Old 12-16-2022, 10:12 PM   #5097
I personally don't know if I would spend the money again. I paid 800, I think, for my used nameless header. It is coated inside and out.
Actually, you've just put me over the edge. It most needs tightened up past the differential. I should spend that money on custom half-shafts. Some tougher cv joints.
Old 12-16-2022, 10:28 PM   #5098
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The juice just isn't worth the squeeze to me. I could decat a stock header or buy a Tomei and get most of the gains for a lot less. There is also a kid in a stock power BRZ that has laid down some stupid lap times at the Ridge and PIR.
That reminds me, I need to go through and repack my CV's again and build a heat shield for the driver side
Old 12-16-2022, 10:45 PM   #5099
I really am satisfied with the power, and I have strong feelings about cats. I would only run it if I could pass minimum efficiency with only the downstream cat. I'd have to score a spare stock front pipe and install a bung all for the experiment.
Yeah, that hot spot is real. Overpipe cooks that sway bar bushing too. Shit, the whole tunnel gets hot.
Old 12-16-2022, 11:36 PM   #5100
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I really am satisfied with the power, and I have strong feelings about cats. I would only run it if I could pass minimum efficiency with only the downstream cat. I'd have to score a spare stock front pipe and install a bung all for the experiment.Yeah, that hot spot is real. Overpipe cooks that sway bar bushing too. Shit, the whole tunnel gets hot.
I've contemplated going fully back to stock exhaust and just having the car setup for flex fuel and maybe just run a cat back. I haven't decided. I have a couple goals I am shooting for.
My sway bar bushing surprisingly does not look terrible, but I will likely replace it along with a few other bushings. As much as a pain as some of that stuff can be I might as well do it while I have the car apart.
Old 12-17-2022, 10:44 AM   #5101
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Stop. Giving. Me. Ideas.
Already debating whether to get a overpipe coated to stop my sway bushing from melting again.
Also: "Build Thread"
Old 12-17-2022, 11:05 AM   #5102
soundman98
ProCrastinationConsultant
soundman98's Avatar
no, you should definitely do that.
Old 12-17-2022, 11:40 AM   #5103
cjd
cjd's Avatar
Drives: 2017 BRZ
E85 at half the price of 93 is far too tempting (it's not that way any more, but not long ago it was). Then again, I hardly even get the car out of the garage these days so what's the point of even having it? decisions... I'm also tempted to just get silly and add boost to the mix.
I can't entirely compare Ace to Nameless due to a different tune, but the Nameless pulled harder up high and the Ace is better in city driving. The difference is quite surprising. Worth the cost vs other options? Hard to say. I'm a min/maxer so the answer is clear to me (thus swapping the PP Brembos for AP Sprint/vanilla OE - seems now I could have kept the Brembo rears but at the time I couldn't find data on bias).
As long as you have fun with your process/result I'm not sure it really matters. Pick the parts that do what you want them to do.
Old 12-17-2022, 12:36 PM   #5104
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You could always just wrap it.
Old 12-17-2022, 02:23 PM   #5105
Spuds
The Dictater
Spuds's Avatar
Stop. Giving. Me. GOOD. Ideas.
Excuse me while I go look up things about exhaust wrap and see whether it's worth it to remove the over pipe heat shield...
Old 12-17-2022, 03:40 PM   #5106
Oh, get on with it and jest wrap it! -
Bubba
Old 12-17-2022, 03:58 PM   #5107
Spuds
The Dictater
Spuds's Avatar
Bubba
That looks a bit like how I fixed the hole in my exhaust in college.
Old 12-17-2022, 04:14 PM   #5108
I dunno... It's pretty easy to replace that bushing. I still haven't replaced mine but I don't really lean on it for any length of time.
Old 12-17-2022, 04:48 PM   #5109
Spuds
The Dictater
Spuds's Avatar
Oh, I got a Perrin front sway bar going in with it's own bushings. I just don't want anything to happen to that one lol.
Old 12-17-2022, 04:56 PM   #5110
Meh. Consumables.
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
