.
Old 09-07-2022, 06:44 PM   #1194
Lantanafrs2
Drives: 2013 frs red
https://www.google.com/amp/s/www.for...l-and-gas/amp/
Lantanafrs2 is offline   Reply With Quote
Old 09-07-2022, 07:19 PM   #1195
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Lantanafrs2 View Post
"Elon Musk said..."
Me:
The Following 6 Users Say Thank You to ZDan For This Useful Post:
Irace86.2.0 (09-07-2022), MyHybridBurnsGasAndTires (09-08-2022), NoHaveMSG (09-11-2022), Spuds (09-11-2022), Tcoat (09-07-2022), weederr33 (09-11-2022)
Old 09-07-2022, 07:43 PM   #1196
Irace86.2.0
There is a lot of 'no duh' moments and also moments when Musk is getting it wrong in that article. For instance, we have been saying that it will take decades to just get off oil for passenger vehicles, but we obviously use oil in everything from plastics to fertilizer. There are alternatives, but it will be quite a while for the world to significantly reduce oil dependence, so yeah, of course we can't go cold turkey overnight.
In an interview with the New York Times last year, the billionaire said he felt a “bit bad about hating on the oil and gas industry” as the people who built those companies had no idea about the impact of fossil fuel usage.
Oil companies knew about global warming back in the 1980's, but they did everything to refute and dismiss what they knew to be true. Musk knows that. He may just be trying to make some new friends.
https://theconversation.com/what-big...n-words-170642
I'm not against nuclear because it is green, but the reality is that it is extremely expensive upfront cost, the plants take a long time to make, there are huge government (at every level) obstacles that delay production, no one wants it in their backyard, there is the question of the long and safe storage of nuclear waste, there is the risk of meltdowns, there is a risk of terrorism, and there is probably more. Companies trying to maximize their profit do the bare minimum to prepare and maintain the facilities, which is always concerning. If an accident occurs, it could leave an area uninhabitable like Chernobyl. Governments typically need to subsidize the investment, but even then, investors may not see a return for decades, so they would rather put their money into solar or wind, which has dropped significantly and is faster to market and faster to get a return on their investment.
Old 09-11-2022, 02:38 PM   #1197
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Energy. Density.
Vehicles do not have unlimited space and mass.
Paper from 2014 and likely a bit biased toward hydrogen, but it illustrates the idea.
https://www.energy.gov/eere/fuelcell...icles-compared
Old 09-11-2022, 08:49 PM   #1198
Irace86.2.0
Energy. Density.
The paper is fairly old and hasn’t aged well. The range vs vehicle weight chart hasn’t held up to time. For instance, a Tesla Model 3 standard range plus with 262 miles of range weighs 1,645kg, which isn’t too far away from a comparable BMW and is a ways away from 2,000kg suggested in the article. Meanwhile the new Toyota Mirai weights 1,920kg/4,224lbs with 402 miles of range, and the comparable Tesla Model S weighs 4,883lbs, so the Tesla is heavier, yet it is also 4” wider, but it is not 3,000kg/6,600lbs like the article suggests.
The battery density has probably improved, and they didn’t consider packaging. Previously, BEVs were ICE vehicles retrofitted with batteries. The skateboard design utilizes the battery as a structural component of the car, which reduces weight, and the packs and modules are far more efficiently built into the vehicles without the bracketry needed to mount inverters and other components into conventional engine bays. I think if you compare the cargo capacity of the Model S and Mirai, the Tesla would have more, so the topic of storage predates the skateboard design, which is very compact.
Power and performance seems to be well managed despite their statements. The Mirai goes 9.2 sec to 60, and 7.4 on the mark II, but this is much slower than the Model S standard at 4.2 sec.
End of life GHG emissions for BEVs are less than HCEVs, even if hydrogen was produced from renewables, so they are wrong there too. Part of the problem are the conversion losses, and the other problem was the energy density improvements and vehicle weight.
Cost is comparable or favoring the BEVs when we base things off performance.
The energy density of new sodium/lithium sulfur batteries is on a different scale and makes this paper even more outdated. The recent discovery of a stable lithium sulfur battery with greater charge cycles. These batteries aren’t going to have 8x the range, but expect huge improvements to range. Sodium sulfur batteries have excellent power density and have shown to have 5,000 cycles making them twice that of lithium ion.
The energy density of traditional Li-ion batteries can hardly go beyond 300 Wh/kg.
Based on an average discharge voltage of 2.15 V, the theoretical gravimetric energy density of a Li-S cell is ~2,510 Wh/kg, which is much higher than that of the traditional Li-ion batteries.
https://www.frontiersin.org/articles...019.00123/full
This development would not only make sulfur batteries commercially viable, but they would have three times the capacity of Li-ion batteries and last more than 4,000 recharges
https://drexel.edu/news/archive/2022...te-electrolyte
Old 10-28-2022, 04:32 PM   #1199
Irace86.2.0
Why hydrogen ICEs are probably not going to work for many people:
Dadhawk (10-28-2022)
Old 12-22-2022, 05:11 PM   #1200
Irace86.2.0
Old 12-22-2022, 05:18 PM   #1201
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Uniquely disquieting "Tommy Boy" vibes with that guy.
but that's just me I suppose.
Old 12-23-2022, 08:39 AM   #1202
soundman98
ProCrastinationConsultant
soundman98's Avatar
i didn't watch the video, but the reality is that ford would need to pull every single franchise contract in order to effectively hurt the markup stuff.
with all the dealers being a franchise instead of being owned by ford, ford has little to no real say in the matter, like it or not.
Old 12-23-2022, 09:23 AM   #1203
Not sure that is 100% accurate given Ford controls allocations to dealers, and that seems to be the route they are going down.
Irace86.2.0 (12-25-2022)
Old 12-23-2022, 01:09 PM   #1204
soundman98
soundman98's Avatar
i dunno, there's enough other fees a vehicle purchase, i don't hold out hope that they don't move the numbers in the fees around a little to offset it while looking 'legal' to ford.
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 01:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 04:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 12:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 02:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 07:27 PM
